05-07-2017, 11:04 PM | #26 |
Re: rear end pinion angle issues
i'll be checking on tuesday/wednesday. unfortunately the truck and I don't share the same physical address as my work makes me travel. I'm going to take it apart at the slip shaft and line everything up. i read that < 3 degrees is ok and that I'm just to take a inclinometer and measure on top or bottom of each u joint cup. anything else i should look for?
05-08-2017, 12:31 AM | #27 |
Post Whore
Yep..3 deg down on trans ..3 deg up on rear diff
05-08-2017, 07:08 AM | #28 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=522180 K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-09-2017, 06:03 PM | #29 |
after checking the angles and phasing. they are all correct. What i did notice was something much simpler. I made my own set back place and I believe I made them too short. I'll take some better pictures tomorrow morning.
What I think is happening is under acceleration the rear end rotation upward what would be an acceptable amount nut it basically falls off the back of the setback plates. when i built them i basically did a 2.5" x 5" plate on top of the leaf spring, cut the hole out so it would sit flush and then welded in a 5/8" round stock bar to fit inside the perch. the plate ends about 1/4" after the round stock I welded in so half of the perch on the rear end axle is not touching anything. |
05-09-2017, 06:40 PM | #30 |
Post Whore
Sounds like you may have found the problem..
