07-31-2015, 12:07 AM | #26 | |
Re: Build start
07-31-2015, 11:59 AM | #27 |
Re: Build start
for the pics..... hold the phone sideways with the button on your right hand side. thats the only way i can get the pics to post right side up
1967custom |
07-31-2015, 01:22 PM | #28 |
Florida Edition
Re: Build start
I suggest you buy a good little digital camera...less than $100. You defiantly want to document your work on this for future reference, it's going to be a great truck!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-01-2015, 10:31 PM | #29 |
Re: Build start
No new pictures worked on mocking up the serpentine belt set up. Have the Ac brackets ready to weld up .Put the ford 9 inch in today and set the pinion angle .Was going to put the axle on top of the leaf springs but with weight on it it was only about an inch from the frame.I didnt note the ride height before took it apart.Just going to put it under the leafs and see where it ends up lowered the front 3 so i might get away with using a custom pair of shackles on the rear of the springs and if thats not enough ill raise the front spring hanger .
08-04-2015, 12:24 AM | #30 |
Re: Build start
Well its coming along made a bracket for the AC for the belt drive.Grinders cut off wheels and determination!
08-04-2015, 07:13 AM | #31 |
Re: Build start
Looks like it's coming along nicely to me. I like the serpentine setup, what did you use for that? The frame looks bad ass too. You better have paid your buddy in lots of beer to wire wheel that thing. Lol.
08-05-2015, 12:30 AM | #32 |
Re: Build start
The belt drive set up is a cobbed together early 1987-88 454 system with a stamped steel braket on the D side alt,pwr steering pump side .And i made the Passenger side bracket from 1/4 steel plate.Used a 103 inch long belt.
08-23-2015, 11:48 PM | #33 |
Re: Build start
Some new pics had to fire the helper was ruining too many parts .Not my grandson he is awesome!The (mechanic)i hired everything he worked on i had to fix?Not good still trying to finish for the 7th of Sept for Pigeon Forge show.
09-29-2015, 01:55 PM | #34 |
Re: Build start
[QUOTE=0311Chevy8152;7173875]Wish I lived closer, maybe out of both of us we could compensate for each others disabilities. I can only get a little while out of my new hip right now depending on how heavy of objects I carry and twisting to get into tight spots. Hope you are doing well with the hip .
09-29-2015, 01:58 PM | #35 |
Re: Build start
Well we made the Pigeon Forge show!The front brakes locked up had to adjust the valves the shifter came off in my hand and the clutch is weak when it gets hot and you can barely get it in gear .But we made it to Tennessee then Naples Florida and back to Md averaged 12 mpg .
