01-30-2014, 09:36 AM | #26 |
Registered Truck Offender
Re: 400/406 Builds
Nick, I saw a set of cnc ported 186 casting camelhumps that were built for a friends small cubic inch dragboat went 218/137 @ .6" lift on a Superflo SF600 bench. That was with some spec they had to live by limiting the port to (best my memory recalls) at 165 or 170cc (something like that),, where they start at mid 150ish cc in stock, as cast form. I remember Roger saying some of the castings they started with went almost 200cfm as cast, but the sloppy casting and inaccurate means of the day,, the #'s were all over the place.
I've seen some of the reports around the net that they got 461's and such up to 260-270cfm with ultra secrete trick cnc programs,, but I've never seen anything but 'internet' claim those numbers. In short I'm not trying to bash anyones machinist or build, just saying a 400 inch motor is BIG cubic inches and using a head designed for 327 inches should in it's self offer some thought of it's limitations.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
01-30-2014, 09:47 AM | #27 |
Re: 400/406 Builds
Ty Marv, I'm not looking for an all-out racer just around 450 would be nice and I am definitely considering new heads like the Capt has advised. Looking at AFR 190.
01-30-2014, 10:54 AM | #28 |
Re: 400/406 Builds
World Products Sportsman II's are good heads as well. You will have to have the steam holes drilled.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
01-31-2014, 01:57 AM | #29 | |
60-66 Nut
Re: 400/406 Builds
Which Comp extreme 4x4 cam did you use?
01-31-2014, 01:12 PM | #30 |
Re: 400/406 Builds
I bought a 64 C10 last fall with a 400/406 small block. The engine started as a 400 4-bolt main small block; 10.2-1 compression, 292 comp cam, roller rockers on top, Edelbrock aluminum heads, Edelbrock RPM intake, Holley 750 carb with hooker headers. I only put about 50 miles on the truck before I tore the truck apart, but it "screamed" down the road. I plan on taking taking the oil pan, valve covers and timing cover off to make sure everything looks "ok" before I re-gasket everything. I plan on taking it to a engine dyno to see what type of power it makes and fine tune it before I drop it back into my truck this spring. The previous owner claimed it was around 500 Hp at the crank, so I will be surprised to see what it actually makes on the dyno. It runs ok on pump gas, but it ran much better on 100 octane.........
Dan |
02-01-2014, 01:16 AM | #31 | |
60-66 Nut
Re: 400/406 Builds
Which Edelbrock heads are on your engine?
02-01-2014, 05:30 AM | #32 |
Re: 400/406 Builds
If I remember right there were a couple choices back then and I went with the 1st selection. I would have to look up the specs as I kept all the paperwork.
I figured it wouldn't see much high rpm usage so a good lope was not going to be a good thing rock crawling. Then I moved to flatlands.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-01-2014, 10:45 PM | #33 |
Re: 400/406 Builds
The heads are Edelbrock performer 60739
02-02-2014, 12:31 AM | #34 |
60-66 Nut
Re: 400/406 Builds
Thanks for that info.
So those Performer RPM heads have 170cc intake ports and 70cc combustion chambers with 2.02/1.60 valves.
02-03-2014, 01:16 PM | #35 |
Re: 400/406 Builds
Captainfab,
I need to change the rear-end in my 64 truck with a new one due to 50 years of wear. I found a 1969 complete rear-end with 3.07 gears; with my engine set-up I posted do you think I will loose too much low end torque going from 3.73 to 3.07's? |
02-03-2014, 05:01 PM | #36 |
60-66 Nut
Re: 400/406 Builds
That depends partly on what trans you are running and what size tires. The 400/406's typically make good torque, but with the cam that is in yours, your low end torque may be down a little, as compared with a milder cam.
02-03-2014, 05:23 PM | #37 |
Re: 400/406 Builds
Turbo 400 with a 3000 stall convertor; tire size will be around 225/70-15 or close to that size for the rear
02-04-2014, 12:02 AM | #38 |
60-66 Nut
Re: 400/406 Builds
I don't have any personal experience with a 406 with a 292 cam, but I think there is a possibility that the 3.07 gears may be just a little too high for that combo. They may work out, but if I were to choose, I would go with 3.42 gears with that engine and trans combo. I doubt you'll be getting much traction with those skinny tires.
02-06-2014, 12:34 AM | #39 |
Re: 400/406 Builds
I have what is supposed to be a rebuilt 400 stock bore, but a non-stock cam (which I haven't got to verify yet). I do have 2 sets of heads. Stock vortec or Twisted wedge gen1.
Which truck gets the engine will determine the cam, heads, and intake used, and whether I use the 800 holley spreadbore or a modified Qjet. I'm guessing if it goes into my '94 K1500 - I'll either need a 9.5" sf six lug rear or weld the tubes and beef my 10 bolt , but the PO left the 231 tc in it when he changed to a carb'd 350 and a NV4500. Is the NP231 pretty weak ?( too weak for my 350 also ?) |
02-06-2014, 02:28 AM | #40 |
60-66 Nut
Re: 400/406 Builds
I don't know much about the strength of the NP231, but typically if you step up to larger than stock tires, and or lower gears, is when you find your weak links. What is your intended use of the '94 K1500?
02-06-2014, 03:25 AM | #41 | |
Re: 400/406 Builds
No mudding, just street and snow playing , off-roading may be a crawl thru the woods or pasture. It has 33's and the stock 3.73's. |
02-06-2014, 02:14 PM | #42 |
Re: 400/406 Builds
....good point to Manimals comments about the steam holes.
It was my understanding too that any heads used on the 400 sbc's had to have the mating steam holes (special siamezed bores) in them to keep the engine from overheating. Is this not required? Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
02-07-2014, 01:34 AM | #43 | |
60-66 Nut
Re: 400/406 Builds
With 33's and 3.73's, there shouldn't be too much extra strain on the trans TC from that end. But if you do put that 400 in this truck, that will be some extra torque on the input side. I would suggest posting a question about the NP231 over in the Offroad and 4x4 section.
02-07-2014, 02:51 AM | #44 | |
Re: 400/406 Builds
02-18-2014, 04:29 PM | #45 |
Re: 400/406 Builds
Ok finally got the specs.
406 4 bolt gm crank and rods balanced KB flat tops 10.5 1 NEW DART 200 cc SHp mildly ported 64 cc comp cam hydraulic roller 523 lift 519 exhaust Comp 1.6 roller rockers air gap Holley 850dp full headers 373 gears posi 350 3 speed Whatta you think? |
02-18-2014, 08:22 PM | #46 |
Re: 400/406 Builds
With the proper piston to deck height you'll have closer to 11.7 - 1 compression , a 76cc chamber would be perfect with flattops.
The 850 holley isn't a good street carb for anything smaller than a 454 , and not great then either . A Holley 780/750 vacuum carb or a 750 or 800 tuned-up Qjet (first choice), even an 800dp or an 830dp holley carbs will be more responsive. Better yet the Demon high-end carbs are better than all but the very newest and best Holleys. What is the cam's .050 duration ? Last edited by 68post; 02-18-2014 at 08:27 PM. |
02-18-2014, 09:35 PM | #47 | |
Re: 400/406 Builds
02-19-2014, 12:01 AM | #48 |
60-66 Nut
Re: 400/406 Builds
IMO you still have too much compression for pump gas. And now you have way too big of a carb. But you said your machinist is well respected and a friend of yours, so I won't say any more.
02-19-2014, 05:25 AM | #49 | |
Re: 400/406 Builds
I like it. I have one that is close to yours but with a comp solid lifter cam. Same KB's. 64 cc camber Dart Iron Eagle, rpm air gap and a 750 holley. Last edited by northern; 02-19-2014 at 05:27 AM. Reason: spelling |
02-19-2014, 05:29 AM | #50 |
Re: 400/406 Builds
yes my mechanic has two to three different carbs that he will try out and see which is best for the motor and for the street. How is your motor on the street? plenty of power? Did you run any times at the track?
