Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-22-2014, 03:08 PM   #26
Flat 67
Junior Member
Flat 67's Avatar
Re: 1971 C50 Swap Project
Originally Posted by flashed View Post
That was quick ,I like it .
Flashed
Actually it took several months to do this. I just wanted to post what I had done. It also took me a long time to find my pics. They were in different phones and cameras.
Flat 67
Flat 67 is offline   Reply With Quote
Old 02-22-2014, 05:09 PM   #27
flashed
Oh ,OK ,youre a tricky rascal ,but I still like your truck .What you doing to it next ,staying tuned in.
flashed is offline   Reply With Quote
Old 03-06-2014, 11:01 AM   #28
Mater/10
Mater/10's Avatar
This is an awesome swap bud! helps me with my c50 frame swap! how different are the cab and core mounts?
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline   Reply With Quote
Old 03-06-2014, 04:15 PM   #29
Flat 67
Junior Member
Flat 67's Avatar
Mater,
That was interesting part about this swap, there was NO difference. It bolted right in. I was so surprised.
Flat 67
Old 03-06-2014, 06:43 PM   #30
mrolds88
Originally Posted by Flat 67 View Post
Mater,
Flat 67
HMMMMMM> Gives me a possible new avenue for my 70 that has a rusty cab, fenders, running boards, grille....You get the point! LOL
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-07-2014, 02:26 PM   #31
rkn463
rkn463's Avatar
Mater,
Flat 67
That is great news. I'm going to be swapping my 68 C50 cab onto an 89 C60 frame, that will get me better gears, 2 sped rear, power steering and 4 wheel disk hydro-boost brakes. I had done some initial measurements and thought it looked like it was going to fit but I was afraid t was too good to be true. I've about decided to go with the 366 that is in the 89 rather than keeping the 327 and having to fab up all of the brackets. One problem with that is my 89 has a huge radiator so I was wondering if you swapped rads and if so did you have much trouble with that? Also, how much fab work was involved in mounting the air brake controller (?? Don't know what to call it) to the firewall?
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 03-07-2014, 03:21 PM   #32
Flat 67
Junior Member
Flat 67's Avatar
-Richard
Richard, I'm going to try to answer all your questions. First of all, there was a body change in 89 with the med duty trucks. Is yours the 73-88 version or the 89 and beyond. 89 was the transition year. If it is the 89 and beyond version I am not familiar with the body mounts. As you can see in post #22, I used the smaller stock radiator of my 71. I figure I would not be hauling much and that it should be cool enough. If it became a cooling problem I would get a bigger one that would fit the space I had. The air brake controller, to my surprise again, it bolted right in with the same 2 bolts that held the M/C. Granted there were a bunch of airlines to deal with.
Hope all this helps, you have good questions.When I started my project I had no one to go to, so I am more than happy to help.
Flat 67
Old 03-07-2014, 07:08 PM   #33
rkn463
rkn463's Avatar
Flat 67
Thanks for the info. Fortunately my 89 is still the old "square" body style like your donor truck so I should be good with the body swap. Now I know that I can do that part I have the confidence to just do it and then deal with the unknowns like the radiator. I'll also have to deal with a too wide front axle. I'm hopeful that the two will have the same size kingpins and steering knuckles allowing me to use the old axle with the new running gear. I'll get a build thread going one of these days.
Thanks for sharing your build with us, I love your project.
-Richard
