11-15-2016, 10:04 PM | #26 |
Post Whore
Re: Vanschoyck MetalWorks & Artistry's 67 c10
Great work. I didn't think anyone under 40 knew what 6011 was let alone how to use it.
Welcome aboard
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-15-2016, 11:38 PM | #27 |
11-15-2016, 11:41 PM | #28 |
Thank you very much brother! Like I said I'm still learning, I've only been welding a little over a year but I started with what they say is the hardest and most old fashioned process, arc welding! In my class I took everyone complained about running 6010/6011 especially overhead and vertical so being the guy who loves to do things people say you can't, I of course picked that electrode to focus on! After using these rods I won't use anything else! Thanks so much for the kinds words!
11-15-2016, 11:52 PM | #29 |
Got started on the front frame horns today guys! And BOY did it go rough lol. First I measured the Z and realized I had actually done a 3-1/4" Z, no big deal! So I cut the horns off and got them in place and tacked them, looked good so I ran a bead on the inside, cut through the front side until I found my weld and welded it up (to insure 100% penetration.) measured again and low and behold one side was 1/4" off! Dang! Had to cut it back off and re-do that! Next I made the gussets for the bottom and plates for the top. Seemed like I had the worst time getting in a decent position but I finally managed to get those pieces in. About this time I decided I'd had enough and was gonna call it a night because it's getting pretty cold! I let the truck down off the jack and decided to check and see how low the front bumper was gonna be! Put on bolt in and WTH?!?! The other side was about 1/2" off!!!!! Rookie mistake! Didn't put a cross brace on the pieces before I cut them off!!! I got my small propane torch and heated as much as I could and pushed with my legs until I bent the horn out enough to thread the other bolt in. At this time I was so stressed out I started 2nd guessing myself!!! Maybe my welds will fail, nothing is gonna line up, etc etc. then it dawned on me, a good weld is suppose to bend, not crack or break so this was actually a great sign!!! Lesson learned!!! Tomorrow I'm going to try to cut, fit, and weld up those bottom plates, the whole point of this long post is maybe someone can learn from my mistakes!!! Always brace, always measure BEFORE you run a full bead!!! At the end of the day, it's just metal, with enough heat, grinding, cutting, welding, it'll go where you want it to go! Will def get some pics for you guys tomorrow!
11-15-2016, 11:59 PM | #30 | |
So who still stick welds???
Jimmy Hoelzel |
11-16-2016, 12:01 AM | #31 |
Post Whore
Well don't give up on the rest. 7018 is a nice rod, a little more difficult on verticals and overhead, but comes out real pretty and if your setup is right it almost chips it's own slag. It won't burn through rust like 6011 will so good prep or new steel is important. Keep up the good work.
. I raise my barley pop and salute you and your skills.
11-16-2016, 12:22 AM | #32 | |
Here's a pic of that slag rolling off like you was talking about with 7018 on a scrap piece I use to set my heat!!! Makes really pretty welds!!! |
11-16-2016, 12:25 AM | #33 |
11-16-2016, 12:45 AM | #34 |
Post Whore
She sounds like a keeper.
11-16-2016, 01:51 AM | #35 | |
Good luck with the build! |
11-16-2016, 06:39 AM | #36 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-16-2016, 10:24 AM | #37 |
11-16-2016, 10:25 AM | #38 | |
11-16-2016, 10:34 AM | #39 | |
11-18-2016, 09:25 PM | #40 |
finally got around to the front! Man this was a nightmare to get to some of these joints!!! Also some bad fit up on my part but I'm getting better and better at closing gaps/holes!
11-18-2016, 09:27 PM | #41 |
More pics
11-18-2016, 09:30 PM | #42 |
also wanted to show you guys this lamp I built the other day! I think it turned out pretty cool!
11-18-2016, 09:38 PM | #43 |
ok last post for now i promise lol don't know if any of you guys are into art or not, but figured I'd share this as well since everyone here seems so cool! This is a charcoal drawing I finished that I started working on in 2015 haha hope y'all like it!
11-18-2016, 09:46 PM | #44 |
Great work brother! Can't wait to see the sheetmetal back on the frame, keep it going!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
11-18-2016, 09:47 PM | #45 |
The chassis looks pretty good! Cool lamp, but a killer art piece! You need that framed for the Man Cave!
Keep up the great work! What is next on your list of to-do's?
Jimmy Hoelzel |
11-18-2016, 11:53 PM | #46 |
11-18-2016, 11:57 PM | #47 |
Thanks for the kind words!!! I think the next thing would be to try to get the back end of the frame down. I'm thinking I will just Z the rear as I've seen some people do and see how low that gets me. I'm thinking if I run a small enough diameter tire I can get it to lay frame. I need to put my bag plates/cups in as well up front, need to buy some drill bits! Also I need to box the frame in all the Z points. Running really low on materials so it may be a few days!
11-20-2016, 11:33 AM | #48 |
Here are my bag cups, I had some tape laying around didn't know the width so I threw a piece on and it looks like this may be too much to cut off the cups? Can these trucks lay frame on a 16" wheel with cups/plates?? Any help would be appreciated guys, thanks!
11-22-2016, 07:03 PM | #49 |
Finally started on the back. Ran out of rods so, this is as far as I have made it. If my measurements are correct, the back should be about 1" from laying out with this size tire 28.5-29". Now to get the damn front down!
11-22-2016, 07:41 PM | #50 | |
If I might add some insight.... Getting it as low as can be w/wheel & tires appropriately sized yields better visual results vs. using shorter wheels & tires just to make it as low as possible. I've seen more than a few trucks that the owner got it to 'lay frame' but used super short tires that did not look as good as another truck that maybe doesn't lay frame but has the wheel well filled. Food for thought.
