Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 11-11-2014, 09:54 AM   #26
BabyBlue
The Peacemaker
BabyBlue's Avatar
Re: Out with the old and in with the new.
http://www.lingenfelter.com/mm5/merc...E#.VGIUFFtigi4
http://www.lingenfelter.com/mm5/merc...7#.VGIUC1tigi5
These two parts are at the top of my list right now. I am trying to get a head gasket thickness to find out exactly how much this might drop my compression and if I should just buy stock 6.2L heads. 56.5cc vs the 59-61cc of those beautiful machined heads. That cam might be a little aggressive in which I may opt for the Comp Cam D .224/.236 N .222/.234 118LSA .572/.529 @ .050" (With 1.8 Rocker Arm).
We'll see. I might just go with a tune for the moment and wait till spring for these upgrades.
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 01-03-2015, 12:44 AM   #27
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Very nice truck! I just bought a 2014 Chevrolet RCSB with the 5.3L/6 speed automatic, but haven't' picked it up yet. Can you haul anything after doing the 4/7 drop? I'd like to lower it, but I'm hesitant because I want to pull a trailer sometimes as well as throw stuff in the back. Not to mention the possibility of warranty issues.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-03-2015, 02:45 AM   #28
piecesparts
Parts and more parts
piecesparts's Avatar
My 2011 has a McGaughy's 5/7 drop. I upgraded the rear shocks to a Bilstein shock over the McGaughy's shocks. I use my truck daily and haul what I want in it. I have had close to a 1000 pounds of black dirt in it without any real issues in hauling it.
Frank
piecesparts is offline   Reply With Quote
Old 01-03-2015, 04:41 PM   #29
C10_ustacould
Blank canvas... I have a few ideas.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-10-2015, 08:37 PM   #30
BabyBlue
The Peacemaker
BabyBlue's Avatar
I'm with piecesparts, I've had a bunch of lumber in the back without any issues. I kept my bumpstops and those hit every once in a while if I am not careful around a huge bump or hauling a lot with a good bump, but other than that, no issues. My dealership is a little finicky but they didn't care about the lowering, more about the tune that I have to do after the headers and air intake.
aka "Audrey"
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
Old 01-10-2015, 11:18 PM   #31
C10_ustacould
I talked to the service manager at my dealer and he said the only pieces that would not retain the factory warranty would be those that I replaced. However, if they deem the drop caused a failure of other parts they may not be covered. For instance, if a u-joint fails and they attribute it to a vibration caused by the drop it wouldn't be covered by the warranty. Fair enough, I guess it's the price of looking awesome! I think I will go with a 3/5 drop initially since the drop is adjustable. One question that does come to mind is that you all mention changing shocks. Everything I've read says the kit comes with front struts and rear shock, do they not work well?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 01-11-2015, 12:12 PM   #32
piecesparts
The front drop consists of changing the springs and the spindle piece, but uses the factory strut. As good as they are, I wanted a better control of my ride, so after a short period of time, I upgraded to a different strut. The rear shocks work well, but the pair that I got from McGaughy's did not have the valving that I wanted, so I upgraded to a Bilstein shock. With my 5/7 drop, I changed out the degree pieces in the front to allow for more range on the wheel alignment.
Frank
Old 01-11-2015, 02:52 PM   #33
BabyBlue
The Peacemaker
BabyBlue's Avatar
I should probably get those alignment cams for mine, it isn't quite factory alignment but it is darn close.
MY front drop used the adjustable coil spring mounts....now that they have an adjustable strut, c-notch and drop shackle......hrmmmmm, maybe it's time to go looooweeeer. hahahaha. Have to wait till this NY winter is over and I know I can get a "winter" rig though. I hate driving it in the winter but it's not like the 78' is touching pavement anytime soon.
aka "Audrey"
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
Old 01-11-2015, 05:20 PM   #34
piecesparts
The one thing that I found out about mine and winter. It now sits low enough and the design of the frame being so low, the truck actually became a sled in deeper snow. It would actually move along until it lifted the wheels high enough to not get any more grip. I now have a four wheel drive winter beater for those stinky deep snow days.
Frank
