02-23-2020, 05:22 PM | #26 |
Re: "Burrari" my first project, 70 c10 swb
Here we are 4 years later and I now have a 6 month old baby girl, married, and this project has completely taken the back burner. Here's some photos of what has happened in that time and what I need to do next. Goal is to have it running by the end of this year and body work finished in the next 2.
Picked up a big rod lq4 6.0 liter from a chevy dismantling yard in Maine. Has about 175k miles on it, but in great shape, and ran fine before it was pulled. Pulled the 317s and took them to have a mild port/polish and new seals, springs, etc. Cylinder bores still had cross hatching, bearings looked good, swapped to an f-body pan. Bought the plans for tip and flip cab dolly. This was my first fabrication project and was a lot of fun. I'm no welder and have taken one 8 hour class at a local metal art studio. Turned out nice, and works really well.
1970 C10 Short wide -No Limit Pro-Tech Chassis 6.0 LQ4 / BW S480 Turbo 2004 Pontiac GTO, 419rwhp/378rwtq, -H/C/I/E, M6 2014 Cadillac CTS-V Auto Last edited by HellaciousA; 02-23-2020 at 05:47 PM. |
02-23-2020, 05:51 PM | #27 |
Painted the block, had a lot of trouble with getting good adhesion with the VHT engine paint, and I imagine it will start to flake after it's run-in for a while. Sent the cab off for sand blasting, thankfully no major surprises. Towed the cab to my work where I had it epoxy primed. And bought a bunch of aftermarket sheetmetal (hood, fenders, doors, core support). Which I regret doing, as the gaps are poor and are going to require a lot more work to get nice. Some progress on the motor My favorite part! Borgwarner S480 kit from KBracing, specifically made for the 67-72 C10. Had to mock it up after wrapping the hot side.
1970 C10 Short wide -No Limit Pro-Tech Chassis 6.0 LQ4 / BW S480 Turbo 2004 Pontiac GTO, 419rwhp/378rwtq, -H/C/I/E, M6 2014 Cadillac CTS-V Auto |
02-23-2020, 05:55 PM | #28 |
4l80e set up on my engine stand and starting installing the transgo hd2 shift kit. Found a broken accumulator spring, glad I went this far. Hopefully there's no other problems once I get it running. Shaving the firewall: Trans painted: Applied sprayable seam sealer to the cowl inner panel: Rust repair in progress:
02-23-2020, 05:57 PM | #29 |
More rust repair inner rockers:
Trans assembled: Inner rocker repairs complete, sprayable seam sealer applied: Fitting the aftermarket doors: And then I decided to shave the drip rails, which in retrospect really complicated things, should have left it alone:
02-23-2020, 06:00 PM | #30 |
After selling most of the stock parts, frame, engine etc, I pulled the trigger on the frame, which is a No Limit Pro-10. Took roughly 2 months to get, and took 8 guys to get it off the semi truck as we didn't have a forklift.
Porterbuilt hood hinges and a smooth cowl being mocked up: Pulled the cab back off and brought it home as there was no room to store it in the shop I was working at: More drip rail removal progress:
02-23-2020, 06:01 PM | #31 |
Drip rail shaving continued:
Fuel cap shaved: New cab corners:
02-23-2020, 06:05 PM | #32 |
And at this point is pretty much where things ground to a halt. The body shop I was working for wasn't working out, and I received a job offer to run a new shop, but they wouldn't let me work on my project. I had to tow the cab out of the old shop, and it sat in my side yard under a tarp for 6 months.
Then I decided to move and needed to get the truck back together as a roller again, so work continued: Installed the stall and married the trans to the engine: Bolted the sheet metal back on: Also installed the viking coilovers, but had to leave the brakes off as the roller wheels I have are too small. Motor installed: Had to throw the turbo back on: I then quickly discovered the turbo down pipe is hitting the passenger side upper control arm. At this point I had to pack to move and the project stopped.
02-23-2020, 06:11 PM | #33 |
So here we are, budget is pretty much tapped out as I need to save for a house to move again. I have a Holley Dominator, and nice aluminum radiator and some other odds and ends. I really need to get a driveshaft made, but here's where I am stuck in terms of the sequence of things.
I can't finish the body work myself as I am not skilled enough. I need to set the truck at ride height so I can set the pinon angle and take proper measurements for a driveshaft. Well to do that, I need the right size wheels, which I don't have, nor can I afford (planning on CCWs). Thinking of wheel diameters between 18-20", but I want to run at least 10-12" wide square setup on all 4 corners (hoping for 315 tires). Cab needs to then come back off so I can seam sealer and undercoat the underside. Then, it can go on for good. I figure at that point I can continue with trying to get the truck to start, stop, and steer. Then I need to buy a bed assembly and maybe drive it like that for a while to get the bugs sorted? Or should I just stick to getting the metal work done? I can't find a bodyman nearby who does side work and the guy who was helping me is 2 hours away. Here's some renderings of my end goal that I had done by Hermance Designs:
1970 C10 Short wide -No Limit Pro-Tech Chassis 6.0 LQ4 / BW S480 Turbo 2004 Pontiac GTO, 419rwhp/378rwtq, -H/C/I/E, M6 2014 Cadillac CTS-V Auto Last edited by HellaciousA; 02-23-2020 at 06:17 PM. |
02-24-2020, 10:23 PM | #34 |
Whoa nelly! What an update! No limit all the way man. It will be beautiful with any choice of color you go with. My preference would be the lighter gray with the bluish tint, in case you're asking.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
02-25-2020, 12:10 PM | #35 |
Nice work! I like #2, that tan looks nice. Are you planning on modding a 68 hood to fit the grill or does it just look that way in the image?
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
02-25-2020, 04:12 PM | #36 |
huge update. lol
i vote light grey/blue also. in that first pic of turbo/motor i thought... we're going to need a bigger motor that turbo looks huge. |
02-26-2020, 01:37 PM | #37 |
Sprayable seam sealer!! What the What?? Wish I knew about that......
I really like the cream color above man. Grey(including my truck lol) is really common at this point. But. The grey still kicks azz too. My .02 Nice build going here man. I'm in for the ride.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
02-27-2020, 12:12 AM | #38 | |
I think he had never rendered a 70, so yes he just used a 68 hood. I plan to run a 70 hood. I'd love to get this truck to be able to do 180+ mph top speed, just don't know how many people have done that. I also want to run some auxiliary coolers somewhere in the front end with some duct work in a custom front bumper. I have lots of ideas in my head that didn't show up in the rendering (I had no idea how expensive it was to have them done, so I just went with a basic 2 angle option).
02-27-2020, 09:59 AM | #39 |
Nice work and update. Life always gets in the way of hobbies both time and $$ wise.
I personally like #3 but you wouldn't go wrong with any of those. My idea of a project done well is you could cover it up and stash it away for 20 years but when you roll it out it's still cool. Kinda like a pair of jeans and t-shirt - never out of style.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
02-27-2020, 11:57 AM | #40 | |
06-28-2020, 07:27 PM | #41 |
I just can’t imagine moving during a build like this ? Hopefully someone offered you a # you could not refuse ? Anyway don’t underestimate your talent because it’s amazing ! I wish you all the best, have you bought any lottery tickets lately? I do hope you finish the truck and get a chance to see it’s completion..Jack
71 C-20 07 Magnum RT AWD |
