Old 01-09-2022, 10:03 PM   #26
77chris03
77chris03's Avatar
Need to set shim depth and seal the front up. Sst shifter relocation done. Stage 2 build done. Clean up and paint next.
77chris03 is offline   Reply With Quote
Old 01-10-2022, 09:30 AM   #27
SCOTI
SCOTI's Avatar
Re: New 68 Stepper Build...IM BACK!!
Nice group of parts. Will be on the look-out & watch your progression.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-10-2022, 10:19 AM   #28
77chris03
77chris03's Avatar
Totally forgot to put the speedo gear on. SMH. But then again my motorcycle transmissions don’t have speedo gears
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
Old 01-14-2022, 07:44 PM   #29
77chris03
77chris03's Avatar
got some more little parts in. got the wilwood flex lines and adapters in. next to weld the tab and position where it needs to be.
Transmission is done with the exception of being painted aluminum. Complete LT to LS conversion, Stage 2 650hp build, and shifter relocation.
Old 01-14-2022, 10:51 PM   #30
77chris03
77chris03's Avatar
Ive picked my color for the truck. Arctic Blue Metallic. havent decided yet but might throw a little bit of crystal blue in the clear.
Old 01-16-2022, 04:00 PM   #31
77chris03
77chris03's Avatar
ANYONE HAVE WHAT I DONT HAVE? AT THE BOTTOM OF THE LIST
Specs and current progress.
Engine 95% done waiting on DYNO run Race Engine Development built
2001 LQ4
.030 over diamond LS1 comp series pistons
Compstar 6.125 LS H beam rods
LS6 243 Heads
Stock LQ4 crank, balanced and polished.
Comp Cams 54-444-11
CamComp Cams 13702-KIT
Comp Cams 850-16
Comp Cams 26925TS-KIT .660 lift
Holley valley cover
Holley mid engine drive 20-185bk
GM F body pan and windage tray
Melling HV oil pump
TSP hidden valve covers with LS7 coils
Holley 300-132 intake
Holley sniper efi 550-510D
Speed Engineering Long tube Headers
Speed Engineering SBC to LS engine Plate
Energy suspension motor mounts
Stock GM starter and all GM sensors
Transmission 100% done
97 Camaro T56 Fully converted to LS
Tremec LS bellhousing
Tremec LS mid plate
Tremec LS input shaft
Carbon fiber Syncro rings
New Aftermarket 3, 4, 5, 6 and rev gears REM finished
Tremec 1/2, 3/4, 5/6 and reverse syncro assy.
New aftermarket countershaft REM finished
Billet keys and brass sliders
All new Timkin Bearings
SST Shifter relcation Kit
Energy Suspension Trans mount
McLeod slave cylinder
McLeod 75357 Clutch kit (LQ4 long crank kit)
Frame and suspension/brakes
1967 specific OEM short box frame (titled 1968)
QA1 front Coilover conversion kit
QA1 rear Coilover conversion kit
HPI customs frame brace
QA1 front and rear sway bars
Wilwood Dynalite rear disc brakes with e brake
Wilwood rear 10" flex brake lines
Wilwood Superlite front disc brakes
Wilwood ProSpindles 5x5 pattern
**1967/8 GM 12 bolt**
Moser 30.50" axles 5x5Detroit
Truetrac posi Richmond Gear excel ring and pinion 4:10 ratio
Moser 7111 dif cover Inline Tube full stainless brake line kit
Tanks Inc under bed fuel tank
Tanks Inc fuel pump
Body - Have these and at blaster
1968 titled CST air cab
1968 OEM stepside bed sides
OEM bed cross sills (missing thin center one)
67 OEM fenders (rough)
67 OEM specific hood
OEM rear cross brace
OEM hood to windshield cowl1967/8
OEM front grill shell
Have also
1967 specific buddy bucket seats with bracket
OEM CST door mirrors left and right
OEM CST door emblems
1968 OEM wiper arms
Body - Need and do not have
front inner fenders left and right
fender to core support brace x 2
front doors, left and right (might have a set coming from Arizona, clean and rust free)
front stepside bed panel
chevrolet stepside tailgate
67 specific stepside bed fenders
short stepside steps, left and right
Old 01-16-2022, 04:15 PM   #32
SCOTI
SCOTI's Avatar
Heck of a parts list. Sounds like it's going to be a super nice touring-driver of a truck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-16-2022, 04:18 PM   #33
77chris03
77chris03's Avatar
I THOUGHT SO TOO. didnt realize how big the list of crap ive already bought and assembled. ive got over 20k vested and im still just a frame.
Old 01-16-2022, 05:18 PM   #34
indymachinist
Don't worry about the money invested hahaha
I have a mountain of receipts I don't dare try to add up!
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 01-16-2022, 07:02 PM   #35
garyd1961
Awesome build, I have to say your mechanical skills are way more advanced than mine. I feel like I'm in the stone ages working on my old 350. Can't wait to see it finished.
garyd1961 is offline   Reply With Quote
Old 01-17-2022, 12:32 AM   #36
77chris03
77chris03's Avatar
Thank you. just takes time and patience. I love doing it. I cant wait for it to be done either. you wont believe the amount of money and time ive dedicated since 11/22/2021. The day before it was laying on its side in the garage for almost 5 years. in a matter of less than 2 months...ive got a ton done. ONe thing i havent poste or mentioned is that the body parts i do have are at the blaster.....
Old 01-18-2022, 12:56 AM   #37
77chris03
77chris03's Avatar
Stainless brake lines came in. Ordered from online tube and they totally forgot to put the front lines in the box. Let’s hope they send the rest. Zoey had a rough day. While cleaning up the storage barn at my dads and finding a ton of parts I forgot I had, she ran around in the woods, played in the mud, and got all greasy. Came home got a dawn dishsoap bath, and this is where she’s at now. Thinks she is a human I guess. I think she snores louder than me.
Anyways, after cutting and modifying the lines for the rear, the only thing left for the rear end is tighten the lines up, weld the tabs onto the axle and touch it up.
Old 01-18-2022, 09:41 AM   #38
68Stepbed
68Stepbed's Avatar
Nice work, Chris!!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-18-2022, 11:22 AM   #39
77chris03
77chris03's Avatar
Originally Posted by 68Stepbed View Post
Nice work, Chris!!
Thank you sir! was good talking to you the other day. Ill be there where you are here shortly....
Old 01-18-2022, 11:24 AM   #40
77chris03
77chris03's Avatar
The rest of my QA1 stuff should be here this week along with the holley drive system. OH....and inline tube said they are going to send the missing parts. Rack and pinion will be here this week too...Getting closer to being a complete chassis!!
Old 01-18-2022, 06:29 PM   #41
77chris03
77chris03's Avatar
Got home from dropping some stuff off to go out to some board members and boom!!! Look what was left! Qa1 stuff. Ups is getting worse and worse about damaging packages in transit. Thank god it’s only powder coat.
Old 01-18-2022, 06:31 PM   #42
77chris03
77chris03's Avatar
Man I love this little plasma cutter. Best investment. I didn’t even go thru one metabo blade or tiger paw.
Old 01-18-2022, 09:29 PM   #43
77chris03
77chris03's Avatar
So.. wire wheel…sanding disk where needed, little phosphoric acid wash, degrease, dry with a little heat from a torch, and apply the last bit of por15. When she’s dry… time to assemble.
Old 01-19-2022, 12:50 AM   #44
Mbeef61
Mbeef61's Avatar
About to paint my frame. Looks like you painted the front half and then the back later? Did you do anything special to blend?
Mbeef61 is offline   Reply With Quote
Old 01-19-2022, 03:31 AM   #45
77chris03
77chris03's Avatar
It’s por15. Just scuff it up a little bit. Im putting por15 topcoat afterwards to blend. I waited because I needed to cut the c notch out.
Old 01-19-2022, 07:24 PM   #46
77chris03
77chris03's Avatar
5000 bolts later. I don’t know how this kit was designed to be put on with the bed on. Props to who has done it. I didn’t have help so that may be why.
Old 01-20-2022, 12:47 AM   #47
77chris03
77chris03's Avatar
I think I’m done for the night. I didn’t even get the picture of the sway bar in. Can’t tighten or torque anything that moves until I have it at ride height/weight on the suspension.
Old 01-20-2022, 12:51 AM   #48
77chris03
77chris03's Avatar
Just checked on my rack and pinion and it should be here tomorrow end of day. In-line tube should be here soon too for the missing parts. Need to check on the sandblaster and see where he’s at on the cab and stuff.
Old 01-20-2022, 04:17 PM   #49
77chris03
77chris03's Avatar
Probably the easiest thing I’ve installed on the whole frame.
Old 01-25-2022, 10:47 PM   #50
77chris03
77chris03's Avatar
Did something to my lower back and waiting for my VA doc to respond to getting me an appointment to find out what is wrong. Gotta love the VA right? Anyways, got my guys to move the transmission outside so I could prep, sand, clean, prime and paint my t56. What sucks is I have no way to move it back into the garage, ya know, cause I lifted something wrong so… I guess she’s sleeping outside tonite.
slick67
