#26 |
![]() Join Date: Jul 2015
Re: POR-15 Opinions
That Mastercoat product seem to be a good value, I would like to know how well it holds up in everyday conditions over time.
#27 |
Re: POR-15 Opinions
Should you use a respirator when brushing on?
#28 |
Moderator
![]() Join Date: May 2007
Re: POR-15 Opinions
Yes. If you can smell it, your lungs are feeling it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#29 | |
![]() Join Date: Feb 2009
Re: POR-15 Opinions
Say Mr. SpecialK, what grit was your final sanding on the metal surface, for that Master Series? They suggest 80 grit. Seems a little rough. Other: Definitely wear a respirator to brush on. If you spray it, or as someone else said paint in general, always a respirator until the fumes clear.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-08-2015 at 12:46 AM. |
#30 |
Re: POR-15 Opinions
Lockdoc nailed it. Also use eye/face pro or you'll have black paint spots on your face for a week
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#31 |
Re: POR-15 Opinions
Has anyone ever POR15'd their rusty truck bed floor?
#32 |
Moderator
Re: POR-15 Opinions
POR works when applied directly to rust...but who wants scale and a "lumpy" finished result? Strip it down and use the metal ready prep which GRX mentioned above. It leaves a phosphorus coating, seals the surface, and gives the POR something to grab. The marine clean is by far the best degreaser I have ever used, it will put simple green, purple power, and gasoline to shame when it comes to removing caked on grease. I suspect it is bilge cleaner, as it's name suggests, and can be bought for less as such.
#33 | |
Re: POR-15 Opinions
#34 |
Moderator
Re: POR-15 Opinions
If you purchased master series, roll with it. You can't go wrong with it from what I've read, I've used POR for 20 years and can only relay personal experience with it. I've sourced it locally from the same vendor. They are probably the same thing.
#35 |
Re: POR-15 Opinions
It is used to re-paint hiway bridges. The owner was a chemist for POR-15, but when they cheapened the formula he quit and started this company to produce a superior product. He's not the biggest well know one, he's the best.
#36 |
Re: POR-15 Opinions
nothing is too rough. These products are designed to coat over rusted/pitted metal, is self leveling, and will actually help smooth such surfaces. I use it on sandblasted metal and it's smooth as glass, so scuff marks from coarse paper is no issue
#37 |
Re: POR-15 Opinions
learn something new everyday . never herd of master coat. sounds like good stuff. i have been using chassis saver for years. and i know por 15 and chassis saver has no uv protection. so in a bed it will dull out thru the years.
#38 |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: POR-15 Opinions
UV is a consideration. I did the back window on a Pontiac and the areas where the sun could hit it did not fare well. Pay attention to POR's instructions on this. It must be top coated.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#39 |
Re: POR-15 Opinions
Good information and thanks. Looked up the Master Coat. Another Master Series product, "similar" to POR15 Rust Preventing. I bought the Master Series primer and top coat. May not need the Master Coat, pending fender/cowl removal.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#40 |
![]() Join Date: May 2013
Re: POR-15 Opinions
POR is great stuff for rusty metal , if you have cleaned it already ,and its smooth,or will be exposed to direct sunlight ,, Id use mothane
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#41 |
Re: POR-15 Opinions
I had heard of drilling the holes in the lid and using sheet metal screw to seal them, but the instructions say not to shake the paint but to stir it so as not to cause air bubbles. How do you mix it up when all you can do in pour it through the holes?
Am I missing something? |
#42 |
Re: POR-15 Opinions
I shake the snot out of it. It pours out a little bubbly. I smear it on with those cheapy sponge brushes and it smoothes out ok. I'm not looking for a deep lustrous shine.. JK, it looks ok, the bubbles go away as it dries. I've never applied it to a big flat area. I use it on little brackets & stuff I make or modify.
I laughed when I saw that cdowns had posted almost the same thing I did at pretty much the same time yesterday. Florida thing I guess.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
#43 |
Re: POR-15 Opinions
Something like $100 gets you two quarts of Master Series primer and one quart of satin black top coat. They say that will cover the chassis. Two coats primer, one top coat. You don't even have to top coat, if you like silver or gray. I think it's silver.
#44 |
![]() Join Date: Apr 2015
Re: POR-15 Opinions
Im A big believer in the POR-15. its expensive but it will last u a very long time threw out the elements.. We & I used it for count less thing in Alaska, the ship guys like it to.. when your paying big buck for thousands of dollars of equipment. its good to have a product that works...
#45 |
Re: POR-15 Opinions
i've used it in the truck bed but because the bed was open to sunlight it had a shorter lifespan due to the ultraviloet exposure
#46 | |
Re: POR-15 Opinions
2- If they did the strainer will get them
#47 |
![]() Join Date: Jun 2009
Re: POR-15 Opinions
I know, this is an old thread. Locdoc hit the nail on the head but I bought my gallon of por15 in 09 and it is still good. The lid has never been popped, I punched two holes in the lid as soon as I started using it and run two metal roofing screws in the holes, they are a 1/4" driver head with a rubber washer on them that seals. And with todays impact drivers it is not an issue getting them back out.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#48 |
![]() Join Date: Nov 2006
Re: POR-15 Opinions
Nothing wrong with reviving old threads, they often contain gems of wisdom that might otherwise be overlooked by members later to the forum.
I use a product called Trailercoat, discovered it back in the late '80's searching for something to use on a boat trailer regularly dunked in saltwater. The axle had gotten very rusty. I used a combination scraper/wirebrush to knock the loose stuff off and gave it two coats. After eight years of saltwater and salt sea air exposure it finally started to discolor a little here and there. Dries tough and hard. A bit expensive (last one I bought was about $35 /quart) but it has proven itself to me (and a number of others I've recommended it to). The only "drawback" I can see is that it is silver colored, but it does lend itself to topcoating. http://www.pettitpaint.com/product.asp?id=96 I tried POR 15 once and was ultimately disappointed. Probably didn't jump though all the hoops it requires, but did use it on a very clean, well prepped surface-----most rattle can paint would have lasted longer, in my judgement. Very little exposure to the elements, always garaged, and it eventually cracked and peeled. I did not use any primer under it. |
#49 |
Re: POR-15 Opinions
Well thought I would give an update on my por-15 that's been in use now for over 2 years. I applied 2 coats to the underside of my wheel tubs. I live on 4 mi of gravel, that's 8 mi every time I drive it. This stuff is holding up real well. Not chipping, flaking, or peeling. And my tires are rock throwing sonsabiches.
While there are some comparable products as mentioned out there, if it ain't broke, don't fix it. I would buy this all day long. I also did inside and out on my cab floor after repairs. Didn't discover this though, till long after my chassis was done. Future project maybe.. Hope this helps someone...
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#50 |
Re: POR-15 Opinions
Since POR-15 doesn't have UV protection is it necessary to top coat it on frames, axles or trailing arms? They are out of the direct sun light.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
