Old 01-02-2014, 11:12 AM   #26
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: 1970 c10 LSX 427 twin turbo setup
Nice setup.
13xx hp at the wheels? Damn. I need an LSx block and some 6 bolt heads...
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-02-2014, 06:30 PM   #27
rgonza
Originally Posted by 69trk View Post
Looks like you kept the coil packs on the valve covers... Did you just custom make some plug wires andgo around the manifolds?
Yes, it's a custom make cables, because i'm using a Katech coil bracket set the OEM wire are to short to reach the spark plugs there're about 2" more longer than factories does, the wire set are Taylor 10.4 with ls coil ends.
Cheers
Rob
rgonza is offline   Reply With Quote
Old 01-02-2014, 08:46 PM   #28
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by Wasted Income View Post
Nice setup.
Naw ya don't. Just the heads....and if you REALLY wanted to I may know someone that has a very nice friend at MAST that can track down their 6bolt heads. I feel you don't need a new block till you blow on a hole in the one you got....and with an gmpp LSX block, you'll blow a hole in the block sooner than you'd like heheh.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-02-2014, 10:59 PM   #29
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
really? I thought the GMPP LSX Bowtie block was a sturdy piece...rated for like 2000+hp? No?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-03-2014, 10:22 AM   #30
Wasted Income
Boosted Member
I'd be curious how you'd propose bolting a set of 6-bolt heads on an LQ4?
Unless you're talking about a Bill Mitchell or a Warhawk block...in which case I'd still rather have the LSx for less than half the price
Turbo diesel
Old 01-03-2014, 03:34 PM   #31
rgonza
yes, Thompson engineering already did 2000 hp + on their set up , Twin Turbo t88 388 LSX block.
Old 01-03-2014, 03:39 PM   #32
rgonza
There're few ls block manufacturers that they make 6 bolts heads compatible.
GMPP
RHS
Warhakk, but need to buy the head to then, because of bolt pattern is different from GMPP LSX.
Old 01-03-2014, 03:46 PM   #33
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Wasted - There are some companies that do 6 bolt conversions but I know 90% of them want the aluminum block to start with. BUT just better heads in general could get you pretty far with some creativity. I'm pretty sure you could go up to 1/2" studs and 0-ring the block and prevent lifting enough to get you there. And maybe its just me, but after reading 20 pages of BS on the lsx blocks over on YellowBullet, I don't know if I want one. Tho the world blocks have been accused of issues as well.
Old 01-03-2014, 04:03 PM   #34
rgonza
All depend of your application, in my application i broke two lq9 blocks with 1/2" stud and o rings on cylinders at 25 pounds of boost, i run the lsx with the same boost pressure without any issue in a year and it are not O ringed yet. in my experience is good product for the money.
Old 12-11-2014, 06:26 PM   #35
rgonza
New Wheels
