Old 12-11-2012, 12:29 AM   #26
Xeen
Xeen's Avatar
Re: Project 69SWB
Nice truck to start with, I will be watching this one.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 12-11-2012, 11:59 AM   #27
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks. I'll try to keep you entertained!
~Whitey~ is offline   Reply With Quote
Old 12-11-2012, 12:04 PM   #28
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I got my control arms all cleaned up, painted and installed new Moog balljoints (upper and lower). The upper where a bit of a bear to get out, but a sharp chisel, drill bit, and 3lb hammer did the job. It's a good thing I went through this front end.. I had multiple bolts that were loose and my drivers side lower balljoint was shot.
Old 12-11-2012, 12:08 PM   #29
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I have a homemade sandblaster I use on small stuff... It's a pain in the rear to drag out and use but does save me alot of money. Blasted the front and rear springs, sealed with rust stop and painted. Also painted my calipers with grabber green engine enamel.
Old 12-11-2012, 12:13 PM   #30
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
after letting everything dry for a couple days it was time to put it all back together and get this frame to rolling again. I did created a little custom sticker for my shocks and had them cut out in vinyl.
Old 12-11-2012, 12:29 PM   #31
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
With the frame ready to roll again, it was time to clean up the motor. This is a crate 350 engine with roughly 10k on it. It does run like a champ so I'm not going to go to far into it... just basically replacing some gaskets top, bottom and front, etc, new water pump, harmonic balancer, plugs, wires and cap. I took it down to heads and block, cleaned, degreasing and almost ready for paint.
Old 12-11-2012, 12:35 PM   #32
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
My performer RPM intake cleaned up real good with some etching cleaner, I then painted it black... and then I had this undying need to set the carb on it.
Old 12-11-2012, 12:38 PM   #33
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
here's a before and after of my PS pump... saved a little money by just taking the time and loving on this a bit.
Old 12-11-2012, 12:42 PM   #34
sgaylord
Project collector
sgaylord's Avatar
Re: Project 69SWB
Cleaning up nicely. Is the theme hotrod black and green?
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 12-11-2012, 12:42 PM   #35
67cheby
67cheby
67cheby's Avatar
Re: Project 69SWB
great progress, keep the pics coming !
67cheby is offline   Reply With Quote
Old 12-11-2012, 12:44 PM   #36
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I am painting the truck black, just the motor and calipers will be green.
I'm trying to get caught up... almost there.
Old 12-11-2012, 12:48 PM   #37
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Here's the motor all cleaned up and painted... I got a little happy with the green paint and got some over spray on my valve springs.. but it wiped off real easy since they were oily... I ordered some valve covers from Edelbrock that took forever to come in.. didn't have them for these pics. Cleaned up my oil pan, new gaskets on intake, oil pan, timing cover, fuel pump, new water pump, new harmonic balancer...
Old 12-11-2012, 12:51 PM   #38
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
motor going back in... 350 turbo transmission, took me all day to clean up, etch and paint. It's been beefed up a bit and has a shift kit in it. I replaced the filter and pan gasket, as well as front and real seals.
Old 12-11-2012, 12:55 PM   #39
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Here's the motor back in and the truck pushed out of the garage on wheels for the first time in about 4 months. was going to take it for a spin but was out of gas and a steering wheel. Have a ton of little stuff to do, but getting to here has been a big step. Valve covers finally came in and I picked up cap, rotor and wires. painted the cap grabber green.
Old 12-11-2012, 12:55 PM   #40
RexDodge
Re: Project 69SWB
Nice progress. Yay for the budget builders! We always find a way to git er done!
RexDodge is offline   Reply With Quote
Old 12-11-2012, 12:57 PM   #41
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
It's the only way I can get it done! haha.
Old 12-11-2012, 01:03 PM   #42
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
here's a video I shot that day I pushed it out.
Old 12-11-2012, 01:47 PM   #43
Chev71
Chev71's Avatar
Re: Project 69SWB
Nice progress man, I wish I was done with my Chasis already
Chev71 is offline   Reply With Quote
Old 12-11-2012, 01:59 PM   #44
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks... It wasn't until after I got it done and motor back in that I actually felt like I had accomplished a big part of the project!
Jimmy
.69SWB Build.
Old 12-11-2012, 03:01 PM   #45
chopnchaneled
chopnchaneled's Avatar
Re: Project 69SWB
Your going great guns on it, looking good.
Going to tag along and watch if you don't mind.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 12-11-2012, 03:10 PM   #46
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thank you and I don't mind at all.. I've got most of what I've done so far posted up... little more and I'll be to where I am at today with it.. and I'll be needing some advice from all of you for sure.
Jimmy
.69SWB Build.
Old 12-11-2012, 03:12 PM   #47
Xeen
Xeen's Avatar
Re: Project 69SWB
I'm at the ready, fire away.
Old 12-11-2012, 03:23 PM   #48
Xeen
Xeen's Avatar
Re: Project 69SWB
What is the current condition of the cab?
Was the previous rust repair work done right or does it look like there is an inch of bondo on it in places?
Old 12-11-2012, 03:30 PM   #49
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Getting ready to post up pics. The previous repair work was NOT done correctly in my opinion.
Jimmy
.69SWB Build.
Old 12-11-2012, 03:31 PM   #50
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Here it is freshly back from being blasted... Picked it up last night.
Jimmy
.69SWB Build.
1969, black, custom 10, fleetside, shortbed
