09-10-2013, 07:48 AM | #26 | |
Re: veiws on using the 283?
Bear in mind todays V8 truck engines are 4.8, 5.3, and 6.0 Liters so in cubic inches that's 292, 323, and 366. You can get a good bit of power from a small package with fuel injection. You don't have to have a dual carb 454 to make good power.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-10-2013, 08:32 AM | #27 |
by far the best budget engine build that made quite a bit of power that I've ever done was the 408 I had in my truck when I first built it. such an easy combo and can be done super cheap. basically what I did is found a sbc 400 cleaned up the cylinders, stock crank, stock 350 rods (5.7), ordered a cheap set of pistons, and had set of stockish 300hp heads (041 casting), decent sized cam, and aluminum intake. all in all I had a little over 1000 bucks in the whole motor and I'm fairly sure i was getting 1hp per cubic inch. super cheap, a ton of fun to drive, and very streetable
like it was said before there is no substitute for cubic inches!
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
09-10-2013, 08:32 PM | #28 |
Efficiency is a great substitute for displacement
09-13-2013, 10:37 AM | #29 |
i think you would spend more in the long run trying get more from less, plus stress out the block and rotating assembly, more Cubes means more power and a more stable base to build on.
a 350 cid at 300 HP is pretty cheap and common build
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
