12-07-2015, 05:58 PM | #26 |
Post Whore
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
ok wanted to share some close up pics of the bellhousing
now see how this bellhousing has six transmission mounting holes, I heard people refer to it as dual bolt pattern, as in you can use it to mount two different transmissions to it depending on what you got, so like a Muncie SM 465 would use four bolts and the New Process NV833 would use another four bolt combination However, and you will see this when I post the pics of the transmission, my New Process A833 (or what ever the correct model reference is) actually has the matching six bolt holes. So the 64 million dollar question is do you need 6 bolts to mount this beast? and guys be gentle if I am driving you crazy with dumb questions I am trying to learn something here, and maybe help others too if they come across this later on in the future, thanks |
12-07-2015, 06:02 PM | #27 |
Post Whore
ok, so here is the full frontal of the New Process 440 or NV833 aka A833 MY6 option
note the six mounting bolt holes do you need all six, or is this so that it can mate with a variety of bellhousings, could it even be a transmission case with a bolt pattern that is shared with its MOPAR cousin? and again, remember there is no such thing as dumb questions, only dump people asking questions, ha ha |
12-07-2015, 07:28 PM | #28 | |
driving is in my blood
As for those junkyard trannys, no they did not include shipping. In the end as long as your happy with the outcome thats all that matters. For what I paid for my M20 plus its two rebuilds and new case I could easily had a T56 in the truck, but that just wouldn't make me happy.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
12-08-2015, 08:40 AM | #29 |
I would think that if the 6 holes line up(833 and bell housing) that you would want to use them.
Or are you thinking that some of the 6 bolts might interfere with something?
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
12-08-2015, 09:07 AM | #30 |
Ahh it appears your transmission has both GM and Dodge mounting patterns. It also seems that later bells also have both mounting patterns, my 2 hydro bells have both patterns on them, GM would just put gray plastic plugs in the 2 unused holes. This bell is shared with the SM465 as well.
12-08-2015, 12:26 PM | #31 | |
Moderator
Fairly easy to re-work as long as it's not shagged completely out. The shim plates and springs are available. This guy is hawking his hardened shift rod bushings. They transfer the wear to the soft harder to replace parts. I'd just use the nylon Hurst Pit Pack bushings. 6 bolts is probably gilding the lily. The SM465 does fine with just 4. It's heavier than a dead horse.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-08-2015 at 01:45 PM. |
12-08-2015, 03:58 PM | #32 | |
Post Whore
12-08-2015, 04:34 PM | #33 |
Moderator
Dodge pattern is LH side of the vehicle wider apart than the RH side.
GM are the same distance apart left and right sides. You could get creative and use 5 or use the bottom and middle top on the LH side...
And please let us know if and how your repairs were successful. |
12-08-2015, 09:23 PM | #34 |
I wonder which year they changes the bellhousing pattern. Mines from an 81 with a straight 6 and it has the old muncie saginaw bolt pattern
12-09-2015, 02:48 AM | #35 | |
Post Whore
Had I known this I would not have needed to get the bellhousing, but 1. I didn't know that, and 2. I was too excited when I was buying it, you know how that goes |
12-09-2015, 02:56 AM | #36 |
Post Whore
here is a side by side comparison of my Muncie SM465 bellhousing on the left and the New Process A833 bellhousing on the right so that we can stare and compare the bolt patterns
so looks like I may be able to simply bolt up this New Process trans to my original bellhousing |
12-09-2015, 09:08 AM | #37 |
Well you can always clean it and sell it, or stash it for a rainy day project.
My NP833 is from a 1981 truck, it only has the GM pattern. Interesting I wonder why the change. |
12-09-2015, 10:00 AM | #38 |
Moderator
I wonder if that bell can be used for the 96-01 (Dodge pattern) NV4500... If it can that's some cash for your project. Advance Adapters gets a pretty penny for their conversion bell etc.
The rumor is the 93-95 GM pattern NV4500 is specific to that transmission but I've never seen one to guarantee it. EDIT: went and looked it up. Ignore my hot air^^^ both bolt patterns of the NV4500 are specific to that tranny... much closer to square than either the A833 or the SM465.
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-09-2015 at 10:09 AM. |
12-09-2015, 01:59 PM | #39 | |
When I ordered my '87 it was placed on "stop order", because Mr Gasket was buying out Hurst and GM wasn't sure they were going to get enough shifters to support volume production. My truck was built on a temporary deviation to use up the 100 or so transmissions that we already had in house. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-09-2015, 03:24 PM | #40 |
Post Whore
ok guys lets move on to the shifter, I would like to share some close ups of the shifter that came with the transmission
I noticed the broken shifter knob threads when I was buying it, but it wasn't till I got home that I noticed the stick aka shifter lever is welded into the control mechanism, maybe some of youz can speak to that. I don't recon that's factory, ha ha |
12-09-2015, 04:01 PM | #41 |
Moderator
You could carefully slice through that weld with a cutoff wheel.
Some parts are available for the Comp Plus from Hurst https://www.hurstshiftersonline.com/...53&viewAll=yes The grease fitting makes it look like a Chrysler A-body shifter... the bendy bracket looks like it's for an 84 MY6 setup http://www.gmpartswiki.com/getpage?pageid=58016
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-09-2015 at 04:10 PM. |
12-09-2015, 08:28 PM | #42 |
Post Whore
thanks for all the help guys, I cleaned the shifter up a bit and am able to see some numbers on it, do these mean anything
12-10-2015, 08:11 AM | #43 | ||
I wouldn't have thought that would be the weak spot. Quote:
In later years they went to a flat stick which looks like a cleaner design. K
12-10-2015, 08:12 AM | #44 | |
Just patent numbers and internal codes. I don't see anything that looks like a GM part number. K
12-10-2015, 11:07 AM | #45 |
Post Whore
Thank you Keith, I was totally thinking of you when asking that question, hoping you would see this thread and give us some factory know how, thanks again bud, really appreciate the feedback.
12-10-2015, 11:29 AM | #46 |
Maybe you can knock out the pins on the bottom and install a new Hurst handle? Or get the shifter parts to convert it to a bolt on type handle? Just a thought. I'm working late tonight but I should be able to get out my NP833 shifter and take some pics of how it's supposed to look.
12-10-2015, 01:24 PM | #47 | |
I always used a thin piece of aluminum on either side (a steel scale might work, too). Insert it between the shift handle and the inside of the base to defeat the clips and the handle should slip right out. It just snaps back in for installation. You could keep that blade base/snap in feature and weld whatever shifter handle you wanted to the top of it (like the factory did). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-10-2015 at 01:30 PM. |
12-10-2015, 07:14 PM | #48 |
Post Whore
12-11-2015, 08:46 PM | #49 |
When looking for this "stuff" I found two different styles of shifter mounting brackets and two different set's of shift rods/arms (beefier rods still attached to shifter)
MusicMan70 1961 GMC Suburban |
12-11-2015, 09:52 PM | #50 | |
Post Whore
Yep, I actually used the 1979-84 and 1985-86 Illustration Catalogs to identify 4 different styles, there's the 1981-83 CK version (which I think I have) identified by triangle hole in mounting bracket 1984 only CK version, identified by round hole in mounting bracket 1983-84 G version ( I wonder if G means Van or RV) 1985-86 CK and 1987 RV version (rather similar to the 1984 one) |
