01-31-2020, 12:24 PM | #26 | |
Old member
Re: $155.00 Radiator
Yea I didn't buy any of the fans, I don't think anyway. Come to think of it I think maybe I did for the 56 when I ordered it.
01-31-2020, 12:54 PM | #27 |
I may have to get one of these as well.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
02-01-2020, 09:58 PM | #28 |
Old member
Here is a listing on E bay.
https://www.ebay.com/itm/3-Rows-FOR-...sAAOSwQItT0h2n 3 Rows FOR 1967-1972 Chevy Pickup Truck All Aluminum Radiator 68 69 70 71 +fans Here is one without fans. https://www.ebay.com/itm/3-Rows-alum...oAAOxyQfJTfble
02-01-2020, 11:04 PM | #29 |
I snagged one last night with fans because of this thread. Pretty far out from being ready to install, but I'll have it when I get there.
72 C10 lwb fleetside aka Big Rhonda. Still plugging away. Build thread: http://67-72chevytrucks.com/vboard/s...42#post8247142 |
02-01-2020, 11:34 PM | #30 | |
Old member
Good deal sir! You will be pleased I'm sure.
02-02-2020, 01:31 AM | #31 |
This is the one I picked up:
https://www.ebay.com/itm/263884165440
72 C10 lwb fleetside -stock 350/350 combo |
02-03-2020, 01:07 AM | #32 |
Does it have a heater return inlet? If so what size. Thanks
02-03-2020, 09:55 AM | #33 |
Old member
I've never used the radiator heater connection on them. I always run it to the intake. I have no idea what size it is. All I've ever done is make sure it's tight.
02-12-2020, 12:37 PM | #34 |
Got mine in and installed it over the weekend. Sorry, no pics. Mine is about an 1/8" short of fitting. I figure its because the rubber in the brackets are worn. Just gonna cut pieces off the old hoses to take up the slack until I replace the rubber. It looks pretty damn good in there I must say
03-31-2020, 05:48 PM | #35 |
Now that I've had this setup installed for awhile and have drove the truck a few times, I can provide an update.
Just an FYI for anyone considering buying this radiator with the dual fans - the fans are advertised as 1,200 CFM each but they don't come close to that. I've driven my truck a few times since installing and they're never capable of keeping my LS below 200 with both running half speed, the coolant always heats up to 205 or higher and triggers the PCM to run both fans full speed. This is in 60 degree or lower weather, no AC. I found the fans on Amazon for $20 each and they're sold by a company called UPGR8. They're advertised as 1,200 CFM each and pulling 80W. I've been looking at Spal fans rated at 1,200 CFM and they pull 160W which confirms my suspicion. I even found a review on Amazon for one of the Spal fans I'm looking at which references these cheap fans and how much of an upgrade the Spal fans were. The wires to the fans are no bigger than 18 gage whereas Spal is 12. The radiator itself is still great, no leaks. Just want everyone to be aware of how cheap and low performance the fans are. I didn't have high expectations of them from the beginning, but a radiator with dual fan aluminum shroud for $200 is still a good deal to me.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
03-31-2020, 06:17 PM | #36 |
Old member
This is why I don't buy the fans. They are cheap knock off's.
