Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-03-2017, 07:28 PM   #26
72HuggerK20
Re: Two Tone BC/CC methods
This has gotten me to thinking a little bit, and I could use your input on this Brian. So most companies say that if you go over the topcoat time window of the basecoat (24 hours or whatever it is), you should scuff, re-basecoat, and then clear. Assuming that you aren't messing with metallics or tricoats, would it be out of line to assume that you can scuff the basecoat, spray the entire area with the recommended basecoat blender for whatever system you are using, and then clear the blender? Or could you even do a little pre-planning and shoot ~2 coats of blender over your wet basecoat to give you something to scuff later without actually scuffing the basecoat? And then go ahead and clear? Or could you even skip the step and just scuff the basecoat and clear it? Not trying to be a bench chemist, just trying to figure out a good way to do two-tone.
72HuggerK20 is offline   Reply With Quote
Old 10-03-2017, 07:59 PM   #27
Flying Hamster
Flying Hamster's Avatar
Depends on a lot of things.
Manufacturer says "24 hours" and knows it will work.
You can stretch that window a little and have no problems, you might stretch it a lot and get away with it, or, it may go bad.
If you stretch the window, the Mfgr. is off the hood...
(God, I miss Lacquer. No fuss, no muss. No "windows", No hardeners)
2006 Sierra RCSB V6 5 Speed RWD.
Flying Hamster is offline   Reply With Quote
Old 10-03-2017, 08:01 PM   #28
72HuggerK20
And with a quick splash of thinner, no paint!
Old 10-03-2017, 08:53 PM   #29
bandit0067
Several guys on my Chevelle site have stated they don t like to clear coat over white.....and then give their reasons. I have done several bc/cc jobs myself , but never over white...so I am not sure what they are seeing. I have sanded and buffed both single and two stage and had good results. All you guys are ok with cc ing over white.
My last chevelle will be painted its original 69 white and I am working towards my 71 c 10 as a white and orange truck. Would that be a different white....as to the tape lines, don t the upper and lower moulding cover most of that...
bandit0067 is offline   Reply With Quote
Old 10-03-2017, 09:06 PM   #30
72HuggerK20
Don't get me wrong, I hate clearing white too. Only because you can't see a damn thing while you're doing it. It's really hard to see dry spots. I really dislike single stage though because I find it much harder to spray.
Old 10-03-2017, 11:00 PM   #31
MARTINSR
MARTINSR's Avatar
Yep you really need to follow the manufacturers guidelines! I use to shoot SW (I was a paint rep for them, the Martin Senour label) and the recoat window was 7 days! Love that stuff!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 10-04-2017, 01:33 PM   #32
msg
Stumbled in here, the two tone restoration I am now doing on my 66 fleetside will also have a white top and the white stripes on the side in between the chrome, plus the tailgate lettering. As a newbie I am so glad I read this information. I will need to sort out though when to spray the white strip on the doors, fender and hood, but I know Ill be shopping for some fine line tape!
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 10-04-2017, 03:05 PM   #33
MARTINSR
MARTINSR's Avatar
Usually I would say spray the overall color then the white being the white is small, but yours is really small compared and I am thinking it takes more masking but check this out. You have the whole truck just prior to prepping for paint, all in primer let's say. You mask off to paint the white but only with like foot wide paper just so you don't have direct overspray on the primer surrounding the white. The overspray past that paper, who cares, you are going to be sanding it for paint anyway right?
So you put the little paper around the white areas and paint and clear them. Then sand the truck for painting the other color leaving of course the white untouched. You then cover the white areas with paper and shoot the truck the primary color and unmask the white and wham, done.
Especially with the white roof this works good because you don't have to worry about the hood and what ever is below it getting damaged.
Brian
1948 Chevy pickup
Old 10-04-2017, 04:44 PM   #34
msg
Yeah I have a fully dismantled truck and single car garage so I will be painting part for part and then re assembling, so I had thought to in the case of the cab mask off the part that gets the contrasting color (in my case metallic saddle) and spray the white first. In fact I wondered if I even needed to mask it off at all? Maybe instead just shoot the white on the top and where the stripes wrap around the backside of the cab. Then mask off for the saddle color. I was worrying about the hard edge that would form if I were to mask the white areas, then spray,then pull that tape off and masking and then have to re tape that same edge to shoot the saddle.
Old 10-04-2017, 05:04 PM   #35
MARTINSR
MARTINSR's Avatar
BE SURE TO READ THIS THREAD!
> http://67-72chevytrucks.com/vboard/s...d.php?t=746922
No really, if you are painting in pieces be sure to read that thread.
Brian
1948 Chevy pickup
Old 10-04-2017, 05:25 PM   #36
msg
Brian, Im the same guy youve helped in that thread
Old 10-04-2017, 06:24 PM   #37
MARTINSR
MARTINSR's Avatar
Ohhhh, did you read it?
Brian
1948 Chevy pickup
Old 10-04-2017, 07:34 PM   #38
msg
Yes sir, and re read it a few times. I'll follow up with you there...sorry to high jack the thread 72step
Old 11-13-2017, 12:29 PM   #39
msg
Fine Line Tape recommendations?
Since it might help others to know who find this thread, what is the best fine line tape to get..width as well for masking off the top of the cab with its bends and curves, fleetside stripe, and tailgate lettering?
I assume its the 3M 218 like below? Does the smaller width help like a 1/8"?
https://www.amazon.com/Scotch-Fine-L...ustomerReviews
I have plenty of this around but from what Im reading here not to trust it..this so?
https://www.amazon.com/3M-06652-Auto.../dp/B000FP8HFK
Old 11-13-2017, 12:52 PM   #40
72HuggerK20
I'd probably use regular green masking tape for everything. I've only ever needed two widths as well. 3/4" and 1 1/2". I tried fine line tape on tailgate letters and found that just taping them with the regular stuff and cutting it with a nice sharp razor blade works best. Have to be careful not to press too hard, you just want to score the tape. 3/4" masking tape is actually very good at making gradual bends as well.
