Old 06-20-2015, 02:11 PM   #26
davepl
davepl's Avatar
Re: Starting issue
Cliff Ruggles wrote the book on these. Literally. There may be better but it was always my small-B bible for these carbs, and is likely still the one to get.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-21-2015, 02:41 PM   #27
kool1972
kool1972's Avatar
Re: Starting issue
Originally Posted by davepl View Post
Could you PLEASE pull and check the accelerator pump like I said 10 posts ago? 25 more posts of speculation won't help if you don't actually try the things the users are suggesting.
Thank you davepl. I pulled the accelerator pump and found the diaphragm wasn't attached to the plunger. It was also very soft. I expected this carb to be better than this considering I just purchased the carb rebuilt from autoline. I learned a very valuable lesson. Things can and will go wrong with rebuilt stuff. Sorry to offend anybody. I wanted to make sure this was the problem before I tore it apart. After spending the money for parts I installed the pump and the truck is running great.
I also ordered Cliff's book for the quadrajet carbs.
kool1972 is offline   Reply With Quote
Old 06-21-2015, 02:46 PM   #28
davepl
davepl's Avatar
Re: Starting issue
I'm just glad I could help. Sadly unless it's coming off the Rochester assembly line or from a reputable shop, the out-of-the-box-experience (OOBE) is often grim on rebuilt parts!
