Old 03-01-2016, 09:54 PM   #26
Zane M
Re: A K5 Cummins Conversion: The saga continues...
Awesome work! Can't wait to see future progress!
Zane M is offline   Reply With Quote
Old 03-02-2016, 12:46 AM   #27
COS399
COS399's Avatar
Nice work. A lot of information in so very few posts. Keep it up and keep us posted.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 03-02-2016, 03:24 AM   #28
MaxPF
MaxPF's Avatar
Thanks!
Thank you! Stay tuned, there's still more to come!
1991 V1500 Blazer (Silverado), 5.9L 12V P-pumped Cummins (5x .012 sac injectors, #6 fuel plate, WH1C with external 38mm wastegate running 30psi), NV4500 with 1-⅜" input shaft, SBC Con-O clutch, NP205, HAD, 4.10 D61/14BFF spinning 37" Nitto Exo's
"I got a shotgun, a rifle, and a four wheel drive and a country boy can survive."
MaxPF is offline   Reply With Quote
Old 03-04-2016, 11:52 AM   #29
BigBlockBurris
BigBlockBurris's Avatar
Thank you very much for taking the time to post all of that great info!
What is that fan off of?
Thanks!
BBB
BigBlockBurris is offline   Reply With Quote
Old 03-05-2016, 12:13 AM   #30
MaxPF
MaxPF's Avatar
You're welcome! Hopefully some of it can be of use to others who are contemplating a Cummins swap in a swuare body.
Navistar 1614237C1
Poke that part number into Amazon or Ebay (or a search engine for that matter) and you should get some hits. It's 22" in diameter and about 2-1/4" wide. I've already cranked it up and even at idle it moves a butt-load of air!
Old 03-10-2016, 04:55 PM   #31
ERASER5
ERASER5's Avatar
Navistar 1614237C1
Is that a British butt-load, metric butt-load, or Standard butt-load?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-11-2016, 12:33 AM   #32
MaxPF
MaxPF's Avatar
It;s a butt-load by ANY standards!
Old 03-11-2016, 09:30 AM   #33
ERASER5
ERASER5's Avatar
See I would have gone with metric sh...ton butt-load. To be precise.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 04-06-2016, 11:37 PM   #34
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Max awesome build! I started reading it when you originally started posting it but I was having issues getting the pics to load. They still show just x's right now. Stupid computer.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-07-2016, 12:32 AM   #35
MaxPF
MaxPF's Avatar
That's what you get for running Internet Exploder
Serious mode on: Has anyone else had issues with pics loading?
Old 04-07-2016, 09:53 AM   #36
84chevyguyid
I use firefox, they load ok but they take a while with my lightning fast 1m internet connection.
84chevyguyid is offline   Reply With Quote
Old 04-07-2016, 03:13 PM   #37
Dieselwrencher
It very well could be IE causing the problem. Junk stuff.
Ryan
Old 04-08-2016, 03:37 AM   #38
MaxPF
MaxPF's Avatar
I use Dropbox to host my pics. It's less of a PITA vs Photobucket, but they do throttle the bandwidth pretty heavily.
Old 04-16-2016, 11:21 AM   #39
ryanroo
ryanroo's Avatar
In that last pic you can see the turbo is assembled and mounted to the manifold. I had the turbo rotating assembly balance-checked at the turbo shop and it was perfect, so there were no show-stoppers. The last minor doo-dad I made for the turbo setup was an AN drain fitting for the block. The stock drain is simply a pressed in pipe, and I wanted to use -12 AN, so I turned down a -12AN male to male pipe, pressed a piece of 3/4" OF steel onto it, and ended up with a fitting that would press into the block and give me the -12AN drain port that I wanted:
At this point the engine was ready to mount into the truck. Things like accessory mounts were still needed, but I wanted to put the engine in the truck before I designed the mounts.
Stay tuned for the next episode appropriately titled
subbed, and idea stolen.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-17-2016, 12:42 AM   #40
MaxPF
MaxPF's Avatar
Thief! I want my idea back!!!
Old 07-10-2016, 01:47 AM   #41
1972K20
1972K20's Avatar
Good looking build with attention to detail!
What front springs are you running?
1972K20 is offline   Reply With Quote
Old 09-02-2016, 03:47 AM   #42
MaxPF
MaxPF's Avatar
So, last time I updated the thread I was about to get some exhaust going. It's just your basic 3" aluminized system,starting with a downpipe:
I decided to reuse my Magnaflow muffler:
It really tones down the exhaust and eliminates any in-cab drone despite being a straight-through design:
Complete exhaust system:
Gotta wrap the downpipe to keep the heat down:
A few installed pics. I had to route the exhaust on the outside of the trans crossmember due to lack of clearance inside:
And, of course, the honkin' 4" tip!
Old 09-18-2016, 03:40 AM   #43
MaxPF
MaxPF's Avatar
Since the exhaust was now good to go, I needed some intake plumbing. I was leery of all the Chinese silicone couplers out there, so I opted for Gates couplers used for MD/HD trucks and equipment. I got simple straight couplers that I could cut to length for areas where little flex was needed:
I also needed one flexible coupling on each side, so I got a pair of ring-retained hump hoses:
Note the "Made In USA" on the hoses I also got some constant-tension t-bolt clamps to retain the hoses.
I also needed tubing. Some of the stuff I found was ridiculously expensive. I ended up using Chinese aluminum u-bends because I could actually afford them. I made a simple bead tool to put a bead on the ends, and after some , , , and I ended up with these:
Starting at the turbo:
Through the core support:
Into and out of the intercooler:
Back through the core support:
Around the extra-wide diesel radiator, which other swappers assured me COULD NOT be done:
A hump hose mid-pipe:
And finally into the intake elbow:
I had to use regular hose clamps here because the constant tension clamps were too wide. In case your wondering, yes, it does clear the master cylinder. Barely:
There was one other minor thing I wanted before I threw the batteries in and took it for a spin. I wanted a place to tee both positive battery cables off to the starter. A piece of Delrin, a 3/8" Allen bolt, and an hour of lathe time later yielded this:
It's mounted to the front of the drivers side battery tray stand. Following that was some uninteresting and still unfinished wiring and installation of the air cleaner (which I lost the pics to somewhere ), and it was ready to drive! Yay! So, how did that go? Stay tuned to find out...
Old 09-18-2016, 07:16 PM   #44
notchbackgta
I would like to see your bead tool. They are usually pretty expensive to buy and I will need one eventually
notchbackgta is offline   Reply With Quote
Old 09-19-2016, 12:37 AM   #45
MaxPF
MaxPF's Avatar
I will have to see if I have a pic of it. It's seriously redneck, but it gets the job done.
Old 09-19-2016, 04:57 PM   #46
Dieselwrencher
Man, I still can't see yor pics even with google chrome. Is your bead tool a modified 3 jaw vice grips?
Ryan
Old 09-20-2016, 11:13 PM   #47
MaxPF
MaxPF's Avatar
Do you have Dropbox blocked? That's where my pics are hosted.
Old 09-21-2016, 05:00 AM   #48
MaxPF
MaxPF's Avatar
So, the initial drive showed a few issues. Most were simple fixes of minor things, but one major problem was a random failure to crank. I had a starter relay mounted on the fender. and from that relay a 14 gauge wire snaked down to the starter along the main battery cable, a distance of perhaps 7-8 feet total. It seems this length of 14 gauge had too much resistance and gave marginal voltage at the starter solenoid terminal as well as some heating of the wire.
The immediate idea for a solution was to run a larger wire, but that meant threading a 12 or 10 gauge wire through an already-mounted loom. Instead, I close to eliminate the relay from the fender and connect the ignition switch start wire directly to the wire going to the starter. I then moved the relay to the frame rail adjacent to the starter, and used the starter wire going to the starter to instead actuate the relay. The relay switches power directly from the main battery terminal on the starter, protected with an inline fuse, to the solenoid terminal when the key is in the start position. The wire on the fuse holder is 12 gauge, while the other wire is 14 gauge. Since resistance increases with length, and the wires are kept very short with this arrangement, there have been no more failure-to-crank issues. Here's some pics before I put convolure tubing over all the wires:
I put a reverse-biased 50V Schottky diode between the starter wire and the ground wire. When the relay opens, the energy stored in the magnetic field of the solenoid has to go somewhere. Normally, it arcs across the relay terminals as they open, which will eventually cause the relay to fail. The diode allows the reverse current to travel harmlessly to ground with no arcing, where it is dissipated as heat in the solenoid winding.
Here's the installed relay and fuse:
This setup engages the solenoid without fail, even when the batteries are too weak to give more than a half-crank to the engine. The weak batteries were caused by my alternator losing a diode, which is a story for later time .
Old 01-31-2017, 01:16 AM   #49
MaxPF
MaxPF's Avatar
Quite a bit has happened since the last update. I have been chasing an intermittent bump-induced driveshaft vibration for several months. Despite rebuilding the CV and replacing the output bearings in the t-case the vibration persists. :gaah: I will get it figured out one of these days.
My batteries finally went Tango Uniform I was originally set on running a pair of group 24 flooded deep cycles because, frankly, I believe properly maintained QUALITY deep cycles will outlast AGMs. However, that plan got thwarted when I discovered that Sam's Club had group 34/78 Deka AGMs (labeled Duracell) for only $105 during a Christmas sale!
Sign me up on that deal! I eventualy plan on moving the batteries out of the engine bay and into the rear of the truck, so hopefully getting them out of the engine bay heat will increase their lifespan. When I do that I will make the battery boxes capable of accepting group 31's.
Not long after that my third Autozone alternator decided to windmill the pulley and spit the belt off. Swell. At this point my option was to fix the pulley and keep running the Zoner alternator, or put this in it's place:
I scored a pair of these off of Ebay for $165 each. Normally, these are $525 alternators, but these had been dropped and had broken back covers and some dings, hence the discount.
$525 you say?!?! Why so expensive? Simple answer:
This alternator can crank out 240A CONTINUOUSLY. And they are made in USA. Unlike mere mortal alternators that have six rectifier diodes that are heat-sinked to the case, these bad boys sport 12 rectifiers in their own heat sink, which is still mounted to the case for further head sinking.It also has dual fans:
I ordered new rear covers for them, as well as an 8 rib pulley and a 7 rib pulley. They 8 rib pulley is for mine, while the 7 rib pulley is destined for Todd's Jeep. These alternators have 7/8" shafts, and it seems 6 rib alternators are not made for that size shaft, so the 7 rib jobbie will be used on the LS motor with it's 6 rib belt. Here they are, ready to go:
10 hours of machining and wrenching later, I ended up with this:
What is not noticeable in the above pic is that the AC hoses and lines are gone. This was pre-planned even before the alternator debacle. I evacuated the refrigerant and capped the compressor, condenser, and receiver. In the next few days I will remove the glower/evaporator box from under the hood and the HVAC box from under the dash. This will get replaced by a unit that fits entirely under the dash. The purpose of removing the factory HVAC stuff is to make the room needed to fit the HE351VE variable geometry turbo that I have acquired Not to mention I have always disliked that crap cluttering the engine bay. It will also make room for another item I have just ordered, but I am keeping hush-hush for now
Old 01-31-2017, 01:18 AM   #50
MaxPF
MaxPF's Avatar
But wait! There's more! Another item on the to-do list for the New Year was new tires.
I had originally intended on running the same 37" BFG KO2's that Todd is running on his Jeep. However, perusal of the reviews on this tire revealed a disturbing trend; it seems they wear rapidly when they are on a heavy vehicle. I had already noticed the weight on the front end of my truck has not been kind to the 35" KO's I was running, and I most certainly did not want to pay $1500 for tires that would only last 20,000 miles. :whaa:
A buddy of mine with a Cummins-swapped old-school Suburban had the same issues with KO's and ended up switching to Toyo M55's. The M55's are designed for heavy trucks that routinely run down unpaved roads, so they are tough and designed to wear well. My buddy has been running them for over three years and has nothing but praise, so I was sold. Sadly, the biggest size available is 33" and I want 37's So, I did some more looking. As it turns out, Toyo's sister company Nitto recently introduced a new tire geared toward the same type of use as the M55. It is called the Exo Grappler AWT, and unlike the M55 it is available in a 37" version. 37x13.5x17 to be exact, so it is an inch wider than the typical 37" radial. It's E load rated, and guys running them on 3/4 and 1 ton trucks report 30,000+ miles with plenty of tread left. And, they only cost $15 more per tire vs the BFG's. Sounds good to me, so I had Discount order a set of four. They arrived in due course, and looked better in person than on Nitto's web page:
Mounted on my H2 rims:
Like the KO2's, the Exo's are severe snow service rated, which will come in handy during those December hunts when a snow storm rolls in:
Here's the tread:
And finally, installed on the truck:
So far I have put about 100 miles on them, and they are night and day compared the the 35" KO's they replaced. They are responsive, and despite their E load rating they soak up the road bumps better than the BFG's they replaced. They are also smoooooth, which I attribute both to the quality of the tire and the 10oz of Dynabeads in each tire instead of conventional balancing. It will be interesting to get them off-road and see how they work and how they wear, but so far I like 'em a lot.
One side benefit is that the 37" tire actually improves my gearing. The engine seems happier cruising down the freeway, and I no longer need 5th gear on the surface streets. It will be interesting to see if/how much my fuel economy is impacted by the new rubber.
