Old 08-27-2016, 06:38 AM   #26
1project2many
Re: Brake issue 59 2ton
Sorry for your loss. I caught the date of the thread start and the date of your brother's passing. What a reminder that we can talk to folks every day and know nothing about what they're going through.
The problems you're having seem similar to problems I've experienced with faulty Hydrovacs. Pull off the vacuum hose that goes from Hydrovac to engine. If there's brake fluid in it then you need a rebuild. I used to have a short piece of brake line that I'd use to bypass the Hydrovac. It eliminated the HV as part of the problem pretty quickly. I can also tell you that we had plenty of problems with reman Hydrovacs being garbage over the years.
Man... that foot doesn't look good. I hope your clutch pedal works a lot easier than your brake.
1project2many is offline   Reply With Quote
Old 08-27-2016, 07:48 AM   #27
Softpatch
Softpatch's Avatar
thanks man....
Ya it was a rebuild Hydrovac booster and I know how that goes
.......Never buy a car made on a monday or friday.... right
I'll look see if any fluid is in the canister
Last few times when Bleed the brakes the truck has been sitting for days
No vacuum..... cold steel
they worked before now they won't hold pressure air in the lines
I can't find any..??
Maybe like some one suggested....
Vice grip the brake hose to isolate each wheel one at a time
I know I'm missing something real simple
.....Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
