10-15-2014, 11:40 AM | #26 | |
Re: 4 link Kit for 55-59 Chevy Truck
what rearend are you running in your truck? traction bars can be as cheap as $49 and may be your cheap fix if you chose traction bars; read up on the applications (i've never installed/used them) the snubber should make contact on the spring pivot not further back on the spring
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-17-2014, 09:56 PM | #27 |
polishing a turd
Nice looking truck!
I like using a panhard or even better a watts link to locate the rear axle. It defines the rear suspension roll center. I am building this '59 to be a an all around performer, which includes handling around corners (I guess that's called pro touring now?) so that's why it is a no brainer to me. Plus the adjustable link locations allow you to dial in how the chassis responds to power being applied to it by the rear axle.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
11-06-2017, 09:55 AM | #28 | |
Triangulated http://www.how-to-build-hotrods.com/...ed-4-link.html Parallel http://www.how-to-build-hotrods.com/...el-4-link.html I just bought the Performance On Line Kit because of the rectangular upper shock bracket like HEIDTS, is the complete kit and it has a Limited Lifetime warranty! https://www.performanceonline.com/19...-Kit-Complete/ and it is $999 but if you watch the web site I got it for 10% off and got it with the Blacked out Coil-over adjustable shocks! |
11-08-2017, 12:03 AM | #29 |
A lot of good info on rear end set ups!! What are some of the width & types of rears? What fits under the rear fenders? tires,wheels,back spacing ??????
11-14-2017, 03:32 PM | #30 | |
11-22-2017, 10:54 AM | #31 | |
I'm thinking of down the road to doing this very thing. Thanks again for your help.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
11-22-2017, 11:04 AM | #32 |
cody,iam running a dyna 60, if you click on my build just underneath my signature, it will give you an idea of how wide you can go without making you frame more narrow from your stock frame, You will have to notch the frame if you lower it and of course cut in to the bed sides to squeeze that amount of meat in there. ask away if you need more info
