Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Closed Thread
Old 09-06-2014, 03:38 AM   #26
68c10owner
68c10owner's Avatar
Re: HD relay conversion headlight harness available!
Since I`m fairly new to this sort of thing, does this kit make the lights brighter? My 97 GMC`s lights are so dim at night its scary. I do need to polish out the lenses but still could be brighter. Is there anything else I would need to do? Just unplug the OEM harness and plug this in? How long does it take to install? Need any special tools?
Anthony
68c10owner is offline
Old 09-06-2014, 08:49 AM   #27
w314speed
Thanks for the education on the upgrades that you offer and where my problem is. Thanks, Dan
w314speed is offline
Old 09-06-2014, 02:53 PM   #28
gmachinz
Polishing the lenses or replacing them altogether is priority #1. Then, if you still feel they aren't bright enough, the relay kit is designed to splice into your existing harness with NEW plugs and a sealed fuse holder-I've tried the Chinese "ceramic" plugs and they are on the same quality control level as dried toothpaste so I use GM Delphi OEM style thermoplastic plugs with oversized terminals and wiring-something you can't get with "ceramic-toothpaste" plugs, either.
This kit is designed to splice into your headlight wiring (lt green/tan) and no special tools are needed except for a crimper and/or a soldering iron. I can supply a full front lighting replacement harness from the firewall forward as well-pricing depends on year. PM for more details on full harnesses.
gmachinz is offline
Old 09-19-2014, 09:31 PM   #29
99'Subourbon
PM Sent.
Thanks!
99'Subourbon is offline
Old 09-29-2014, 04:06 PM   #30
RATFOOD
Pmd!
RATFOOD is offline
Old 09-29-2014, 04:14 PM   #31
gmachinz
Cool-PM'd you back!
gmachinz is offline
Old 10-03-2014, 04:40 PM   #32
sctrailrider
sctrailrider's Avatar
Received my set a few days ago, not installed yet, they are very well made and will be great when I get them installed..
1993 Chevy K3500 CCDRW
Coming soon, frame off resto, Cummins 6bt swap.
sctrailrider is offline
Old 10-06-2014, 02:17 PM   #33
jrsavoie
I am finally ready to order. At this time I can only afford 2 sets. I need one for the 1994 K3500 6.5 diesel and one for the 1998 K2500 6.5 diesel Suburban. so they need to mount on the drivers / right side.
As stated I would like to able to plug into the headlight harness the way that Baron's harness did.
IIRC you unplugged the headlight and plugged that connector into his harness to trigger the relays.
If you could duplicate Baron's harness with longer ground wires - or just one ground wire to go to the battery. - I didn't quite understand why he had 2 incredibly short ground wires, instead of tying them together to run back to the battery - to match the length of the hot wire or longer with 3/8 eyelets and your mountable relay sockets it would be good.
98 GMC Suburban 2500 6.5 4x4 235,000 mi, FS2500, 96 GMC 6.5 Suburban 1500 4x4 280,000 mi; Amsoil 95 Tahoe 2 door 4x4 6.5 280,000 mi; 91 international 4700 low pro, spicer 6 speed, DTA 360 with 18' van box 500,000 miles plus.1994 chev K3500 crew cab SRW 5 speed 4x4 245,000
jrsavoie is offline
Old 10-07-2014, 01:14 PM   #34
jrsavoie
How does your harness deal with daytime running lights?
The LMC harness says not to use with DRL's
jrsavoie is offline
Old 10-13-2014, 06:58 PM   #35
99'Subourbon
His, as well as LMC's (and just about anyone else's) use a relay to draw power from the battery to feed to your lights, as opposed to your light switch. Your light switch will now just act as the trigger for the relay.
That said, DRLs are simply a low power feed to either your low beams or your high beams (depending on vehicle), when your light switch is turned off. When you install and HD harness on a vehicle with DRLs, the low power feed is now being pulled from the battery, becoming a full power feed which in turn makes for full brightness DRLs.
Because the HD harnesses don't vary much in how they operate, and are pretty universal to all vehicles, they state not to use it with DRLs because those vehicles who use the high beams on lower power for the DRLs, will now be shining high beams on high power at all times...
This is my understanding of how it works, anyways.
Old 10-13-2014, 07:00 PM   #36
99'Subourbon
Oh, and the solution? Simply remove your DRL-FOG fuse. Usually found in the convenience fuse panel, location between the door and the dash, by steering column.
Old 10-13-2014, 07:13 PM   #37
jrsavoie
thanks
jrsavoie is offline
Old 10-16-2014, 03:47 PM   #38
stratosurfer
Originally Posted by gmachinz View Post
Ok...finally got my attachments to work. My harness includes flame retardant corrugated loom, replacement rosebud wire loom retainers, MIDI 40A fuse holder and fuse as well as HD relays mounted in mountable relay bases-this dual relay setup is equipped with the 4HI option as well and is diode protected against voltage spiking. You can see the difference between OEM 18 gauge leads and the Delphi SXL 14 gauge supply leads.
I would like to order a harness for a 98 Burb LT 6.5. I just got privileges on this board so I'm not sure I can p-mail...
Could you pmail me or email at markmagee.tx@gmail.com with instructions to order the harness?
Mark
stratosurfer is offline
Old 10-17-2014, 07:12 PM   #39
RATFOOD
Well, I have received the harness and it looks great, thanks! I do have a question about installation. The tags say "to tan/lt green from firewall harness". Where are these wires that I need to attach to? Are they the ones both running to the light switch in my dash? Am I cutting them off and attaching to them or am I leaving the current ones attached and just splicing into them? Sorry, I never messed with any light harness before..
Thanks again!!!
RATFOOD is offline
Old 10-17-2014, 08:01 PM   #40
gmachinz
PM sent! Glad you like the harness! In your case, best route is to replace your existing harness with the one I provided you with.
gmachinz is offline
Old 11-17-2014, 10:45 PM   #41
Metal
Metal's Avatar
Any available???
"If at first you don't succeed use more duct tape" Red Green....
Danger --if you meet it promptly and without flinching -- you will reduce the danger by half. Never run away from anything. Never!
-Winston Churchill
A few of my holsters.............
Metal is offline
Old 02-16-2015, 02:01 PM   #42
gmachinz
I have several types available as well as custom built harnesses-this one is for a member who also opted for a 3rd relay for aux. lighting at his discretion. This kit features a 4-HI adapter plug-in which is designed to add to give 4-HI operation BUT, if for some reason you don't need or want it later, you can simply unplug it and the low/highs return to normal operation.
If anyone has specific requirements for a HD headlight kit, PM me for details-I can integrate nearly anything for custom lighting.
gmachinz is offline
Old 03-17-2015, 02:12 AM   #43
gmachinz
Ok, good news! My adapter connectors that were on backorder came in and I'm shipping out a few harnesses in the morning! If anybody wants a plug n play kit, shoot me a PM! These plug into your existing headlight connectors, provide 4-HI relay power for lows and highs using (2) 40A relays and can be installed on either side of the engine bay.
This kit uses HD Delphi terminals, ringlets as well as flame/heat resistant OEM style wire loom with rosebud clips included for a factory style install!
gmachinz is offline
Old 03-18-2015, 07:43 PM   #44
gmachinz
Here's a pic showing the difference between the stock headlight connector- 18ga crimped OEM style and mine with 14ga wiring and soldered connection.
gmachinz is offline
Old 03-24-2015, 12:58 PM   #45
gmachinz
I'm building a couple kits for members this week-if anybody wants to get into the build rotation, PM me with what you need/want! I can build to suit if you have something specific in mind-extra running lights, aftermarket fogs, etc.
gmachinz is offline
Old 03-24-2015, 10:11 PM   #46
stratosurfer
I bought the harness awhile back and just now am able to get to install it. Do you have downloadable instructions for the install?
Mark
Old 03-25-2015, 12:59 PM   #47
gmachinz
Everything should be labelled but yes, PM me your email and I can forward an attachment to you!
gmachinz is offline
Old 05-12-2015, 11:40 AM   #48
gmachinz
So far I'm up to date on these kits shipping out-thanks to everyone so far for the support!
gmachinz is offline
Old 09-28-2015, 10:46 PM   #49
csx7006
Are you still making these? Do they come with instructions?
csx7006 is offline
Old 09-29-2015, 06:47 AM   #50
gmachinz
Yes I do-I make them for pretty much every year. I include new Packard 59-series terminals and can provide bulkhead out harnesses. Wires are All color coded and labelled using only US materials! These are NOT your typical EBay kits-you won't be disappointed! PM for details. Thanks!
gmachinz is offline
Closed Thread
