07-13-2015, 10:51 PM | #26 |
Re: Clifford 6=8 products? Anyone using?
07-14-2015, 11:59 AM | #27 | |
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
07-14-2015, 07:46 PM | #28 |
I think Sissel is till doing it or was recently.
I've always wanted to do a 302 gmc with a crossflow head. there is an algon head on ebay right now but the $12,500 price tag puts it out of range
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
07-14-2015, 08:25 PM | #29 |
Way outta my price range. Lol
07-15-2015, 06:47 AM | #30 |
I built a 302 and it was in a 37 Chevy 1/2 ton for many years . Carefully assembled with Venolia 9.25 actual compression pistons, hotter cam, short tube header, SBC valves and springs fitted into a lightly ported head. It was a lot of expensive machine work to correct the usual GM sloppy factory machine work.
About 220 HP and 300 ft pounds of torque. The flathead Ford V8 guys were scared to of the GMC Spending 12 grand on the head and another 6 grand for parts might get 300 HP for a streetable engine. |
07-15-2015, 07:29 AM | #31 | |
07-15-2015, 08:31 AM | #32 | |
6 forged pistons for any 6 cylinder are about 100 each for Venolia, Ross, etc. For a 302 GMC very little is available ready made. There';s a number of cam grinders who will regrind your stock cam for less than 100 bucks. If you need new lifters, that's another hundred bucks. Main and rod bearings are 200 bucks.. You can go the slightly cheaper route with very heavy stock pistons and stock head and valves with more carburetion ,a cam and headers. And that will do if you're happy with 170 HP at 4000 rpm and decent low speed torque. People talk a lot of crap about these old engines making huge power.They confuse them with hyper expensive highly modified limited duration racing engines ..I've seen "normal" builds on the dyno and on the road and without spending a ton of cash ,the power is ok for vintage engines but that's it. |
07-15-2015, 12:10 PM | #33 |
Now that's pretty affordable. About 4k is my budget.
07-15-2015, 12:42 PM | #34 |
Well, that was in about 10 years ago but I believe the prices are still about the same.
I didn't like the available made in Mexico engine bearings and found older new stock Clevite 77...If you use custom pistons then use SBC rings. Changing over to SBC valves and springs required changes to the rocker arms to keep proper geometry. The stock GMC valves and retainers are not suitable for over 4000 rpm .This is easily done at home as is drilling and tapping the block for a full flow oil filter.Much stronger tubular pushrods are inexpensive. Old GMC's respond to all the same performance tricks used on a SBC so don't fall into the "they require special treatment" money trap. |
07-15-2015, 06:21 PM | #35 |
Thanks for the info. I'm thinking that the prices may have gone up some but maybe not to much.
07-16-2015, 12:07 AM | #36 |
Tony, 37 1/2 ton, 302, 4 spd sag with Overdrive tail housing, former regular on the Stovebolt? How are you doing?
'67 GMC 2500, 292, 4spd, AC |
07-16-2015, 06:10 AM | #37 | |
You have a 292 powered 67? |
07-16-2015, 12:04 PM | #38 |
I recall you picked up an El Camino after the '37, but sounds like you've had a few other vehicles since then.
I'm still driving the '67. The only thing I've done to it in recent years is put on the 17" aluminum Hummer wheels. To keep on topic, the 292 has a Clifford intake with Carter AVS.
07-16-2015, 02:46 PM | #39 |
The El Camino was a 4 speed V8 so we won't talk about it After that was a strong 261 Chevy 6 in my 50 Chevy PU. Then sold it all and got into old Jeeps...Now they are gone and I'm back in a Chevy with a 6...
