11-25-2012, 08:53 PM | #26 |
Re: Photo needed of Hood Latch 1972 Blazer
brianK ,
Do your trucks latches look like the pics in post #5 or is there something different. Thanks Tbruz |
11-25-2012, 10:00 PM | #27 |
Yep, they're all the same.
Posted via Mobile Device |
11-26-2012, 12:11 AM | #28 |
Old member
Depending on how well you have the outer snubber's adjusted and the bullet adjust will make the hood pop up correctly. The hood hinge springs will detirm how much it pop's up.
The two outer snubbers on the corners of the hood and the bullet have to be correct for it to lift though! The trucks are the same way. Black snubber lower right corner in picture.
