Old 11-14-2015, 02:45 AM   #26
whitels1
whitels1's Avatar
Re: 79 K20 Custom Deluxe - Goldy LS1
More progress this week, it was slow going but I managed to get some stuff done. Removed some rivets, fabbed up a cross member / spring hanger / pull point / winch mount. It's basic but it should be beefy enough. Moved the rear hanger for the front springs and did a rough mock up of the 52" springs.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 11-14-2015, 10:55 AM   #27
Greenlee
Greenlee's Avatar
Nice build! I love the videos.
Greenlee is offline   Reply With Quote
Old 11-14-2015, 12:32 PM   #28
whitels1
whitels1's Avatar
Thanks!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 11-15-2015, 12:13 PM   #29
Zane M
Coming along nicely!
I too love the videos, thanks for sharing.
Zane M is offline   Reply With Quote
Old 11-15-2015, 01:47 PM   #30
whitels1
whitels1's Avatar
Thanks Zane! I ended up moving the cross member forward.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 11-15-2015, 07:46 PM   #31
whitels1
whitels1's Avatar
Altered the spring pack, bolted up the axle and got the weight of the truck on it. I'm happy with it for now. I still have to get the cross member bolted in, new spring / shackle hanger bushing and alter the width of the shackle hanger, it's way to wide.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 11-29-2015, 08:40 PM   #32
whitels1
whitels1's Avatar
I missed a weekend due to a trip to Utah, but go back on it this week. Happy Thanksgiving to everyone! I removed more rivets and crossmembers, squared up the frame and started boxing the frame in the front area. I added a crossmember at the steering box for more support. Still lots to do....
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 11-29-2015, 09:57 PM   #33
Jake Wade
Jake Wade's Avatar
Awesome man! I like the way you DIY on everything you can, that's the way I roll myself. GREAT JOB
Jake Wade is offline   Reply With Quote
Old 11-29-2015, 10:20 PM   #34
whitels1
whitels1's Avatar
Thanks! DIY is the only way, save money, learn a lot, stand back and be proud of what you have done.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-01-2015, 09:33 PM   #35
MTCK
MTCK's Avatar
Awesome! How did I miss this one? Glad to see you hung on to this rig. Also I feel like you keeping your parts truck may help me make the case to keep mine.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 12-02-2015, 02:56 AM   #36
whitels1
whitels1's Avatar
Me too I didn't have the heart to let it go, so I made room for it.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-02-2015, 11:40 AM   #37
77K10Silverado
77K10Silverado's Avatar
Looking good bud!
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 12-02-2015, 02:50 PM   #38
whitels1
whitels1's Avatar
Originally Posted by 77K10Silverado View Post
Looking good bud!
Thanks!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-02-2015, 08:43 PM   #39
Jake Wade
Jake Wade's Avatar
Just curious, What do you do for a living?
Old 12-03-2015, 08:03 PM   #40
whitels1
whitels1's Avatar
The wife and I run a graphic design business. I don't have much time to work on the truck but I have some flexibility.
I picked up a stick of 3/4" .120 wall dom, drilled holes and burned it in.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-03-2015, 10:46 PM   #41
MTCK
MTCK's Avatar
Looks good. Going to need any gussets?
-Marcus
Project Plow Truck
Old 12-03-2015, 10:58 PM   #42
whitels1
whitels1's Avatar
Thanks! I wasn't planning on any. I feel like once everything is burned in and with the crossmember it should be good. Time will tell!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-07-2015, 02:40 PM   #43
whitels1
whitels1's Avatar
Figured I would get the engine / trans / transfer case mocked up so I can start building my crossmembers etc.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-07-2015, 08:01 PM   #44
Jake Wade
Jake Wade's Avatar
Why didn't you just use the factory shim plates to avoid modding the brackets? Were you concerned with the additional height? or would it just not work out with those.
Old 12-07-2015, 11:03 PM   #45
whitels1
whitels1's Avatar
Jake, they would not lay flat and the bars looked like they were going to hit the oil pan. In retrospect I could have modified and used them, but figured I would hold on to them for later on if I need them for something.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-21-2015, 08:09 PM   #46
whitels1
whitels1's Avatar
After further thought and with everything mocked up I will probably end up making some kind of bracket so I can connect the engine with the flywheel cover.
I did get the trans mounted into it's final location, I ended up having to make a spacer to mount the trans to the stock crossmember. I also replaced the body mounts so I can get an accurate Idea of how everything will fit together. I want to start mocking up the shifters and the mount for the transfer case soon.
Video.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-21-2015, 10:22 PM   #47
MTCK
MTCK's Avatar
Good update as always. Is that motor a 5.3 or 5.7? Should be fun when it's all together.
-Marcus
Project Plow Truck
Old 12-21-2015, 10:44 PM   #48
whitels1
whitels1's Avatar
Thanks Marcus, it's a 5.3 bored to 5.7.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 12-22-2015, 02:12 PM   #49
daddyjeep
daddyjeep's Avatar
A Graphic Designer than can fabricate and build hard core stuff.
I'm glad I'm not the only one. Most of the guys at work "can't believe a guy like me" built this. Just because I wear a shirt with buttons and use my brains and creativity to earn a living instead of my hands doesn't mean I don't have skills.
[IMG][/IMG]
daddyjeep is offline   Reply With Quote
Old 12-22-2015, 04:26 PM   #50
whitels1
whitels1's Avatar
Thanks, and good work on your jeep. Skills born out of necessity and turned into a hobby, I wouldn't have it any other way!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
