Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-14-2014, 08:47 AM   #26
JayB331
JayB331's Avatar
Re: Project '67 Clone SWB
Cleaned up and measured the deck clearance on the passenger side pistons last night. They're all running between .020" and .024" down. Gonna clean up the drivers side tonight and re-measure everything.
'67 K10 SWB
350, SM465, NP205, 12 Bolt & Dana 44 w/ 3.08's
My Project
http://67-72chevytrucks.com/vboard/s...d.php?t=602684
JayB331 is offline   Reply With Quote
Old 01-14-2014, 08:50 AM   #27
JayB331
JayB331's Avatar
Originally Posted by swamp rat View Post
Yea i have the playoffs on my mind a bit too.
I'm guessing Go Seahawks?
'67 K10 SWB
My Project
Old 01-14-2014, 02:26 PM   #28
swamp rat
swamp rat's Avatar
Um..... Yea! LOL!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-16-2014, 12:05 PM   #29
JayB331
JayB331's Avatar
Well, it looks like I'll be replacing the cam in this engine. 2 lobes going flat, 2 scuffed lifters, and 1 lifter with a broken retainer. First thing I did when I bought the truck was change all of the fluids and the engine oil was filthy. The good news is, so far, everything else looks to be in good shape. I'm going to pull a couple of main caps and check the bearings tonight.
'67 K10 SWB
My Project
Old 01-17-2014, 01:09 PM   #30
JayB331
JayB331's Avatar
Checked a couple of the mains last night, the crankshaft and bearings look good. I'm going to go ahead and change the rear main seal while I'm this far into it. I pulled the trigger on a Comp Cams Nostalgia Plus 300HP cam last night. My goal is to have it back running by Super Bowl Sunday
'67 K10 SWB
My Project
Old 01-18-2014, 07:27 PM   #31
JayB331
JayB331's Avatar
Got a lot done in the past couple of days. The block's painted as well as the oil pan, timing cover, harmonic balancer, and alternator bracket. I cc'd the heads yesterday evening and each chamber is 76-77 cc's. The pistons are averaging .023" in the hole. I'm going with Clevite Nitroseal head gaskets with a compressed thickness of .026" giving me a quench area of .049". Plugging all the numbers in the trusty old DCR calculator gives me a static CR of 8.94 to 1 and a dynamic CR of 7.56 to 1. Just waiting on parts now!
So this afternoon, me and a buddy of mine changed out the front springs. Did away with the stock front springs and blocks and put a set of 2.5" front springs in her.
'67 K10 SWB
My Project
Old 01-18-2014, 09:36 PM   #32
swamp rat
swamp rat's Avatar
Keep at it, its starting to motivate me!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-18-2014, 11:19 PM   #33
JayB331
JayB331's Avatar
By the way, Go Seahawks!
'67 K10 SWB
My Project
Old 01-21-2014, 05:35 PM   #34
JayB331
JayB331's Avatar
Well, I found another unexpected issue with the motor. Most of my parts are in (still waiting on the cam and lifters) and I've finished painting the engine and detailing the engine compartment, so last night I checked the end play on my crankshaft and it's running .021" to .022". I thought about possibly putting in a .010" oversized thrust bearing, but that would leave me at .011" to .012", which is a little out of spec. I talked with the guys at Performance USA and they recommended against it, especially since I have a manual transmission. So they hooked me up with a local machine shop and I got a .020/.020 crank and a set of matching bearings for $140. I think I'm finally through spending money on the motor!
'67 K10 SWB
My Project
Old 01-21-2014, 07:33 PM   #35
swamp rat
swamp rat's Avatar
Good thing you checked the end play before putting it back together!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-23-2014, 09:27 AM   #36
JayB331
JayB331's Avatar
You got that right!
New crankshaft is installed. .006" end play. That's more like it!
'67 K10 SWB
My Project
Old 01-23-2014, 05:45 PM   #37
JayB331
JayB331's Avatar
I gave my headers to my buddy Jeff last week to get them ceramic coated. Just went by his shop and picked them up!
'67 K10 SWB
My Project
Old 01-23-2014, 07:33 PM   #38
swamp rat
swamp rat's Avatar
Plenty of assembly lube used after checking end play right?
The headers look sweet! I wish i had some buddies that worked in auto body right now.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-27-2014, 12:52 PM   #39
JayB331
JayB331's Avatar
Mocked up the motor yesterday, still waiting on the cam and lifters
'67 K10 SWB
My Project
Old 02-03-2014, 01:12 PM   #40
JayB331
JayB331's Avatar
Motor's back together. Gonna prime her up tonight. Plan on putting it back in tomorrow after work
'67 K10 SWB
My Project
Old 02-04-2014, 11:13 PM   #41
JayB331
JayB331's Avatar
Motor's back in. I'll be posting pics in the next couple of days. Plan on breaking in the cam Friday evening
'67 K10 SWB
My Project
Old 02-05-2014, 11:37 PM   #42
JayB331
JayB331's Avatar
Getting close!
'67 K10 SWB
My Project
Old 02-09-2014, 12:04 PM   #43
JayB331
JayB331's Avatar
Broke in the camshaft yesterday. Changed the break in oil, set the timing, and took her for a spin. Running like a champ! I get my hood back from the painter tomorrow evening.
'67 K10 SWB
My Project
Old 02-09-2014, 07:53 PM   #44
swamp rat
swamp rat's Avatar
Great news!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-09-2014, 09:19 PM   #45
JayB331
JayB331's Avatar
Thanks Rat! I understand you had some health issues. Hope everything is OK
'67 K10 SWB
My Project
Old 02-09-2014, 09:37 PM   #46
JayB331
JayB331's Avatar
I've been asked to help on a side project for my buddy David. He just purchased a '64 Malibu project for his wife. 54,000 miles, all original, 283 Powerglide. The car's been sitting for about 18 months. We got it running but are chasing a major vacuum leak, 10" at idle. Yeah I know, it's not a truck but it's a Chevy!
'67 K10 SWB
My Project
Old 02-18-2014, 09:04 AM   #47
JayB331
JayB331's Avatar
More engine pics
'67 K10 SWB
My Project
Old 03-15-2014, 07:28 PM   #48
JayB331
JayB331's Avatar
A few pics from the beach
'67 K10 SWB
My Project
Old 03-15-2014, 09:22 PM   #49
swamp rat
swamp rat's Avatar
Sweet!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-20-2014, 02:47 PM   #50
JayB331
JayB331's Avatar
Pic of my truck next to my buddy T-Dub's '62 Nova out at the beach a couple of nights ago
'67 K10 SWB
My Project
