Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 10-06-2014, 06:55 PM   #26
Ulysses
Re: New: Porterbuilt Inner Frame Structure
Originally Posted by Pro Performance View Post
Ulysses
Yes, this frame structure will work using a static drop to laying the frame on the ground.
- Travis
Travis,
I was under the impression that a two piece drive shaft was needed to make this work without angles that are going to hit something. I would also like to be convinced that I want to replace to upper and lower tubular control arms. Would there be a huge inprovement in steering and cornering with a static 4/6- 5/7 that it would be worth it for me. Im on the fence of going tight suspension with motor build or air ride and mild build.
We need to eventually talk because I spend a lot of time on AZperformance.
Thank You
Ulysses
Ulysses is offline
Old 10-07-2014, 10:45 AM   #27
Pro Performance
Pro Performance's Avatar
Ulysses,
Feel free to call anytime.
They do have a 1-piece driveshaft version now. In regards to the arms, I think you would see an improvement in the performance. On static drops, we usually recommend going with a 1" forward lower, and a standard upper. This will put more caster into the front geometry, which will improve the steering feel and performance.
- Travis
Pro Performance is offline
Old 12-24-2014, 12:32 PM   #28
GoaterAz
GoaterAz's Avatar
Thank you, Travis!
There aren't very many pictures of this top notch product, I wanted to share a couple installed pictures. Anyone on the fence, you will not be disappointed. You literally can't go wrong with Porterbuilt products and Travis' customer service. Thanks again!
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline
Old 12-27-2014, 02:15 AM   #29
Pro Performance
Frame looks great! Thanks for sharing the pictures and good words.
Old 01-08-2015, 04:44 PM   #30
C10Greg
Do you have these available and are they still $995?
C10Greg is offline
Old 01-08-2015, 05:02 PM   #31
Pro Performance
These are still available, but the $999 was an introductory price. They are $1,199 now. I did have one in stock, but am now out, but can definitely order one for you.
- Travis
Old 09-16-2019, 09:13 PM   #32
19Loki67
I’m running a full RideTech strongarm coilover setup. I want to use one of these stiffeners to help strengthen my frame cuz I’m running an LS3 stroker motor. Do u think the trailing arm mounts will work with the RideTech trailing arms?
19Loki67 is offline
Closed Thread
