11-30-2015, 08:06 PM | #26 |
Re: 67 C10 "Green Gobblin" straight from the field!
Heres a few updates! I got the cab front end torn down and off the trailer. I had a few scary moments lifting it with my engine lift and straps! ( not recommended!!!) I modified my rotissorie to fit the cab so Now she's spinning and i can get a good look at the underside. Its pretty bad so i ordered up a complete floor/rockers/cab corners.
11-30-2015, 08:16 PM | #27 |
A few more
11-30-2015, 08:18 PM | #28 |
Nice work man!
Keep the updates coming |
11-30-2015, 08:23 PM | #29 |
More rotisserie! Plus a few pics of the nest that was in the heater core area! One thing i hate is digging out nests!!! If my wife or kids ever saw this they would never ride in this truck!!!
11-30-2015, 09:31 PM | #30 |
You planning on a Vintage air unit?
11-30-2015, 10:06 PM | #31 |
12-02-2015, 12:21 AM | #32 |
Curious how you came up with your balance point on the rotisserie mounts in the door jamb? i see the povot is forward of center. And can i assume the forward point is also bolted using the top door hinge mount?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-02-2015, 01:07 PM | #33 |
I just placed the pivot point in the center of the cab and not center of the door. the forward point is just below the upper door hinge. I didn't spend to much time trying to create a balance point as i just wanted to flip the thing over! Its still a little firewall heavy but I'm hoping it will balance a little better once all the dash and steering column is out. Heres a quick pic of the door bars i made to match up to my existing rotisserie. ( pretty simple )
12-02-2015, 02:38 PM | #34 | |
I grew up in Iowa, North Dakota may not be the place for needing A/C, I keep forgetting.... Keep up the great work!!! |
12-03-2015, 05:22 AM | #35 |
Thanks for the pic!
12-29-2015, 08:58 PM | #36 |
Finally got a chance to sit down and give you guys some updates! Since I'm waiting on my parts order i dug into the 72 parts truck. Heres a few pics! its a 72 lwb custom with the original 350/350. Apparently ran and drove until the previous owner had a carb fire and he gave up!
12-29-2015, 09:14 PM | #37 |
Ok now for the good ole burnt up 350! i figured it was a total write off and if nothing else it would be good for a rebuild. After i stripped away and swapped out all the burnt up stuff like Dist, wires, carb, hoses and drained out about 10 litres of oil and water and popped in a new set of plugs she fired up and ran like a champ!!! Oil press was 50psi at start up and 30psi warm. I gave it a compression test and was at 130psi on every cylinder! It passed a leak down and its going to be good enough to clean up and slap into the Green Goblin!
12-29-2015, 09:24 PM | #38 |
Now with my new found motivation since the motor runs i stripped the rest of the truck down to see what i might be able to use. Other than all the 5 lug swap parts i will need the dash and part of the firewall.
12-29-2015, 09:30 PM | #39 |
Since its getting cold and the snows piling up i figured id grab the firewall before the whole trucks buried! Thats about it for the 72!
01-05-2016, 08:22 PM | #40 |
Ok I finally got my parts!!!! Thanks LMC and summit! New floor, rockers, cab, corners, fender skirts, Rad support, basically all the metal to do this job is here Plus a ton of misc stuff out of the LMC Catalogue! A nice pair of 15x8 6 lug wheels and all the Heater box,core and controls from a few fellow board members. I actually think i might have ordered to much stuff as I'm running out of room to work on it now! But my kids happy with all the boxes!!!
01-05-2016, 08:29 PM | #41 |
Heres a few pics of the floor and firewall. I gotta say the floor is a nice piece! if anybody is thinking of doing a lot of floor work this is the way to go!
01-05-2016, 11:42 PM | #42 |
Wow! That is some haul of parts! Looks like you will be pretty busy!
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
01-06-2016, 03:03 AM | #43 |
Who did you get the floor and firewall from if ya don't mine my asking? Great news on the engine too!
01-06-2016, 09:33 AM | #44 | |
Posted via Mobile Device |
01-06-2016, 04:23 PM | #45 |
Looking good, love the forest green on the 67's are you planning on keeping the patina green if possible or repainting it?
01-06-2016, 04:54 PM | #46 |
Keep the progress coming.
01-06-2016, 07:23 PM | #47 |
Truck looks a lot like mine! I'll be along for the ride. Just for s***'s 'n gigs did you pick up that parts truck from somewhere up in the great wide manitoban north?!
My 68 Build http://67-72chevytrucks.com/vboard/s...=1#post7272324 Herb! My C30 build http://67-72chevytrucks.com/vboard/s...80#post7304180 |
01-06-2016, 09:23 PM | #48 | |
The plan is to keep the patina as is and build the truck as a safe/fun driver for me and my kids. I'm fixing all the underside rust and a few ugly spots like bottom of fenders/box and blend them out to match the rest of the truck. I will redo the interior to keep it Clean and simple so the wife might even want to ride around in it!? |
01-06-2016, 09:38 PM | #49 |
Wow Sicksty8 I just checked out your thread and ya they look like twins! And yes i picked up the orange 72 parts truck and my green 67 from Manitoba! That's why there's so much rust! Lol
01-06-2016, 11:40 PM | #50 |
That's pretty funny because I'm pretty damn sure you beat me to buying that 72! Yeah almost every truck I've checked out here in manitoba has a crapload of rust. I'm also just a bit jealous of your parts pile Looks like fun!
