#26 |
Re: LS engine swap into 1966 c10; fuel tank install
#27 |
How do you open the gas cap with 60 psi and not have it knock you over. I'm missing something.
Jon S 1966 GMC Suburban 305 V6 Las Vegas NV |
#28 |
Never Ending Projects
It doesn't pressurize the tank, it is the pressure into the fuel line to the engine. The tank has to be vented anyways.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#29 |
Soo, if you send it out at that pressure, the tank vent has to let air in at that same rate, I think. If not vented the pressure could not be kept up, so not being vented enough could cause problems of low pressure. ???
#30 |
Vented gascaps are usually always a good idea... esp if you live in a high temperature change area.
Aka I fill my tank now (45*F) and in 2 weeks it will be 70*F and sunny one day. doesnt take long.
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
#31 |
When I did my suburban tank I used the factory Camaro pump and housing, I just cut it off the Camaro tank and welded it onto the suburban tank. That maybe an option, suburban tank with newer Silverado flange and pump., I left my stock suburban fuel sender in for the gauge.
#32 |
Return pressure is typically much less than supply pressure. Volume and pressure is lost because of the fuel used by the engine.
#33 |
Any pics of this tank? Or part number?
#34 | |
I think Terry said that he had to shorten the depth of the pump. |
#35 |
I tried this on a chevelle I did since the caprice tank is a nice replacement in the 70 chevelle. Even the impala SS fuel pump won't produce enough pressure.
#36 | |
#37 |
I was reading through this thread this evening and am thinking about a 19 gallon blazer tank and module ( they are cheap on ebay) for my 61 project.
I did an 98 s10 ls swap last year and the stock pump worked fine for the 5.3 I have an original cluster with the gauges I'd like to use in the truck, but if its not practical I'll upgrade to modern gauges. I'm curious as to what you all are doing for a fuel gauge, any one using the stock gauge? If so how is it done? Thanks, Bud |
#38 |
Tanks inc 53-54 Chevy passenger car, baffled and ready for Tanks supplied pump.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
#39 | |
How did you mount this, and do you have pics of what it looks like from below and behind?
1968 LWB C20 / AC / Wood Bed |
#40 |
Lower frame rails were trimmed approx 1/4-1/2 " to allow proper fit.
#41 |
Looks nice. Is the filler neck going to clear the frame rail?
#42 |
Yep, it fills behind the tail light
#43 |
Tucks up nice and high, hard to see from behind. I can't take credit for this install, other members pioneered this before me.
#44 |
Any pictures of how you made your tail light hinge? looks awesome, good work!
#45 |
This is during mock up on a spare bed corner, a great friend made this for me. I certainly couldn't have done it, LOL.
#46 |
Another one
#47 |
Thank you for the pics
#48 |
Whoa how did you get a filler with no cap?
#49 |
Ford Escape filler=no cap.
#50 |
that tail light gas fill is cool !!
