Old 01-07-2013, 11:29 PM   #26
derrickmanx1
derrickmanx1's Avatar
Re: 71 Chevy LWB Transformation
Originally Posted by MJs69CST View Post
Nice!!
Thanks a bunch. I finally made it to the 2nd page!!! LOL.
NAME: TRAVIS TRUCK: BRUISER
71 C/10 SWB 3.5/5" drop 4.11 GEARS.
F.A.S.T. BBC 408 496hp/479ft/lb
JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL
My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530
derrickmanx1 is offline   Reply With Quote
Old 01-08-2013, 11:43 AM   #27
67cheby
67cheby
67cheby's Avatar
nice wheels and tires !
67cheby is offline   Reply With Quote
Old 01-09-2013, 06:15 AM   #28
derrickmanx1
Thanks, I sure liked the way they looked. I'm doing a hot rod black truck so I hope they work out good. Now I just get to make them work. Well I've been pushed back on the dyno again. It's not a big deal right now cause i'm stuck at work in the middle of the Gulf of Mexico. So he will dyno it friday and send me the results. As soon as I know something i'll post it. CPP finally got my axle perches, bilstein shocks and lowering blocks w/u-bolts to me. I'll be ready to mock up the engine, trans and rear-end when I get home so I can finish the frame, driveshaft and exhaust. FUN FUN FUN!!!! I really do like it.
Old 01-09-2013, 06:19 AM   #29
derrickmanx1
I'm hoping to be done in march or april so I can shake it down before june.
Old 01-11-2013, 07:23 AM   #30
derrickmanx1
Well its dyno day!!! I hope it all goes well today. We'll know something this afternoon. I'm so ready for this.
Old 01-14-2013, 12:52 AM   #31
derrickmanx1
Well maybe today on the dyno. The engine builder got it on the dyno friday and had something come up. I'm not in a big rush just excited.
Old 01-14-2013, 01:02 AM   #32
derrickmanx1
More pictures.
Old 01-16-2013, 10:07 AM   #33
414banger
414banger's Avatar
if you dont mind me asking how much did you pick that trans controller up for and is it completely stand alone
414banger is offline   Reply With Quote
Old 01-16-2013, 11:17 AM   #34
derrickmanx1
They average around 650-700. It is a stand alone unit. It comes with everything you need except the throttle possition sensor for a carb. I have fast injection so I have no need to buy another one.
Old 01-16-2013, 02:58 PM   #35
~Whitey~
~Whitey~'s Avatar
Looking good! Can't wait to see this one through... I debated on getting wheels with the darker centers but since I'm painting my truck black I went ahead with some polished aluminum. super jealous on the calipers/rotors, wish I could have swung them for mine.. maybe later on down the road. Keep the progress coming!
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 01-16-2013, 06:39 PM   #36
derrickmanx1
Thanks. Time sure is dragging on this drilling rig. I get home in a week but then I have a meeting in Alabama so i'm bummed out on that. I will be working on it hot and heavy though when I can. Thanks again for the encouragement.
Old 01-20-2013, 06:28 AM   #37
derrickmanx1
Well the little 408 made 496 Hp @5600 rpm. Should be a great street motor. When I get the sheet i'll post it.
Old 01-20-2013, 11:57 AM   #38
suspect
suspect's Avatar
I like your choice in brakes!
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 01-20-2013, 12:39 PM   #39
derrickmanx1
Thank you
Old 01-20-2013, 10:19 PM   #40
derrickmanx1
Well I talked with engine builder. He said my torque curve was table top flat from 4200-5600 @ 479 ft/lbs. It made 496 hp @5600 had good smooth idle and made good vacuum.
Old 01-27-2013, 09:47 PM   #41
derrickmanx1
Well got back to work on the truck today finally. I cleaned the bed up and worked on straightening the floor in it. I got the new tailgate out and looked it over. I'll pick the engine up and put it in the frame on wed. I still need to work on the drivers side cab corner, rocker and floor pan. Then i'll clean everything up in the cab and paint it.
Old 01-27-2013, 09:48 PM   #42
derrickmanx1
Oh and I plan on chassis dynoing it when it's put together
Old 01-31-2013, 12:41 AM   #43
derrickmanx1
Here's the dyno cover sheet and a picture of the engine. Tomorrow I install the rear end and the engine/tranny to the frame. Then the drive shaft.
Old 01-31-2013, 12:50 AM   #44
derrickmanx1
Still working on the cab in between times I want to have it and the front clip painted by the 11th of feb.
Old 01-31-2013, 11:13 AM   #45
67cheby
67cheby
67cheby's Avatar
Nice stuff !
Old 02-01-2013, 12:37 AM   #46
derrickmanx1
Some more pictures of the trucks progress. Working late and found a bunch of horrible body work on the bed. Some people just don't need to be body men. I'm no pro but crap some of the stuff I have seen on this build. I didn't take pictures of the hacked out hole in the side of the bed but wow the patch panel was just tacked in and they used bondo to seal it up. The panel was a jagged 6" circle to cover a 3" hole. Got the rear end smoothed up and ready to install on the trailing arms.
Old 02-04-2013, 01:10 AM   #47
derrickmanx1
Well I got the rear end in place and loose. The engine is mocked up on the bare frame and I have the accessory drive on the front of the engine. I have the left header on and need to install the right side. I have a question though about the performance online motor mounts. Should they be in the front or back holes? I'm thinking the back holes. I'll try to get the fuel injection and starter in place as well as the fuel tank. Need to get the drive shaft made also.
Old 02-04-2013, 01:26 AM   #48
VA72C10
VA72C10
VA72C10's Avatar
Nice build!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-04-2013, 01:38 AM   #49
derrickmanx1
Originally Posted by VA72C10 View Post
Nice build!
Old 02-05-2013, 01:53 AM   #50
derrickmanx1
Well I got the core support, cowl and the inner fenders painted today. Still working on the cab in between times. I need to mock up the a/c and cut holes for it, cut the hole for the stereo. Hope to be painting the cab by this weekend. All I lack is finishing!!!
