Old 10-22-2016, 11:30 PM   #26
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: La Crosse- 1960 GMC Custom
And here are pics of the truck now.
The front should drop a little more with the motor and trans in it.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 10-22-2016, 11:35 PM   #27
Classic v6 GMC's
We started working on the engine mounts and also purchased the power steering bracket and power brake bracket from Captainfab (Very nice parts).
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 10-23-2016, 12:05 AM   #28
Rolland
Smile Re: La Crosse- 1960 GMC Custom
Looking great Andy! However, I couldn't help noticing that your hood bird must have flown away.
Rolland is offline   Reply With Quote
Old 10-23-2016, 12:15 AM   #29
Classic v6 GMC's
Thanks Rolland and yes the hood bird flew back on the shelf. I don't want anything to happen to it while we are working on it.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 10-25-2016, 10:51 PM   #30
namloc
namloc's Avatar
Lookin good.Great progress.Captainfab is a good guy and his parts are great.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 10-26-2016, 09:25 PM   #31
Classic v6 GMC's
Thanks and yes he is.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-31-2016, 11:34 AM   #32
Classic v6 GMC's
Well I finally have some updates to post after getting side tracked with the 1967 c20.
I pulled the steering column, heater box and master cylinder. Painted the firewall and installed the power brake bracket.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-31-2016, 11:39 AM   #33
Classic v6 GMC's
Installed the power steering adapter plate and steering box. Still need to weld a piece of pipe over the bolt that goes through the top of the frame.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-31-2016, 11:48 AM   #34
Classic v6 GMC's
Removed the rear axle. Now to swap over the mounting pads.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-03-2017, 08:59 PM   #35
Classic v6 GMC's
We got all the brackets/mounting pads removed and set the axle in place.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-03-2017, 09:03 PM   #36
Classic v6 GMC's
Installed new U-bolts and 4" drop springs.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-03-2017, 09:06 PM   #37
DPowers
DPowers's Avatar
Making some progress. Looks good.
DPowers is offline   Reply With Quote
Old 01-03-2017, 09:13 PM   #38
Classic v6 GMC's
Should probably have gone with 3" drop springs because the axle is barely touching the bump stops. Camper must weigh to much.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-03-2017, 09:17 PM   #39
Classic v6 GMC's
Also cut the wheel tubs so we can widen them.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-03-2017, 09:20 PM   #40
Classic v6 GMC's
Thanks, maybe we can get her back on the road by the end of the month.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-04-2017, 01:46 PM   #41
3/4ton Randy
Hey La Crosse, thanks for posting all of those pictures! I am restoring a 66 GMC and will soon be swapping in a front crossmember out of a '82 3/4 ton and a 14 bolt ff axle. I also have been wondering about replacement water pumps for these engines. Has anyone tried Flow Kooler for a water pump? Their website is www.flowcoolerwaterpumps.com Their site says that they can build a new impeller for a water pump that will flow better than the original.
3/4ton Randy is offline   Reply With Quote
Old 01-04-2017, 09:34 PM   #42
Classic v6 GMC's
Glad I could help.
I have bought a couple new old stock water pumps off of eBay over the last few months so I have not looked for new replacements.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-04-2017, 09:39 PM   #43
Classic v6 GMC's
Cut a section off of the cross sill and bolted the wheels on.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-04-2017, 09:41 PM   #44
Classic v6 GMC's
Pics
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-04-2017, 09:47 PM   #45
Classic v6 GMC's
More pics
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-04-2017, 10:04 PM   #46
Classic v6 GMC's
Removed the bumper and spare tire hanger.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-04-2017, 11:36 PM   #47
DPowers
DPowers's Avatar
Thats alot of tire there. What size?
Old 01-05-2017, 11:37 AM   #48
Classic v6 GMC's
P295/50R15
They are around 14" wide.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-11-2017, 07:13 PM   #49
Classic v6 GMC's
I picked up this 1960 GMC Hydramatic steering column a few months ago. I rebuilt it and got it installed today. Now I just need to get a new shift indicator and shift lever.
Also cut the shaft down.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 01-11-2017, 07:21 PM   #50
Classic v6 GMC's
Found this piece of shift linkage on a parts pick about a month ago and it just happened to be the right one.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
