Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 12-21-2012, 01:32 PM   #26
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: 66 suburban aka the sub
nice job look great you are moving quick keep it up!!!
gostranger is offline   Reply With Quote
Old 12-21-2012, 11:49 PM   #27
69 chevy 1
69 chevy 1's Avatar
Thanks Gostranger glad to be among fellow burb lovers, I have read your build and it has inspired me allot,you guys on the board have some nice trucks,Ill keep the pedal down
69 chevy 1 is offline   Reply With Quote
Old 12-22-2012, 12:04 AM   #28
69 chevy 1
69 chevy 1's Avatar
6.0 exhaust fitment with the camaro exhaust manifolds
Old 12-22-2012, 08:41 AM   #29
gostranger
gostranger's Avatar
Cool let me know if you have any questions that I could help you with!
Old 12-24-2012, 09:00 PM   #30
69 chevy 1
69 chevy 1's Avatar
These were pictures back in late September early October before my sub went to the bodyshop prison, we kinda stripped it down
Old 12-24-2012, 09:11 PM   #31
69 chevy 1
69 chevy 1's Avatar
And a few more since it had to be stripped to the bone,
Old 12-24-2012, 09:18 PM   #32
69 chevy 1
69 chevy 1's Avatar
And more,my body guy will take the doors,hatch and other goodies off himself,also he will install the tall floor hump in place of the low hump,should clear a 4l60e according to you wise men.The tall floor hump came with the burb back when i purchased it.
Old 12-24-2012, 09:28 PM   #33
69 chevy 1
69 chevy 1's Avatar
The burb came with factory air including the center vent,include drier condensor,but i have no ideal why the fire wall was cut up in such a way,maybe this was a factory unit that was dealer installed I dont really know, looks like my body guy has to cover those to.
Old 12-29-2012, 08:19 PM   #34
69 chevy 1
69 chevy 1's Avatar
frame ready for tires
Old 12-29-2012, 08:21 PM   #35
69 chevy 1
69 chevy 1's Avatar
front and rear tires on just about a roller
Old 12-29-2012, 08:25 PM   #36
69 chevy 1
69 chevy 1's Avatar
pics of frame on the ground and fuel lines ran, went with a 2006 single feed factory fuel line into single fuel rail fitting.Also went with corvette regulator with a ford fuel filter piggy backed at the outlet,and then plastic line from tank
Old 12-29-2012, 08:27 PM   #37
69 chevy 1
69 chevy 1's Avatar
driveline was also cut and installed,picture of the driveline, all suspension is stock except of springs spindles and blocks in the rear should be around 4/6 give or take.
Old 12-29-2012, 08:28 PM   #38
69 chevy 1
69 chevy 1's Avatar
all fuel line fittings are quick connect like you would find in most fords and chevys,gonna install some heat sheilds also from pick-a -part
Old 12-29-2012, 09:19 PM   #39
19GMC66
19GMC66's Avatar
Cool project.. Should have kept my burb!
19GMC66 is offline   Reply With Quote
Old 12-30-2012, 02:28 AM   #40
69 chevy 1
69 chevy 1's Avatar
19gmc66 thanks for the kind words,check in on my build sometimes it keeps me going
Old 01-03-2013, 01:15 AM   #41
69 chevy 1
69 chevy 1's Avatar
Well my shop empty for a bit my brothers 67 imp on the way over for some new suspension parts a little break from the burb body guy is moving pretty fast though guess i had better hurry.
Old 01-03-2013, 01:25 AM   #42
69 chevy 1
69 chevy 1's Avatar
The burb really isnt bad when the old bondo is removed and dents are removed the correct way, couple before and after shots,rockers are solid one small rust spot at the bottom of door,had to cut it out
Old 01-03-2013, 01:36 AM   #43
69 chevy 1
69 chevy 1's Avatar
before and after shot of drivers side,getting it stripped down off with the old paint.
Old 01-03-2013, 02:28 AM   #44
Crx150zc
Great looking burb, Can I get a little information on the rear tranny mount, Did you build it your self? And how do you plan to run the exhaust?
Crx150zc is offline   Reply With Quote
Old 01-03-2013, 02:52 AM   #45
RockTonka
RockTonka's Avatar
Great progress! Body man is moving fast too, you're going to have this together by summer.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 01-03-2013, 10:16 AM   #46
gostranger
gostranger's Avatar
awesome super fast work!!!
Old 01-04-2013, 02:54 AM   #47
69 chevy 1
69 chevy 1's Avatar
thanks crx150zc the cross member is a classic performance unit I will measure the bend,you set the ends and you can weld them down or bolt them,then the two ends can be bolted to the frame,mine are bolted to the frame I will post a pick of some close up shots,my plan for the exhaust will run under the trans cross member and back,then I will run them up behind the rear cross member into some mufflers and dump in front of the rear end.but im looking for suggestions
Old 01-04-2013, 02:55 AM   #48
69 chevy 1
69 chevy 1's Avatar
Thanks Rock Tonka your Burb is so cool love what you and your son have been doing on your rig,I got my 69 c10 back from paint may 2011,took him a while witch it usually does,But I swear I started trying to get the painter lined up on the burb back in march when I bought it and he was busy so I waited because he said August,then Sept,then October 6 was the date,now he is really moving at a nice speed,and sending me a lot of picks,so ill post more as they come in,I actually bought some fenders and a grill surround to deliver to him.bought them at tuckers trucks in Henderson nv.
Old 01-04-2013, 03:17 AM   #49
69 chevy 1
69 chevy 1's Avatar
Thanks gostranger painter usually goes slower,he usually hates some of of my projects IMPALAS, and tells me no more trucks,but I think he likes this one or hates it LOL.Said he was gonna strip the roof and start sealing,he has been stripping the inside,I told him I wanted all the holes in the fire wall welded up and the high up put in.
Old 01-04-2013, 03:19 AM   #50
69 chevy 1
69 chevy 1's Avatar
Thanks to all you guys for having such nice works of art.
