Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-01-2016, 02:17 PM   #26
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Moog 81114 Front Springs
Well I'm sold!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 06-01-2016, 11:38 PM   #27
pistonbroke800
pistonbroke800's Avatar
I might just grab a set too. Pretty cheap mod to try.
pistonbroke800 is offline   Reply With Quote
Old 06-01-2016, 11:52 PM   #28
Jrgunn5150
Yeah, they're like 80 bucks on Amazon lol.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 06-05-2016, 06:01 PM   #29
383 Stroker
383 Stroker's Avatar
You can buy them off Ebay for $42 with free shipping...
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 06-30-2016, 01:49 PM   #30
Willyk
Willyk's Avatar
What rear springs are you running 383?
1968 Chevrolet c10
360ci, promaxx heads, victor jr, comp solid lift, scat rotating, Srp pop ups, nx plate.
Factory 12 bolt 4.56 gears and mini spool.
Stock trailing arms, 29.5" m/t.
Best 1/8 mile ET: 6.88' @ 98mph 1.47' 60ft.
Willyk is offline   Reply With Quote
Old 07-14-2016, 09:13 PM   #31
BillyT
Great info for those of us just about to put drop spindles in and need springs
Thanks for sharing guys,
Billy
68 Custom SWB
BillyT is offline   Reply With Quote
Old 07-21-2016, 10:51 PM   #32
dinnut
dinnut's Avatar
I actually just installed the 81112 moog springs. They are the same as the 81114 but a bit shorter. I also have 2.5" drop spindles in the front. Once they settle it's probably gonna be a little too low . but my truck is real nose heavy (iron headed big block). Its going to have an aluminum headed engine soon so hopefully it picks up some
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 07-27-2016, 10:50 PM   #33
c-man405
Originally Posted by 383 Stroker View Post
I installed them on a friends square body. Its a small block truck with stock spindles.
Would it be possible for you to measure the ground to fender lip? I want to try these but don't know how much they will affect the ride height. Also what's done do the rear suspension?
Thanks for any information.
c-man405 is offline   Reply With Quote
Old 07-28-2016, 06:38 PM   #34
c-man405
Also I should add how have they changed weight transfer and street driving?
Thanks again Carter
Old 07-29-2016, 08:21 PM   #35
dustin72
dustin72's Avatar
I've had the 81114's on my truck for a few months now, and they haven't settled much at all since I installed them. That's with a bunch of racing too, so I don't expect them to settle any more.
dustin72 is offline   Reply With Quote
Old 07-31-2016, 08:27 PM   #36
dinnut
dinnut's Avatar
Mine settled in on the first test drive but have seemed to stay about the same since. My engine is hurt so no racing here for a while
70 longbed
496/th400/Ford 9"
Old 03-25-2020, 04:43 AM   #37
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I just installed these POS in my 72, it has the 2-1/2" drop spindles with factory 1/2 ton coils with 1/2 coil sliced off. I bought these things like three years ago when I read this thread knowing some day l would install them. Well that day came last month while my 427 was being built. I had a hell of a time getting that POS Moog spring in! I had to use a chain come along and clamp to get the ball joint started! Once tightened up it was obvious that spring was WAY to long! Compared to the factory coil it was 4 inches longer so I sliced a total of three coils off the damn thing and reinstalled it, looked good and fit good and was still one coil longer than the factory coil...I dropped the 427 in yesterday and down she went until it it bottomed out! Just the weight of the motor collapsed those springs to the stops! I don't know how in the hell anybody can be running these full length, cut, or otherwise in a 67-72 factory front end! These 81114 Moog POS are going in the scrap barrel! Live and learn I guess...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-21-2021, 08:23 AM   #38
Chadwi
Anyone else have info on these? I would like 2" lower than stock on a 66 C20 w/sbc. Sounds about right with the 81114's
Chadwi is offline   Reply With Quote
Old 04-16-2022, 12:51 AM   #39
DocZz
Sounds about right, these springs are about half the rate of stock spings and will require banding to install. They allow generous front end rise for a given power input but body roll is also exaggerated.
DocZz is offline   Reply With Quote
