Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-23-2016, 08:37 PM   #26
Super73
Super73's Avatar
Re: Motor for drag strip
I would not limit fast LS stuff to turbos. That's just where most have gone. Plenty of fast N20 LS combos out there. If your pockets are deep enough, there are some LS combos making >900 NA.
Originally Posted by moggey01 View Post
I've been away for a while helping rebuild the engine shop that burned down at TRE. Taylor is up and running again and I spent last week helping get engines ready for customers to run. All the mentioned combinations will run fast. I think the LS stuff seems to like a turbo . Here lately the growing class is the small block shootout. Nitrous cars are limited to 1 carb and cast manifold. The nitrous combination uses and older style small block combination. This combination has proven to be fast and consistent. Justin is 3 for 3 since they started this class. I agree with Marv that a big block is the cheapest power. It does not require a whole lot of work to make them run. It is all about your pocket. They will all make power.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-24-2016, 10:51 AM   #27
moggey01
I was not limiting the ls to a turbo. There is a customer running almost 175 at the 1/8 with a single turbo ls at 3000 lbs with stock suspension in 97 degree air temp. The meanest nitrous small blocks I know of run 161-162 at that weight. For some reason that combination makes a bunch of power with relatively low boost.
moggey01 is offline   Reply With Quote
Old 06-25-2016, 01:21 AM   #28
Super73
Super73's Avatar
That is moving for sure. Curious what the vehicle is...
Old 06-25-2016, 11:06 AM   #29
moggey01
Super 73 pm sent
