Old 01-26-2015, 01:26 PM   #26
38synergy
Re: 99 454 belt tensioner-discontinued?
Please let everyone on this forum know how it works. Take a look at the knock sensor. Wayne 38synergy@gmail.com
38synergy is offline   Reply With Quote
Old 01-29-2015, 03:29 AM   #27
brwn70gmc
It seems to work just fine so far, thanks for your help Wayne, I'm back on the road. Still looking for a new oem part...Knock sensor is where?
brwn70gmc is offline   Reply With Quote
Old 01-29-2015, 01:18 PM   #28
38synergy
It screws into the block, looks like an oil pressure sender. Sorry I can't remember where! Wayne
Old 01-29-2015, 01:23 PM   #29
truckdude239
truckdude239's Avatar
Passager side right above the oil pan
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-29-2015, 01:44 PM   #30
brwn70gmc
would it kick out a code or should I just try a replacement? it idles poorly
Old 01-29-2015, 03:34 PM   #31
38synergy
I would not change anything without finding a code.
Old 12-26-2015, 10:57 PM   #32
SACRAMENTO 71
SACRAMENTO 71's Avatar
Brwn70 - did the eBay part ever work? I'm having the same issue with tensioner and curious if that is the route I should go. Thanks Nick
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400
64 C10 SWB 406SB TH400
74 SUBURBAN 454BB TH400
78 K10 SWB 350 TH350 6" ON 35" BFG MUD
71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD
00 K3500 DRW BIG BLOCK "DRINKING PRBLM"
SACRAMENTO 71 is offline   Reply With Quote
Old 12-27-2015, 12:48 AM   #33
brwn70gmc
It does work quite well. I installed it and haven't had a problem since.
I would still prefer to find the original part, but apparently they're all gone?
seems hard to believe there's none to be found. good luck and let me know if you ever find any originals.
Old 12-27-2015, 04:43 AM   #34
SACRAMENTO 71
Thanks BRN70GMC, experience is priceless. Appreciate you sharing, I'll be ordering the same tensioner shortly. Nick
Old 12-27-2015, 12:57 PM   #35
38synergy
This is 38synergy. I have sold over 140 replacement 10237275 tensioners. Not one complaint! They are available on eBay. Be careful, two customers copied the design! Mine is sold under ruthwayne. A NAPA store in Brea CA also stocks them. Jackson NAPA Brea, CA. Wayne
Old 03-19-2018, 07:45 AM   #36
I fix brown trucks
Had this same problem with trying to find this tensioner. I ended up getting one from ebay and it worked great. But I kept searching and finally found a direct fit aftermarket replacement. It is from Dorman part number 419-126.
Left- original
Center- Dorman
Right- ebay
I fix brown trucks is offline   Reply With Quote
Old 03-21-2018, 10:37 PM   #37
brwn70gmc
Thanks for the info, glad to know there's a few more options. Nothing against the one I got from Ebay, it's working great, but the Dorman seems close to the stock part.
I think at 210,000 I'm due for injectors, it idles horrible
belt, tensioner
