Old 09-19-2015, 03:23 AM   #26
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: New Radiator
Originally Posted by Z10 View Post
Andy,
I just replaced the cap that came on mine, because it wasn't holding pressure. Just keep an eye on yours. I replaced it and all is well.
I think you'll really like it. I just completed a 600+ mile trip in the Texas sun last weekend, and the temp stayed rock solid on 185.
Cool! Plan to use the old one I have now on it. It works great and looks good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-19-2015, 09:38 PM   #27
Andy4639
Old member
Andy4639's Avatar
Ok I got the old one out and put all the fittings on the new one. Made new aluminum brackets for the daul fans and mounted the radiator back in the truck. Fits good and is all plumbed except for the upper hose. I need a new one the old one is to small for the top radiator mount.
The old radiator was leaking bad, you can see by the pictures.
Decided it wasn't worth polishing it up since it will mostly be covered up with the mount.
I may go back and polish the top of it though later.
Anyone have thoughts on upper hose?
I may turn those top mount bolts around to. After looking at the pictures they need to be reversed to clean it up some.
Old 09-19-2015, 09:44 PM   #28
Andy4639
Old member
Andy4639's Avatar
Some more pictures.
I went to Lowes and bought 2 peices of flat aluminum to make the brackets. I think they turned out nice. I also took and filed the corners down.
Hope to find a upper hose tomorrow and finish it up. Then Monday I can start on the pinion seal leak.
Old 09-20-2015, 12:46 PM   #29
Andy4639
Old member
Andy4639's Avatar
Just drove it about 5 miles, so far so good! Never went past 188 on the scan gauge are the mechanical gauge which is about 190*
Old 09-20-2015, 02:27 PM   #30
Kaptain Kadian
Kaptain Kadian's Avatar
Re: New Radiator
What are you using to wire your fans in? What temperature range is your fan thermostat too? Looks really good.
Kaptain Kadian is offline   Reply With Quote
Old 09-20-2015, 03:20 PM   #31
Andy4639
Old member
Andy4639's Avatar
Fans are wired through the ECU I don't know the exact temp they come on at. I'll have to ask. I have the one fan hooked to the AC switch so it run's the whole time the AC is on.
Old 09-20-2015, 06:55 PM   #32
Shon
Re: New Radiator
190 on 185 off. (looked at your tune from the time I grabbed it when I came to look at the settings for you)
can you tell me how to wire up the fan to run when the AC is on?
Thanks!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-20-2015, 09:06 PM   #33
Andy4639
Old member
Andy4639's Avatar
Thanks!
Shon you can do it several ways.
I have mine hooked up to the compressor hot wire that triggers the relay for the extra fan. I have 3 fans on mine. The one hooked to the ac only runs when ac is on. It's in front of the radiator.
Drove about 50 miles over to a small cruise in tonight and it ran fine no leaks and it never got over 190* with the AC running.
Old 09-25-2015, 08:49 PM   #34
Kaptain Kadian
Re: New Radiator
Does your factory top radiator support brackets still hold it tight enough? I ordered a different aluminum radiator, but looks exactly like yours and the top brackets don't seem to put much of a grip on the new radiator. The top of it is definitely different than the stock one.
Old 09-25-2015, 09:55 PM   #35
Andy4639
Old member
Andy4639's Avatar
I don't use the top factory mounts just the metal you see in the pictures. I bent it down so that it keeps the top pulled in tight against the foam sandwiched between the support and radiator. The foam makes the air pass through the radiator instead of going around it. Cools better.
Old 09-25-2015, 09:57 PM   #36
Kaptain Kadian
Re: New Radiator
Where did you get that metal? Thanks
Old 09-25-2015, 10:24 PM   #37
Andy4639
Old member
Andy4639's Avatar
I had a local metal shop make mine. You can buy them though also.
Here is a link to LMC part # for it.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=127
