12-16-2014, 01:35 AM | #26 |
Re: Project: Long Time Coming
was able to put in a msd pro billet distributor a little while back along with a mad digital 6al-2 control box and blaster 2 coil. she is running pretty well with all of that under the hood. too bad my modulator on my tranny needs to be replaced.
1972 Chevrolet swb fleet side. - SOLD 2018 Toyota Tacoma but hunting for another C10 Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303 Instagram: https://www.instagram.com/72c10shortbox/?hl=en |
02-02-2015, 12:55 AM | #27 |
so i traded my old brake parts with a local guy who trades in parts from our trucks and was able to get another set of bed inner fenders and another tailgate. while talking with him i found out that my truck is actually a highlander truck with the top option package. so I'm gonna try to restore her as much as i can but add a few goodies in the performance area.
07-12-2015, 02:27 PM | #28 |
so its been awhile since i have been online. but i have been on deployment for a few months and still have a bit to go. but waiting at home is my 72 and all the parts to swap in a tremec T56 6 sod
08-22-2015, 04:47 PM | #29 |
finally back from deployment. now i have a pallet worth of parts to install. going to be a fun time. ordered a Tremec T56 kit from american auto train, 1" bore master cylinder from wilwood, speed demon 650 carb, new steering column from LMC, lokar pedal assembly to go with the transmission, new wiring kit from american auto wire, plus a second set of fenders to tub the bed to fit 18x12's sometime in the near future and a spare tailgate to shave the handle off the tailgate. a few projects lined up for a good time and a whole new truck from a performance and driving stand point.
08-23-2015, 12:00 PM | #30 |
I tried and tried with my e brakes too turned out that my cables had rusted up inside and they wouldn't pull all the way in. They're pretty cheap and worth the insurance.
09-07-2015, 01:07 AM | #31 |
Yeah I'll be taking a second look at mine here soon as I can.
09-26-2015, 03:44 PM | #32 |
well its been a long time since i posted an update on my progress on the truck. Since i was last on here i have installed an MSD Pro Billet Distributor, Digital 6AL-2 control box, Blaster 2 Coil, Tremec T56 Magnum 6 speed manual Transmission courtesy of Hurst Driveline conversions and San Diego Driveline made my new Driveshaft for that, CPP tilt steering column to replace the factory column. lots of pictures to add and found out a lot about my truck that the previous owner helped to add more to my project with.
09-26-2015, 03:51 PM | #33 |
more pictures for everyone
09-26-2015, 03:56 PM | #34 |
thats all the pictures for now. i almost forgot the addition of a Wilwood 1"bore Master Cylinder. definitely brakes better now. next up on the list is to swap all the factory gauges for Autometer Sport comp gauges
11-02-2015, 01:04 PM | #35 |
Looking good and welcome to the PNW.
JD Builder Modifier |
11-07-2015, 11:54 PM | #36 | |
Where did you get the brake and clutch pedals? they look really good!
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
11-08-2015, 10:02 AM | #37 |
So a little warning on the shifter location. We discovered that my motor is mounted in the big block mounting location so it should be 2-3 inches further back. But it will still clear. Plus there are 3 mounting locations for the shifter. I am using the normal location just with the shifter plate rotated 180° which it comes with the ability to do. There is also a mid point it can be mounted to but requires a different shifter plate. Easy swap though. The pedals are lokar direct replacement pedals. I like them alot. They also make a matching throttle pedal that is a factory replacement.
11-08-2015, 12:07 PM | #38 |
Cool build man. Nice looking truck
67 C20 to K20 Conversion 283 SM465 See my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=687765 |
11-08-2015, 04:09 PM | #39 |
Thanks. Still has a ways to go but she is coming along nicely. And I love driving her to work everyday.
11-16-2015, 08:53 PM | #40 |
made a final decision on gauges and wheels. gonna get a full set of auto meter ultralite gauges and then 20x8 and 20x9.5 us mags rambler u111 with 245's in front and 285 or 295s out back.
12-05-2015, 12:51 AM | #41 |
got some new tires put on today. feels a lot better. hopefully tomoro i can get my custom license plate bracket wired up and installed and post a couple of pictures of that.
12-05-2015, 01:34 AM | #42 |
nice truck
looking forward to pics
'68 C10 SWB '85 K30 Blazer |
12-21-2015, 01:02 AM | #43 |
thanks. hopefully ill be able to get some things done soon and post some pictures.
04-26-2016, 12:23 PM | #44 |
any updates?
04-26-2016, 08:44 PM | #45 |
i just added a custom license plate bracket. and I'm in the process of making an auto meter gauge cluster. i bought a few products from Delcity.net so that i can have one 12 pin connector for all of the dash electrical. also got some 2 and 3 pin connectors for the side makers and headlights and tail lights. the gages in the pictures are from beelzeburbs build. I'm using the same gauges but with a 200mph speedo. also put in a lokar gas pedal to match the clutch and brake pedal.
04-26-2016, 08:58 PM | #46 |
great looking truck. always loved these in white.
04-26-2016, 09:52 PM | #47 |
Do you have a link to the 12 pin connector you are going to use?
04-26-2016, 10:49 PM | #48 |
Yea, I want that too!
04-26-2016, 11:10 PM | #49 |
ok so here is the link for the 12 pin connector. its from a website called del city.net. they have a lot of great stuff to clean up and customize your wiring setup. be warned though to make the 12 pin connector you need both the male and female sides, male and female contacts, plus the wedges for both. so depending on how much you get it can get pricy. but i think its totally worth it in my book. ill make sure to take lots of pictures during the install. they have a few different styles of connectors. i got lucky and was able to borrow a very nice crimper from an electrician buddy to crimp my contacts for the plug.
and thanks farmyard. she has seen better days but the white has grown on me. http://www.delcity.net/store/AT-Seri...0.h_797548.t_1
05-23-2016, 12:30 AM | #50 |
Finally my Grant Challenger GT steering wheel came in. been waiting a few months now for it. I think that it looks pretty good.
