09-15-2014, 09:20 AM | #26 |
Re: Reproduction Rubber Floor Mat
I need one as well & would pay a couple hundred for an original looking rubber mat. Maybe more since it's my only available option.
'62 Chevy K10 |
09-15-2014, 12:56 PM | #27 | |
For more reference, I will include a picture of the mat in my 66 C20, also a low hump. The texture is very similar (if not the same), but you can see a slight difference in the pattern. The 1966 low hump mat The 1962 low hump mat |
09-15-2014, 01:09 PM | #28 |
[QUOTE=oem4me;6843708]Well, I could be mistaken. The mat pictured in my previous post is the one that was in my 62 C20 when I got it, and as far as I can tell that truck was completely original and unmolested. It even has near perfect factory seat upholstery, so I know the interior was well taken care of. I guess it could have been swapped out, but that would surprise me.
For more reference, I will include a picture of the mat in my 66 C20, also a low hump. The texture is very similar (if not the same), but you can see a slight difference in the pattern. The 1966 low hump mat Attachment 1301962 i had an nos mat that had 60-62 on the box and i had the other pattern on it, and when i got it off ebay it was stated as 60-63. |
09-15-2014, 01:13 PM | #29 |
Ok, to further confuse the issue of mat identification, here's a pic of the mat in my '65 Suburban, a 46K mile survivor.
1965 high hump Last edited by oem4me; 09-15-2014 at 02:13 PM. |
09-15-2014, 01:16 PM | #30 |
But Found Her 25yrs Later!
I guess we'll have to allow more members to post before either of us can be positive.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-15-2014, 01:38 PM | #31 |
Ok. Here's my Original 1962 Chevy K10 high hump floor mat.
Looks just like OEM4ME.
'62 Chevy K10 |
09-15-2014, 01:45 PM | #32 |
Looks like we have a larger variety of mats available for the older years that we were unaware of.
Here's another thread showing even a third pattern; http://67-72chevytrucks.com/vboard/s...d.php?t=477989
09-15-2014, 01:54 PM | #33 | |
09-15-2014, 02:11 PM | #34 |
My sense that those are not OE mats is reinforced by the fact that the boxes they came in are not GM boxes, but clearly aftermarket. Agreed?
09-15-2014, 02:13 PM | #35 |
That's a valid point.
Probably just odd aftermarket patterns.
09-15-2014, 05:02 PM | #36 |
09-15-2014, 05:05 PM | #37 |
found a pic of the box
09-15-2014, 05:06 PM | #38 |
09-15-2014, 06:52 PM | #39 |
We'll eventually get to the bottom of this.
Pimpston, that box/mat you had was no doubt vintage, but may have been aftermarket. Most, if not all GM issued parts or accessories had GM/Chevrolet logos and both group and part numbers listed on the box. Below is an example of a period mat in an original GM box (not a truck, but impala or something). |
09-15-2014, 07:28 PM | #40 |
Mitch--what shifter is in your tk? looks like a sm465?
1961 chevy K10 my build is------------61K10 build |
09-15-2014, 08:47 PM | #41 | |
03-18-2015, 03:58 PM | #42 |
Ditto - my 1965 GMC has the identical color & pattern as the 62 & 65 pictured above. I desperately need a replacement. Just spent $175 for black vinyl Matt from ACC as an interim but I'm still holding out hope that someday, someone will offer a correct, high hump reproduction.
03-18-2015, 08:31 PM | #43 |
03-19-2015, 10:43 AM | #44 |
Tranny is a SM420.
I checked the shifter and it has the bowtie emblem at the bottom. Yall think it's been re-shaped? I'll have to do some searching for the correct pattern. When I pulled it, it didn't show any signs of heating, or stress cracks. But...
'62 Chevy K10 |
03-19-2015, 11:11 AM | #45 |
All I know is my sm420 shifter is one bend she of Yours. Granted I have to later model casting so the housing by my reverse gear is Finned. Vs. Yours that's smooth. So I don't know if early model sm420s had a different shifter Than late model ones. but I couldn't imagine they'd differ. It'd be a waste of time. Unless there was seat clearance issues. that shifter does look like the one on a sm465 that I have. Don't think there interchangeable...
Well that didn't go as planned. 1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6 |
03-19-2015, 11:28 AM | #46 |
Well I guess, I finally found an un-original piece! lol The old man sure didn't change much, that's for sure!
'62 Chevy K10 |
03-19-2015, 02:00 PM | #47 |
I have three k models with sm420s and all have straight transmission levers and a 68 with a sm465 with same shifter lever
03-19-2015, 02:06 PM | #48 |
Yall are right. It just never occured to me. I know its a SM420 , reverse is far left and back.
So, I guess it has a SM465, shift lever...Now I gotta find an orig...
'62 Chevy K10 |
03-19-2015, 03:10 PM | #49 |
Shouldn't be to hard to find there fairly common in junk Yards.
03-19-2015, 03:24 PM | #50 |
Ive had at least two of those shift levers bent like that to clear underdash AIR Conditioning units
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
