#26 | |
Re: Ammeter to Voltmeter - New American Autowire Harness
Myoldtruck that looks great where did u get the clock ?
#27 |
Post Whore
![]() Join Date: Feb 2016
After the great photobucket debacle some of the photos in this thread were lost. Here is a couple new ones showing the back of a Squarebody voltmeter with the 67-72 front on it. The blue rectangle is the previously mentioned resistor.
The 2nd photo shows the small screw and nut I used to replace the rivets. If memory serves me they are 8-80 screws. Much thanks to the OP and all the contributors since. I am now sporting a nice voltmeter in my Burban.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#28 |
![]() Join Date: Apr 2016
Good to update with previously lost picture. What does the face of it look like? And which 2 of the 3 terminals are used? When ray_mcavoy and leftybass209 referred to the "lost" pictures, they mentioned terminals A, B, and C, using A as 12V input and B ground and don't connect C.
#29 |
Post Whore
Here is how I did mine. Notice that I have the ground on bottom either way works. I am still planing on routing the wire differently than shown. It is way too long and bothers me but I have some more components to mount (and that switch to remove) so it will have wait until then.
And here is a labeled switch to match the earlier posts.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 06-06-2020 at 12:37 AM. |
#30 |
Here's a pic of the 67-72 face on the voltmeter. I set the needle for 12v in the straight-up position, and used a 13.8vdc power supply to confirm it in the "charging" position.
In the second pic I repurposed the AAW harness yellow and purple VSS leads and connector for the voltmeter. Yellow is ground, and purple (12v ignition) is spliced to a bullet connector for future use, and the gray lead in the #1 position in the gauge connector (lower right). I probably over-thought this, but it was a winter project when I couldn't tackle other things.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. Last edited by tim_mc; 06-06-2020 at 11:09 AM. |
