01-09-2015, 03:52 PM | #26 |
Re: Painting grill letters ..the easy way!
Excellent... will put this to use shortly and maybe by summer I can participate in a FEF post lol
64 Step Side - The Mistress |
01-09-2015, 04:06 PM | #27 |
someone give that man a BEER!!!!!!!!!!!!
01-09-2015, 04:52 PM | #28 |
You're the man OEM...what a wealth of Chevy Truck knowledge. Just what my grill needs as it looks too dark. I wonder if I can return my stick'um letters...
01-20-2015, 07:50 AM | #29 |
Will be doing this shortly thanks...
08-25-2015, 09:15 AM | #30 |
thanks for the info will be doing this soon
03-03-2016, 05:49 PM | #31 |
Nice..best way to paint most recess areas.
03-05-2016, 05:05 PM | #32 |
Cool trick!! I learned it with my shift knob numbers.
03-05-2016, 07:03 PM | #33 |
10-20-2016, 12:41 PM | #34 |
will this work with a chrome grill and if so what paint should I use and what type of paint thinner.
10-20-2016, 04:43 PM | #35 |
It should work exactly the same way. New chrome on a steel grill will be a bit slicker than the factory aluminum, so it might tend to flake off easier when dry. Make sure your grill is 100% clean before painting, and use a high solids paint for best results. If you use the same paint/thinner that I did, you should be ok.
10-20-2016, 04:49 PM | #36 |
Sorry for my ignorance but what is high solids paint?
10-20-2016, 06:30 PM | #37 |
High solids means that by comparison, there's more paint/pigment, less solvent in the can. High solids paint will require fewer passes to cover well. Some paints nowadays are so watered down they take many coats to build a film, and also tend to fisheye more.
I think the pigment to solvent ratio (like ingredients) used to be printed somewhere on every can, but I just checked a couple newer cans and that info wasn't on there. Hmmm. Just use the Duplicolor stuff I did, and you'll be fine. It's sold at local auto parts stores. Last edited by oem4me; 10-23-2016 at 12:02 AM. |
10-22-2016, 08:31 AM | #38 |
Great info thanks!!!
10-22-2016, 09:57 AM | #39 |
I have an NOS aluminum grill, the letters are not painted but have always been curious if they should be.
07-28-2018, 09:43 PM | #40 | |
But Found Her 25yrs Later!
I have a beautiful aluminum grill that doesn't appear to have ever had painted letters.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-30-2018, 10:55 PM | #41 |
Here is a NOS posted by GMCNUT:
No painted letters
07-30-2018, 11:22 PM | #42 | |
If you can't use solvent (ie you have a body color painted grill) you can either build up a bunch of wax on the area's you don't want to paint (build many coats but don't buff it off). Do the paint method the same way, the overspray will stick to the wax, not the clearcoat, buff excess paint away. Vasoline works damn well too. I know that's an odd trick but it's a work around. Another method is go to Staples and get clear window cling. Apply over the area, draw the letter outlines with a sharpie ("trace them"). Remove cling, cut out, reapply, you have a stencil. (This with wax is a good combo too).
64 C10 A bunch of Volvos Luthier Simpsons Nerd Last edited by hank scorpio; 07-30-2018 at 11:32 PM. |
08-03-2018, 09:57 AM | #43 |
This is going to come in handy when I'm ready to do it. Thanks!
08-09-2018, 03:46 PM | #44 |
You can wear tight rubber gloves before you wrap your finger in t-shirt scraps to keep the paint thinner off your skin.
03-31-2019, 09:48 PM | #45 |
got to V - will finish the rest next weekend.
Your technique worked well - thanks! How has yours held up all these years later? |
04-01-2019, 07:49 AM | #46 |
I want to try this on my 70 this year. The grill looks too bare without those letters.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
04-01-2019, 07:56 AM | #47 |
EdwardSams - Are you planning on painting the lines at the top and bottom also? Same way? I'd love to see results when you are done.
04-01-2019, 10:54 AM | #48 |
Like others have posted, this technique is useful for lots of trim details. Sail panels should be easy. A bunch of years ago, I re-did some rocker trim on a '63 Corvette using this method. That Corvette trim piece has straight flutes in it which are almost exactly like our sail panels, but it's four or five long feet of continuous lines. Any waves show up terribly. I think it was my first effort with this, and they came out perfect. Kinda blew me away and sold me on the technique.
Included is a pic of some Vette rocker trim, not mine. Last edited by oem4me; 04-10-2019 at 09:12 PM. |
04-01-2019, 12:52 PM | #49 |
1965 Chevy C10, 2005 4.8L/4l60
Here is my grill letters, I used this post to do it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-01-2019, 09:05 PM | #50 |
