Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-11-2014, 11:11 AM   #26
TheBlueBomber
TheBlueBomber's Avatar
Re: Twin turbo 5.3?
Wasted that turbo you used is huge! I'm concerned about the leaf suspension I have now but don't really want to go 2wd... granted that may be my only option if I want to go fast and take a corner.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 02-11-2014, 11:51 AM   #27
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: Twin turbo 5.3?
You aren't going to go fast and take a corner in a 4wd truck. You might be better off finding a 2wd truck and going from there. If your body is in good shape you could just do a body swap.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 02-15-2014, 06:51 PM   #28
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Twin turbo 5.3?
...AND you want it to turn? Picky picky. In my day a man would have been happy with either going fast OR turning....now they want both.
He's right in a sense. Tall sidewall tires, leaf springs, high center of gravity and extra unsprung mass...don't really add up to cornering.
Now a 2wd truck with a 3/4link or trailing arms,and a good wheel/tire combo, that will turn. Take a look at the Ridetech and Holley trucks....I have pictures of them from the road course on the Optima Challenge. They can turn.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-16-2014, 01:26 AM   #29
TheBlueBomber
Re: Twin turbo 5.3?
Yea I'm the kind of person who knows what he wants and won't stop till he gets it. I just need to figure out what I want.
My import friends keep trying to persuade me into building a mean car... but something keeps pulling me back to the trucks.
I've got a little time to think about suspension. The 5.3 is a the house on the stand as of Friday afternoon. Should have some time tomorrow morning to start digging in.
Austin
Old 02-16-2014, 03:11 AM   #30
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Twin turbo 5.3?
Hahah, import guys don't really gave a good truck option, so they have bed envy.
I will say that a good balance will get you a truck that your plenty happy with. If you can keep your goals in check, then you can probably end up with a pretty sweet setup; what I mean by that is... If you build a good turbo engine (but hold back from building a MONSTER), then you can also usually dial in suspension, braking and weight.
With the amount of weight you have to carry, finding a way to upgrade AND save weight might really benefit you. Switching to disks all the way around does both well, as does going to a nice aluminum bodied shock (my qa1's changed the way my truck rides 30%+). Might even be worth thinking about a tubular k member too, if there is one that suits the 4x4 well, I'm not 100% sure on that one. Its a slightly different caliber, but I've seen some very interesting concepts for weight savings (and LS truck power) at the KOH the last few years.
Old 02-16-2014, 03:08 PM   #31
TheBlueBomber
Re: Twin turbo 5.3?
True that. I definitely want to go upgrade the disks in the front and swap disks in the rear. Just need to figure out which ones will work best with the rims I have.
Austin
Old 02-16-2014, 08:39 PM   #32
Mr. 250r
Mr. 250r's Avatar
Re: Twin turbo 5.3?
Look up screamin semen on youtube he has a nice turbo'd 5.3 as far as the gas tank why not a 87 FI tank just use the old sending unit with a new pump that plugs into the wiring harness that's what i did for my suburban using my 91 tank
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 02-23-2014, 03:51 AM   #33
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Twin turbo 5.3?
I can confidently tell you that I have no desire to see what the internet yields to those search terms.
Old 03-05-2014, 07:03 PM   #34
TheBlueBomber
Re: Twin turbo 5.3?
6.5 turbo diesel 4x4 dually... unknown miles... old man truck and the owner passed away... Transmission 4l80e...
$350
Should I get it? All of the 4l80es that are ls transmissions are going for $1000+ so If I can get this one itll be a win. My buddy says monster transmission sells build 60e's but yall are swearing by the 80s.
Austin
Old 03-05-2014, 07:39 PM   #35
TheBlueBomber
Re: Twin turbo 5.3?
I think I answered my own question with this http://ls1tech.com/forums/automatic-...otor-help.html
So now I'm down to, If the transmission seems to be A OK is there any advantages between this versus an ls 80e?
Austin
Old 03-05-2014, 07:45 PM   #36
TheBlueBomber
Re: Twin turbo 5.3?
And so I'm guessing with the flywheel, spacer, and bolts I will be able to run this 80e
Austin
Old 03-05-2014, 09:08 PM   #37
79 big block
Re: Twin turbo 5.3?
Yes you will, the early 6.0 used the 4l80e that had been used on the non ls motors. Hence the spacer to properly engage the torque converter hub.
79 big block is offline   Reply With Quote
Old 03-05-2014, 10:36 PM   #38
TheBlueBomber
Re: Twin turbo 5.3?
Sweet!! I'll pull the pan and look it over and if my buddy (who does R&R on transmissions) says it's cool ill pick it up!
I was concerned because it's in a 6.5 dually but I have to keep reminding myself... they're all HD work transmissions lol.
Austin
