07-01-2014, 12:42 PM | #26 |
Re: Garage interior finish
I used 1/2 sheetrock on ceilings and 3/8 plywood on walls then caulked seems on the walls and taped and textured ceilings.
1970 K20 1967 Blown Stepside 2016 Chevy 2500 Duramax 1989 Jeep Cherokee 1995 S-10 2014 Infinity Q-50 AWD 1970 Chevy K20 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=634164 1967 stepside rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=684913 Shop build http://www.garagejournal.com/forum/s...d.php?t=225559 |
07-01-2014, 12:56 PM | #27 |
I did 7/16" OSB with a 3' tin wainscot and tin on the ceiling.
07-02-2014, 05:18 PM | #28 |
Nice job !!!
07-13-2014, 03:48 PM | #29 |
Active Member
I like that idea of the 3' metal Coach. I think I'll use that on my walls. I was already planning to use the OSB but the addition of the metal on the bottom would help protect from scrapes and bumps as well as moisture protection in case I want to scrub and spray out the floor occasionally.
Fleet '66 ***************** '66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade '64 C-10 LWB BBW near future project - "The Wife's Ride" '58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show |
07-13-2014, 05:59 PM | #30 |
I did 3' of standing seam out of some old stuff i ripped off a roof doing a remodel.
11-03-2014, 10:40 PM | #31 |
I used 1/2 in. OSB on the walls and tin siding on the ceiling. It is not finished in this picture, it has changed quite a bit since then.
You need to go to the garage journal and check out some of the garages there, you will spend hours (days) looking at them. http://www.garagejournal.com/forum/index.php Jim |
12-04-2017, 01:56 AM | #32 |
I was going through my old threads and found this one I totally gapped out... here is a pic of the garage after I got it all done.
Went with 1/2 cdx all around painted white and caulked the seam between the wall and ceiling. Turned out really good. Ended up having to install more joists to make the garage 24" on center (was 48" on center). Also grinded the floor with my 4 1/2" grinder and painted epoxy. |
12-04-2017, 03:23 AM | #33 |
I wish my garage floor was flat enough to allow sanding! Seriously, my garage floor must have been poured during an earthquake.
Nice looking garage man. |
12-04-2017, 09:46 AM | #34 |
motor exploder
That turned out really nice! well done
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
12-04-2017, 09:48 AM | #35 |
motor exploder
How did you get the OSB to turn out that smooth? That looks very nice.
12-05-2017, 12:33 AM | #36 |
Thank you guys. It looks a bit different in there now that I have many projects to keep myself busy!
