Old 06-13-2014, 05:52 PM   #26
Tennypicou1
Tennypicou1's Avatar
Re: Project General JD "Ole Jack"
Repaired the tailgate had rust holes everywhere and painted I like the way it came out keep in mind I spray canned the paint job on this because it is an ongoing project when I am done with all the body work and body replacement it really needs it will get a professional paint job but that will be sometime from now it really needs a lot of new parts. I just made it as solid as possible so it can be driven and have fun with it while repairs are made.
Tennypicou1 is offline   Reply With Quote
Old 06-13-2014, 05:56 PM   #27
Tennypicou1
Passenger side work being done it was worst than the drivers side by far and had some crazy repairs made took forever just to cut those out
Old 06-13-2014, 05:57 PM   #28
Tennypicou1
more of the passenger side
Old 06-13-2014, 06:02 PM   #29
Tennypicou1
So I was not a good documenter with the pictures was not really thinking about it at the time was so much work involved here is the truck after all the work was done
Old 06-13-2014, 06:25 PM   #30
Tennypicou1
15% Tint installed and the first photo shoot for a charity benefit my tattoo artist was involved with
Old 06-13-2014, 06:29 PM   #31
Tennypicou1
This is the photo they used for the poster for the event
Old 06-13-2014, 06:33 PM   #32
Tennypicou1
Jack Daniel's logos installed and the shifter I use. I also recently raised the shifter so you can it through the windshield
Old 06-13-2014, 06:36 PM   #33
Tennypicou1
Wood bed cover built and installed. Used old wood I got from an abandoned paper mill it was shelving sandwiched vinyl between the supports and the cover to keep it from leaking
Old 06-13-2014, 06:43 PM   #34
Tennypicou1
Installed 17" FJ cruiser wheels with 225/70r17 in the front and 295/70r17 in rear had to spread the rear fenders, cut the lips, and bent them over to get the tires to fit the drivers side rear fender needs body work done to it after I found very thick bondo covering up damage
Old 06-13-2014, 06:47 PM   #35
Tennypicou1
Wood bed cover stained and Jack Daniel's logo painted on
Old 06-13-2014, 06:48 PM   #36
Tennypicou1
Trim rings installed
Old 06-13-2014, 06:54 PM   #37
Tennypicou1
Currently working on installing CPP tubular trailing arms, rear sway bar, porterbuilt crossmember for the trailing arms, front power disc brake kit, upper and lower control arms, front sway bar, and power steering kit with quick ratio gear box.
Old 06-13-2014, 06:58 PM   #38
Tennypicou1
And the brake spindles are 2.5" drop spindles
Old 06-13-2014, 07:42 PM   #39
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Nice work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-16-2014, 07:47 PM   #40
Tennypicou1
Thanks! I got the porterbuilt crossmember for the trailing arms, CPP tubular trailing arms, and rear sway bar completed today. Started on the disc brakes and power steering have the passenger side disc brakes with drop spindles and new upper and lower control arms mounted up. Also got the drivers side all apart and the power steering quick ratio gear box mounted.
Old 06-17-2014, 10:58 AM   #41
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I gotta say I really like the look with big tires filling the fender wells...makes it look better imp.
Old 06-17-2014, 02:53 PM   #42
Tennypicou1
Thanks man I like how it turned out. I actually put those tires on it to bring down my rpms and with some luck on my side the speedo is now correct no more GPS.
Old 06-21-2014, 09:31 PM   #43
Tennypicou1
Got the disc brakes on, power steering gear box on, and power steering pump installed. While installing the pitman arm it feel and chipped my tooth hurt like hell. Seems like everything I do with the old truck fights me the whole way. But tooth can be fixed and the truck will ride like a new one when I am done. Worth it!
My build thread General JD or Ole Jack
http://67-72chevytrucks.com/vboard/s...d.php?t=632318
Old 06-22-2014, 07:00 AM   #44
rusty76
rusty76's Avatar
Neat truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 06-22-2014, 11:36 AM   #45
Tennypicou1
Thank you
Old 07-16-2014, 11:43 PM   #46
Tennypicou1
Had the wife helping with mounting the power brake booster today.
Old 07-17-2014, 10:34 PM   #47
Tennypicou1
Finished the brake lines today. Bled the system. Same for the power steering. I love the stance with the 2.5" drop spindles and 2" drop springs in the front not sure if I want to leave the 4" drop in the rear or go lower. I like the rake but it is extreme. Pictures to follow tomorrow.
Old 07-18-2014, 10:12 AM   #48
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
P/B is always nice. lol
Old 07-18-2014, 11:39 AM   #49
1963c-10
1963c-10's Avatar
Nice progress and the projects rolling along quick. Keep up the pics and progress!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-18-2014, 03:33 PM   #50
doobiebro
doobiebro's Avatar
Nice build! Looks like we both have similar taste..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
1964, c10 chevy truck, jack daniel's
