Old 11-27-2013, 07:41 AM   #26
bigmac73
bigmac73's Avatar
Re: $2K for this engine? *time sensitive*
well if you are going to get a crate engine, get a 383 stroker, i kick my self in the ass for not spending an extra 600 bones and getting a 420HP 383, instead of the 355. but i am thinking about converting mine and adding a trick flow top end kit to it
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-27-2013, 09:09 AM   #27
cdowns
cdowns's Avatar
Originally Posted by GASoline71 View Post
Funny thing is... a 350 can be built for a tad under 2 grand and make 1hp per cubic inch or more.
Gary
funny thing is the engine section here is chuck full of posts about those type of engines being dead in 500 miles or less
Old 11-27-2013, 11:49 AM   #28
Jahloha
Jahloha's Avatar
I am so on the fence with the same dilemma...this is going to be a DD, but man, I read about and see 383s and think, "man I would like to feel that torque power off the line every once in awhile".
cdowns...I appreciate your insight. I have read your posts about not being pro-rebuilds. What crate engines have you had experience with or prefer?
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-27-2013, 12:34 PM   #29
bbcmudtruck
Thats completely the builders fault, not the engines! Good bearings, good machine work and knowing your tolerances and how to set them is critical. However a stout $2000 350 rebuild is completely doable, if YOUR capable.
bbcmudtruck is offline   Reply With Quote
Old 11-27-2013, 12:54 PM   #30
cdowns
cdowns's Avatar
cdowns...I appreciate your insight. I have read your posts about not being pro-rebuilds. What crate engines have you had experience with or prefer?[/QUOTE]
i've used a few of the GMPP crate engines 260 and 290 mostly// one time iwhen i was in a real time bind i got a turnkey 300hp setup from the engine factory// that was really nice just hooked up water gas and electric and it was great for a 2000 mile test drive the next day
Old 11-27-2013, 12:56 PM   #31
Jahloha
Jahloha's Avatar
I am an engine novice, if I do go crate engine, would you recommend a turn key? I can bolt things on and run belts, but never broken an new engine in.
-JASON
Old 11-27-2013, 01:24 PM   #32
sublime1996525
Engine break in is easy. This big thing is the initial fire to break in the cam. Just google cam break in and you'll see what to do. Pretty simple just make sure everything is ready and you have a way to gauge RPM's.
2006 Z06
2013 Cruze
sublime1996525 is offline   Reply With Quote
Old 11-27-2013, 01:32 PM   #33
Jahloha
Jahloha's Avatar
Thats good to know because I called Gus Paulos to see what theyd charge to install a Chevy crate engine (that way I can keep the warranty valid), and they said theyd charge $1850. Does that seem outrageous?
I have originally thought having that warranty would be nice, but adding an additional 2gs to the overall costs is killer.
-JASON
Old 11-27-2013, 01:41 PM   #34
sublime1996525
That sounds about right for a dealer. I don't think it has to be a Chevy dealer that does the install though for the warranty. Maybe you could clarify that and find it cheaper or see if they will let you do the install yourself and bring it to a dealer for inspection?
2006 Z06
2013 Cruze
Old 11-27-2013, 01:47 PM   #35
Jahloha
Jahloha's Avatar
Great idea. I forgot that I think I read that on our forum somewhere, about being able to possibly install and take to dealer for inspection. That would put their crate engines back onto my radar.
-JASON
Old 11-27-2013, 01:58 PM   #36
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
LMAO!
Just cuz it's a "crate engine with a warranty" makes no guarantee that it will survive any longer.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-27-2013, 11:34 PM   #37
CastIron
CastIron's Avatar
LMAO!
Gary
It's not a guarantee, but buying a crate engine certainly improves the odds of getting 100k+ miles without needing a rebuild.
I've installed dozens of new and remanufactured engines from GM. (I worked at a GM dealer for over 17 years) I've never had one come back for anything more serious than an oil leak.
CastIron is offline   Reply With Quote
Old 11-28-2013, 12:32 AM   #38
Jahloha
Jahloha's Avatar
Have a personal preference for any crate motors from GM?
-JASON
Old 12-03-2013, 01:35 PM   #39
Jahloha
Jahloha's Avatar
Bringing this one back up with an update, looks like I might be able to pick this engine up for 800-1000 bucks. It hasnt' been fired up for 2-3 years. If you were in my seat, what would you do?
-JASON
Old 12-03-2013, 01:56 PM   #40
Bigdav160
Bigdav160's Avatar
I'd buy it just to have it.
But I'm a hoarder
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-03-2013, 02:00 PM   #41
Jahloha
Jahloha's Avatar
But I figure, for 800-1000, thats the minimum I am at, to machine my current block and crappy 462624 heads, which we all know are crack prone.
I have never started an engine that has been sitting for a couple years, there has got to be some protocols prior to ignition...
-JASON
Old 12-03-2013, 02:01 PM   #42
litew8
litew8's Avatar
Get the owner to fire it up on site. Yeah, the gas is probably bad in the tank.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 12-03-2013, 02:02 PM   #43
Jahloha
Jahloha's Avatar
Anything to be nervous about, if the engine hasnt been fired for a couple years (i.e. oil, gas, etc)?
-JASON
Old 12-03-2013, 02:04 PM   #44
litew8
litew8's Avatar
IDK, I'd take the valve covers off and take a peak. If they say it ran before, should fire (starter fluid). Not sure what the condition the gasoline would be in tank though. Don't want to run it if there's junk build up from sitting. Besides that, you personally have nothing to lose by having the owner fire it up before you buy - if it isn't what they say, you'll notice. You've got to wonder why someone would be willing to let it go for so cheap. Either there's something the matter (not obvious), or they are just selling it for the quick cash. Either way I'd be cautious. If it isn't all setup ready to run - why not? You could probably substitute the gas tank by running the fuel pump to a gas can temporarily. If it's all connected ready to fire, but the owner refuses to do it... reconsider.
Old 12-03-2013, 02:47 PM   #45
67ChevyRedneck
67ChevyRedneck's Avatar
If he's gone from 2K to 800 that means no one else is interested and he's trying to unload it. I would still pass on it. Imagine all the time and effort to install it (and cost if you're paying someone) only to have it blow up on you after 50 or 500 miles and have to do it all over again.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
