Old 11-26-2016, 05:21 PM   #26
Moscowmule
Re: building a mule
also on the front end and rear end they are stamped gm 57 anybody know what they are or how i find out
Moscowmule is offline   Reply With Quote
Old 11-27-2016, 03:35 AM   #27
swamp rat
swamp rat's Avatar
Re: building a mule
Best to start by posting pictures
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-28-2016, 07:06 PM   #28
Moscowmule
Re: building a mule
ya my pictures are in my phone but for some reason they wont transfer to the computer at work like they did before ill figure it out when i get back home in a couple of weeks
Old 02-12-2017, 03:46 AM   #29
Moscowmule
Re: building a mule
so here are some pics of the "new rear end and front end they came out of a 76ish 1/2 ton not sure what they are but i got just about everthing that was attached to them brake booster and power steering included but i didnt get the cross member off the front end. i may be able to go back and get it if i need it. does any body know what they are for sure im asuming the rear is a corp. 10 bolt not sure about the front probably the same?
Old 02-12-2017, 03:52 AM   #30
Moscowmule
Re: building a mule
couple more pics of the front and rear ends
Old 02-12-2017, 03:54 AM   #31
Moscowmule
Re: building a mule
Old 02-12-2017, 03:59 AM   #32
Moscowmule
Angry Re: building a mule
here is a couple of shots of the very dissapointing rot i found under the windshield rubber.rotten all the way through in some places and paper thin the whole way across the upper portion inside and out
Old 02-12-2017, 04:01 AM   #33
Moscowmule
Re: building a mule
so i found a guy 45 miles away that had a cab thats in great shape (ish)Name:  16711965_1192233960823764_3559237972226711365_n.jpg
Size:  73.9 KBaway i go
Old 02-12-2017, 04:07 AM   #34
Moscowmule
Re: building a mule
Funny thing about this business the guy that has the cab tried to sell me the whole truck a few months ago 200$ all i bought at the time was a rearview mirror, parking break lever and a cool spotlight 60 bucks. went back for the cab 500bucks. All the parts that i previously purched were part of the cab but i took them off my first trip.Name:  16649114_1192261070821053_8604683164810598645_n.jpg
Size:  93.2 KBlive and learn i guess
Old 02-12-2017, 04:09 AM   #35
Moscowmule
Re: building a mule
after getting the body off Name:  16708465_1192261700820990_8032911753573927873_n.jpg
Old 02-12-2017, 04:12 AM   #36
Moscowmule
Re: building a mule
new cab on jacks for now
Old 02-12-2017, 04:19 AM   #37
Moscowmule
Re: building a mule
here is the rust on the rockers and floor on the new cab no rust or dents anywhere else so i am happy about that for sure. although just as im typing this i realized i have not pulled the windshield but it sure looks good from the outside i dont know whats under the rubber.Man i feel dumb right now for not pulling the glass before i loaded it up thats what you get for being in a hurry. i wont know what ive got for another month till i get home.
Old 02-12-2017, 06:27 PM   #38
Moscowmule
Re: building a mule
Can somebody tell me hoe far the replacement rockers go into the floor pan?
Old 10-08-2018, 06:52 AM   #39
Moscowmule
Re: building a mule
So I had some time to work on the truck a bit while i was home this time. I ewven took some pictures of the work ive done (not much but progress was made). I know most of you guys know way more about this stuff than i do but i think im going to try to share some of the things i learn as i go hoping maybe it will help somebody like me that is just getting into one of these builds for the first time.
Old 10-08-2018, 06:56 AM   #40
Moscowmule
Re: building a mule
the first thing i did when i got home was clean out the shop because my wife managed to increase the output of her cardboard farm enough that she tried to steal realestate from me.
Old 10-08-2018, 07:00 AM   #41
Moscowmule
Re: building a mule
Last year i found a front end from a 73 k10 that had all the power steering and disc brake set up i was looking for. iI got it cleaned up and replaced allo the seals and bearings brake rotors calipers and upgraded to warn locking hubs
Old 10-08-2018, 07:06 AM   #42
Moscowmule
Re: building a mule
not sure why they are upside down
Old 10-08-2018, 07:11 AM   #43
Moscowmule
Re: building a mule
I cleaned the front end with a wire brush and wire when on a grinder then wiped it all down with brake clean. then applied a coat of por15. then let it dry for a coup[le hours until it wasnt tacky any more and applied 2nd coat. when the first coat dried it was kindof a flat black and the second coat was more of a satin finish.
Old 10-08-2018, 07:20 AM   #44
Moscowmule
Re: building a mule
After reading on here multiple post about por 15 i decided to give it a go.
one thing i learned from the message board was not to open the can but instead just drill a hole and seal it with a screw. this worked great however what i learned from my own misery was do not shake the can to mix before you drill the hole. when i popped the hole in that crap sprayed out like a tiny fountain made a heck of a mess. so drill your hole put your screw in and shake away then remove your screw no mess.Name:  20180914_124758.jpg
Old 10-08-2018, 07:30 AM   #45
Moscowmule
Re: building a mule
i found it was easier to chase the runs if i hung the parts verticle
Old 10-08-2018, 07:34 AM   #46
Moscowmule
Re: building a mule
Size:  41.4 KB can someone tell me how to make the pictures right side up?
Old 10-08-2018, 07:40 AM   #47
Moscowmule
Re: building a mule
Size:  81.6 KB new hubs bearings seals replaced everything except the gears they looked great. all of the bearings and seals looked to be in excellent condition when i took them out but i figured might as well do it while i was in it
Old 10-08-2018, 07:55 AM   #48
Moscowmule
Re: building a mule
[attach]Name:  20180905_145123.jpg
Size:  45.3 KB[/attach]Name:  20180905_145123.jpg
Old 10-08-2018, 08:26 AM   #49
Moscowmule
Re: building a mule
i used a scraper and a wire brush on the frame.there really wasnt anything much for rust mostly dirt got it all cleaned up found 2 cracks up where the bumper mounts up nothing major. i just ground out the crackes and welded them up .
Old 10-08-2018, 08:38 AM   #50
Moscowmule
Re: building a mule
por 15 for the frame now i did 2 coats one side then flipped it over with a chain hoist and come along and did 2 coats on the rest
