Old 10-14-2015, 07:40 PM   #26
Bocephus69
Re: Back to the Basics: Rebuilding a steering coupler rag joint
thanks for the write up. i was just at napa today looking for this rubber coupler. they didnt show an application in their book for a 69 c10, but they had a universal kit that "works for most." well, you know how that goes. i figured i would take it home and at least see if it is remotely the same. it appears to be the same kit you used.....so defying the odds, it should work haha!
69 C10 fleetside long bed - 6.0/4l80E in progress
Bocephus69 is offline   Reply With Quote
Old 09-14-2017, 09:50 AM   #27
stevenbear72
stevenbear72's Avatar
good info, thanks
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 10-23-2017, 03:29 PM   #28
Droff
Any chance on getting the pics reposted? I can't see any of them, I'm guessing due to photobucket.
Thanks.
Droff is offline   Reply With Quote
Old 10-24-2017, 11:46 AM   #29
65 C20
Thanks.
I haven't seen Tx Firefighter on here for awhile.
I just went down and got a Dorman #31015 and it worked for me.
Not too expensive.
Remember that they only fit the spline one way.
I had to wedge the coupler out a little to fit the shaft.
65 C20 is offline   Reply With Quote
Old 06-18-2022, 05:18 PM   #30
Goose
Goose
Goose's Avatar
Thanks for your demonstration. I'm about to start this project on my '72. The thing that escapes me is the steering column. What did you do to your steering column to get enough room to remove the rag joint? Thanks for any help.
'72 GMC short-step 350/350
Goose is offline   Reply With Quote
Old 06-23-2022, 10:51 AM   #31
68 P.O.S.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 09-17-2022, 04:57 PM   #32
Richard2112
Richard2112's Avatar
This has been an excellent read which has helped me while installing my rag and steering gear. (in process)
There are two things I'm uncertain about though; One is the sort of twisted metal bracket called the capture strap. I'm not sure of the purpose of that.
The other thing I'm not sure of is why there are two different sized bolts that hold the lower steering shaft to the coupler/rag joint. It appears the shoulders on those bolts are the same size but the threaded portion is different.
The lower steering shaft will only bolt on one way to the coupler but (and I could be mistaken here) the top of the shaft seems like it's just splined and could go on in any orientation.
Richard2112 is offline   Reply With Quote
