Old 07-30-2016, 08:01 AM   #26
Red Beard
Red Beard's Avatar
Re: Farm Fresh Silverado
Starting to look like a truck again. Set the bed back on it. I need to cut out some of the bed supports to clear the leafs, so the back will look a little lower when I'm done with that.
1987 R10 Silverado "Farm Fresh" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=703698
Red Beard is offline   Reply With Quote
Old 07-30-2016, 09:50 AM   #27
Jstock85
Sweet stance Red! I'm working on a similar project and have a couple questions for you concerning paint. My truck has way more crust underneath so it'll needs more attention! I plan on painting my frame and rear diff exactly like yours and I'll have to shell out a fortune for a product like POR15. Would you mind giving a few details on the rusteloum products you used? I kinda like you where nobody will see it I just want to feel better about cleaning that mess up under there.
Thanks!
Jstock85 is offline   Reply With Quote
Old 07-30-2016, 09:53 AM   #28
Jstock85
Also I don't plan to go as low as you did but I will eventually do the rear disc conversion so keep us posted!!
Old 07-30-2016, 08:15 PM   #29
86454k30
86454k30's Avatar
Nice start! If you mount those dash speakers below the brackets you can space them down with washers or the plastic spacers from an ACE hardware store...thats how I did mine.
86454k30 is offline   Reply With Quote
Old 07-30-2016, 08:22 PM   #30
rusty76
rusty76's Avatar
Cool truck.. Don't know where I have been but I'll be watching for sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-31-2016, 12:03 AM   #31
Red Beard
Red Beard's Avatar
Thanks!
I just hit everything with either scotch brite or a wire wheel. Used some cheap-o Rustoleum semi-gloss black; the springs, shackles, brake lines are a different paint.
Old 07-31-2016, 12:06 AM   #32
Red Beard
Red Beard's Avatar
I was checking that out, wondering if there was a way, for when I get a new dash pad. Mine is cracked so bad I didn't mind if the speakers poked up a little. Have any pictures?
Old 08-01-2016, 02:21 PM   #33
86454k30
86454k30's Avatar
I don't have any pictures but it is pretty straight forward. I used 2 machine screws and nuts instead of the sheet metal screws to attach the speakers. As long as the top of the speaker is below the bracket your good to go. IIRC I used a 3/16" spacer like these
Old 08-02-2016, 12:05 AM   #34
AbigailAmelia
AbigailAmelia's Avatar
Re: 1987 R10 Silverado
I did this little trick with the PEX tubing, so the doors shut a little better... All in all, the doors shut a lot better now.
Hi,
Does this stop the doors from rattling when you close them? Or having to close them again and again just right, like with mine? Why? What is this fixing?
Thanks,
Michelle
"...We won't live forever. Make sure you accomplish what you were put here for.”
Abigail Adams (First Second Lady, Second First Lady)
1977 GMC K25 Sierra Classic Long bed "Abigail Amelia"
1986 Jeep CJ7, 1973 Chevy K5 Blazer (Hubby's projects)
AbigailAmelia is offline   Reply With Quote
Old 08-03-2016, 08:47 PM   #35
Chrispbrown36
It makes it so you don't have to slam the door as hard as you can to get it to close. They sell the actual bushings, but this is much cheaper. I bought the bushings two years ago and they are about shot again so I will be going this route.
Chrispbrown36 is offline   Reply With Quote
Old 08-03-2016, 10:13 PM   #36
Red Beard
Red Beard's Avatar
Originally Posted by AbigailAmelia View Post
Hi,
Thanks,
Michelle
What Chris said. Makes the doors shut a lot easier.
Old 08-03-2016, 10:17 PM   #37
Red Beard
Red Beard's Avatar
These are the two things I need to deal with. The stock exhaust, that GM didn't attempt to tuck up in the slightest bit. Also, I thought it was my tires rubbing on the inner fenders, but come to find out, it is my wheel getting a little friendly with the lower control arm. Still need to blow the front end back apart and replace all the tie rods, ball joints, brakes, etc.
Old 08-03-2016, 10:20 PM   #38
Red Beard
Red Beard's Avatar
Also took some pictures with my actual camera, instead of my phone, just for good measure.
Old 08-04-2016, 10:08 PM   #39
rusty76
rusty76's Avatar
Looking good
My build thread
Crossmembers CC
Old 08-05-2016, 02:20 AM   #40
AbigailAmelia
Hi again,
I'm hoping to fix the rattling doors/missing bushings this weekend (except I will buy pre-made bushings to limit my errors!). Does this just require a hex star wrench that I would likely find in the hubby's tool box? Or something else? Is this straightforward for a newbie, or is there room to mess this up and make the doors worse?
I ask because I watched a related video (different vehicle) and the guy highlighted lining up all the pieces. From the rings around the washers, does it look like the assembly could be out of alignment?
Thanks!
Old 08-05-2016, 07:02 AM   #41
Red Beard
Red Beard's Avatar
Hi again,
Thanks!
It's a large torx, I forget the size. You do have to align it. I didn't remove mine to put the PEX tubing on.
Old 08-22-2016, 10:32 PM   #42
Red Beard
Red Beard's Avatar
I've been so busy with work and life I haven't had much energy to work on my truck. Finally got the bed supports notched and the bed bolted back down. Also put on the "sport" bumper or whatever you want to call it. Took it for a spin around the block, U-joints are angry I think. I'll need to replace those. The rear half is now completely finished. Now to blow apart the front again and get it all buttoned down.
Old 08-23-2016, 08:50 AM   #43
DKO
Nice truck! Keep up the good work.
DKO is offline   Reply With Quote
Old 08-24-2016, 10:53 PM   #44
Matt Man
Matt Man's Avatar
You nailed the stance! This thread is proof you can make a longbed look good slammed.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 09-24-2016, 07:22 PM   #45
Red Beard
Red Beard's Avatar
Thanks guys! I really need to get back out in the garage and get it back on the road. I've been too busy lately.
Old 09-24-2016, 08:25 PM   #46
1970pelle
1970pelle's Avatar
I did the front dash speaker deal also, where I installed them under the metal bracket. I did this when I put the new dash pad on, no fitment issue's.
I also still need to notch my bed cross support after my drop. I didn't notice the leaf springs touching right away. I think I felt the vibration first through the chassis, then tracked it down. My plan is to make a cut and the weld in a repair piece.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 09-25-2016, 04:03 PM   #47
Red Beard
Red Beard's Avatar
Ken
Yeah, I'll have to do something about the speakers when I get a new dash pad. The one I have now is so bad, it doesn't really matter. I pulled the bed off when I lowered the back, so I figured out that I needed to notch the bed supports when I put the bed back on and noticed that I couldn't bolt it back down. Welding in something where it's notched wouldn't be a bad idea. I might do something like that later. I'm taking care of the tie rods, ball joints, and front brakes today.
Old 10-09-2016, 06:26 PM   #48
Red Beard
Red Beard's Avatar
Finally got it back on the road. Been cruising it around a little. Got an alignment and the tires balanced, but I think it needs new tires, something is still shaking. Next on the list is to paint the Rallys and get the rings and caps back on.
Old 10-09-2016, 10:31 PM   #49
Red Beard
Red Beard's Avatar
Here's a few more pictures from today.
Old 12-04-2016, 08:30 PM   #50
Red Beard
Red Beard's Avatar
I decided it's too cold out until spring to paint my wheels, so I put the caps and rings back on. I've been driving it a lot lately. Drives awesome! Haven't done anything to it in a while, so no updates.
