Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 07-18-2014, 12:58 AM   #26
litew8
litew8's Avatar
Re: Aluminum intake cleaning? Any options
Originally Posted by CST10 View Post
Will the al cleaner mess up the engine block paint?
Yes
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 07-19-2014, 11:50 PM   #27
CST10
CST10's Avatar
Thanks for that info. Someone told me to use a wore brush and lightly scrub the intake and not the painted block. Anyone do this before?
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 07-20-2014, 12:16 AM   #28
69chevytrucker
69chevytrucker's Avatar
product called super clean comes in a purple bottle spray it leave it for 20 min then wash it off good cause it will eat the aluminum fast i put some in a spray gun and the next day the pot crumbled to dust in my hands
69chevytrucker is offline   Reply With Quote
Old 07-20-2014, 12:25 AM   #29
litew8
litew8's Avatar
You could probably get away with spraying some of that al or oven cleaner into a small cup or container. Then use an old toothbrush to dip into it and apply to the intake with little action (scrubbing) then rinsing with hose etc... not long after (before it dries). Repeat until done.
Old 09-08-2014, 08:54 PM   #30
CST10
CST10's Avatar
That's a good idea to try. That way it doesn't get on the painted surfaces. I used a wire brush lightly and it worked pretty good, just took a while to do it. I should have high temp coated clear that sucker when it was built.
MyToys:
Old 09-25-2014, 03:18 AM   #31
full foot notch
have you tried soda blasting
full foot notch is offline   Reply With Quote
Old 01-17-2015, 12:15 AM   #32
CST10
CST10's Avatar
No I haven't. Does it work?
MyToys:
Old 01-17-2015, 11:48 AM   #33
piecesparts
Parts and more parts
piecesparts's Avatar
Air conditioner coil cleaner works well, spray on and hose off. It is a citric acid base for cleaning aluminum.
Frank
piecesparts is offline   Reply With Quote
Old 01-17-2015, 12:39 PM   #34
CST10
CST10's Avatar
Thanks. I guess you can buy that coil cleaner at an ac shop?
MyToys:
Old 01-20-2015, 02:46 PM   #35
Marv D
Registered Truck Offender
Marv D's Avatar
@ Ace hardware. It works pretty good but RINSE IT OFF AS DIRECTED.
I left it on a intake and forgot about it,, it turned it chalky white.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-20-2015, 03:19 PM   #36
motorcritter
motorcritter's Avatar
The Purple Power can discolour the surface if not removed quickly. The citrus cleaner is a good choice, and it makes a great cooling system cleaner.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 01-22-2015, 01:50 PM   #37
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
"Marine Clean" from POR-15... amazing stuff.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-25-2015, 02:04 PM   #38
CST10
CST10's Avatar
Marine clean, gotta be better than a smal wire brush I just used. Gunna have to find some.
MyToys:
Old 06-01-2015, 01:41 AM   #39
scotts72heavyhalf
scotts72heavyhalf's Avatar
I used a bead blast cabinet with aluminum oxide then clear alodine which most part stores carry to seal the finish, you just spray it on the wash it with cold water and let dry, its amazing that was a old yellow colored and dirty manifold from another project just a few days ago.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
