09-17-2014, 06:57 PM | #26 |
Re: 69 chevy feeling tired!
I would at least make sure the fusible link is still there. Many of them have burned out over the years and been bypassed by previous owners.
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
09-17-2014, 07:05 PM | #27 |
Longstepper-
NEVER run an un-fused wire in your passenger compartment, and keep in mind if you blow a fuseable link other things will be disabled. Ignore the bantering. I know, it's hard to sort through the the injured egos telling you this and that and this leaves you with conflicting answers. |
09-17-2014, 07:19 PM | #28 |
Thanks guys I will start by making sure everything is tight, then use some thicker wire for ignition. That won't be until Sunday but I will keep you posted!
Also, does 15-16 hg. Vacuum coming from the right side port on the front of the carb sound right? |
09-17-2014, 07:22 PM | #29 | |
Edit alert! Have a nice day "in your truck" LOL that relates to trucks. Get it? LOL Last edited by mechanicalman; 09-17-2014 at 07:23 PM. Reason: forgot to add "have a nice day" LOL |
09-17-2014, 07:27 PM | #30 | |
In fact, I believe the original breaker point resistance wire is unfused and begins in the passenger compartment as well (though it gets routed to the engine of course). That one's debatable, but there's certainly no distributor fuse. I have no idea what bad technical advice has to do with egos. Given that I'm consistently right, my ego just keeps getting bigger. Who's is injured?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible Last edited by davepl; 09-17-2014 at 07:42 PM. |
09-17-2014, 07:43 PM | #31 | |
09-17-2014, 09:09 PM | #32 |
What seems like eons ago now, when I did small cap MSD HEI converison in the Jimmy, I used 12ga wire which was same size that the MSD distributor came with. I plugged it into the spade connector on the fusebox marked IGN. This has worked fine for at least 15 years.
It makes for an easy way to disable the vehicle as well if you wish to have an additional anti theft method when you park somewhere that you worry about the truck.
09-17-2014, 09:17 PM | #33 | |
