Old 05-01-2015, 09:23 AM   #26
aruss99
Re: 1971 C-10 knocking sound and not reving past 3000 RPM
Well that sure is a shame, looks like it makes sense to put a performance cam in with a new valve train. Think about a 268H. Thanks for all the help. I would have never know what to check, it is very much appreciated
aruss99 is offline   Reply With Quote
Old 05-01-2015, 09:51 AM   #27
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
A wiped cam lobe is a complete teardown and overhaul. There will be so much metal particulate in the oil that it has gone through the entire engine. It will be embedded in the bearings too.
You HAVE to get all the metal particles out of the engine. Meaning a very very thorough cleaning of all the oil galleries. I wouldn't be surprised if there is a bit of damage done to the crankshaft as well. Depends on how long you've been driving it this way.
Not bring the doom and gloom, but it happened to me as well. If you just huck a new cam and lifter in there... you'll be going through this whole process again very soon.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-01-2015, 01:03 PM   #28
BugzC10
BugzC10's Avatar
Check that lifter before you go off the deep end with a complete tear down and new cam.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 05-01-2015, 02:39 PM   #29
aruss99
Ok, to check the lifter, can I just pull it out? Or is there more to it? Also, if the lifter is messed up, can I replace just that one? Or do I need to replace them all?
Old 05-01-2015, 02:59 PM   #30
GASoline71
GASoline71's Avatar
Like Bugz said... check to make sure it's not a "collapsed" lifter. You can just pull it out of it's bore. But if you pull it and the bottom is eaten away like this:
Then you have worn cam lobes and there will be lots of trash in the oil.
Gary
Old 05-01-2015, 03:30 PM   #31
67 chevelle
67 chevelle's Avatar
You need to remove the intake manifold to get to the lifters on a small block , check to see if the pushrod is bent or the rocker stud is lose first , either can cause this
not changing the oil will cause flat cam lobes
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-01-2015, 03:32 PM   #32
aruss99
Ok, will do. Thanks for the help
Old 05-01-2015, 04:18 PM   #33
BugzC10
BugzC10's Avatar
If you get lucky and it's just the lifter, it is my understanding you should replace all of the lifters. There's also a school of thought that you must put in a new cam along with the new lifters. Pull the rocker arm off the bad lifter and pull out the push rod to see if it is bent.
Old 05-01-2015, 05:46 PM   #34
motorcritter
motorcritter's Avatar
it sounds like it's 'time' to look at the innards. A 40+ year old truck probably needs some sort of attention, more involved than plugs and an oil change. Unless I have definite history on a vehicle, I assume the worst possible maintainence has been done, and inspect accordingly. If the 'worst case scenario' doesn't present itself, I am one happy SOB. If you don't think you're up to the challenge, there's plenty of help, here on the board. There is probably no situation that some one of us hasn't dealt with, and overcome, usually successfully!
motorcritter is offline   Reply With Quote
Old 05-01-2015, 11:55 PM   #35
aruss99
In order to take off the manifold, it looks like I need to pull out the distributor as well. Is there any special procedure to take it out so I don't mess it up, or can I just mark it and the intake manifold as a reference to put it back in?
Old 05-02-2015, 07:34 AM   #36
BugzC10
BugzC10's Avatar
I usually rotate the engine until the dizzy is in #1 firing position (rotor is pointing at #1 cylinder) then mark location.
Old 05-04-2015, 10:30 PM   #37
aruss99
I was finally able to pull the cam out of the motor only to find that several of the exhaust camshaft lobes were going flat if not there already. It is so bad that the whole motor would need to be rebuilt. That's where I have a question, my dad is currently building a 62 C-10 with a 6.0 liter LQ4 that he got for around $1000. I have been looking at 5.3 liters and it looks like they are around $600. I know it would be cheaper to rebuild my engine myself and have some of the motor machined than having to buy lots of different miscellaneous parts for the 5.3 but I was wondering what you guys thought of going the 5.3 route for increased reliability and better gas milage. Any input is very much appreciated as I have done a lot of research on this but still wasn't sure the correct route to go given my situation. Thanks
Old 05-05-2015, 08:01 AM   #38
MARKDTN
Fuel injection swaps are quite nice. That is definitely the direction I would go. No way I ever build another carbed engine unless it is on lawn equipment.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-05-2015, 08:29 AM   #39
motorcritter
I, too, have decided- no more carburettors, unless it's a vintage motorcycle. The '69 GMC is getting a TPI SBC, the '71 Cheyenne is getting an LS and the jury's still out on the '70 C10. I love the 'old stuff', but I am not a stranger to technology. For a truck that's going to see regular/daily driver use, an LS conversion makes sense, the expense is going to be there, either way- and the 'old tech' stuff has maintainence costs that the 'new tech' stuff doesn't. I vote- LS! I was fortunate (or cursed) to have been in the auto service biz from the time of points and drum brakes and carburettors to all this high- tech (and reliable) stuff. And I am grateful for that.
Old 05-05-2015, 09:09 AM   #40
hamjet
hamjet's Avatar
Hey now fellers, carbs go with manual brakes and manual steering! OLD SCHOOL ALL THE WAY!!!
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 05-05-2015, 02:58 PM   #41
motorcritter
Old skool is nice, I've got a '35 Plymouth PJ than is all original except paint colour. Daily driver- no. My '72 Triumph Bonneville is 'old skool', except for the transitorised ignition, gel battery and resleeved Amal carbs. I'm not going to go across country on it, though. The trucks will get used regularly, and so, concessions to modernity will be made. That's how I roll. Or eye roll, 😈
350 chevy small block, popping, rpm, timing adjustment
