03-29-2018, 08:15 PM | #26 |
“On The Hunt”
Re: F/S C & K Auto Trans Shfit Linkage Setups SBC & BBC
I’d take a set up for a big block Chevy turbo Hydro 350 transmission 4x4
03-29-2018, 08:29 PM | #27 |
Always on the hunt...
Hi Nic, would this needed trans linkage setup be for the 67 4wd that's being converted to a big block? Am not sure if you have more than one project going or not, but if so you would need the longer SBC/Th350 K/auto linkage setup due to motor/trans/transfer position. Also, did you catch that I had added some info for you in the BBC parts thread on the fan shroud? Mel
03-29-2018, 08:37 PM | #28 |
But Found Her 25yrs Later!
How much to ship to 97045?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-29-2018, 09:20 PM | #29 |
“On The Hunt”
Per our conversation, I’ll take the SBC/Th350 K/auto linkage setup
03-29-2018, 09:32 PM | #30 |
03-29-2018, 11:54 PM | #31 |
How about $36 shipped through UPS or FedEx?
03-30-2018, 02:12 AM | #32 |
I would take the 4wd sbc/th 350 setup without the lever/ spring and washer if it's available. thanks
03-30-2018, 03:10 PM | #33 |
Active Member
i need a complete set up for a small block minus the long rod that comes from the steering column if you have any left
thanks Bryan |
03-31-2018, 09:37 PM | #34 |
Here is the 2wd SBC/TH linkage rod that will be sent, we can do a little better than your offered amount. The fedex ship quote is $10.76 for home delivery with a total transit time of 1-business day, so lets call it $31. to your door. Thanks, Mel
03-31-2018, 09:47 PM | #35 |
We can get this SBC/TH 4wd linkage setup (w/o trans lever) headed your way, cost would be $70. plus $18.90 for the USPS shipment, payment options are listed in post #1 of this thread. Thanks, Mel
04-01-2018, 12:20 AM | #36 | |
USPS has let me down too many times. I'll reply to your PM.
04-02-2018, 07:09 PM | #37 |
Payment sent....
Before you ship it off, would you happen to have misc e-brake pieces?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 04-02-2018 at 07:16 PM. |
04-03-2018, 12:46 AM | #38 |
Sorry, too late the linkage rod is already under way, it was shipped out via FedEx on Mon. 04/02, as of this evening the FedEx website is estimating that you should see the package on Wed. 04/04 by the end of the day. Once a deal is in the works and the pm process begins, I sign off of every sent message with our contact number, had you called I could have held the shipment as some days I am not back to the desk/computer until the evening. Your fedex label info was printed out when you provided the address on Sunday. Again sorry, Mel
04-03-2018, 08:01 AM | #39 |
Active Member
do you have another set for a 68 small block? im using a 200r4
thanks Bryan |
04-03-2018, 02:06 PM | #40 |
Pm sent thanks
04-04-2018, 07:12 AM | #41 |
Hi Bryan, here is the 2wd SBC/TH350-400 auto trans linkage setup that we can get headed your way, cost is $60. complete as previously listed/sold in thread. The shipping cost and payment options are listed in the first post of this thread. Thanks, Mel
04-04-2018, 07:48 AM | #42 | |
Active Member
thanks bryan |
04-05-2018, 04:54 PM | #43 |
The 2wd SBC/TH350-400 linkage setup has been shipped, your package went out USPS priority on Thu. 04/05 and the projected delivery date listed on the postal receipt is Mon. 04/09. Thanks, Mel
Your 4wd SBC/TH350 linkage setup has been shipped, the package went out USPS priority on Thu. 04/05 and the projected delivery date listed on the postal receipt is Mon. 04/09. Thank again, Mel |
04-17-2018, 11:37 AM | #44 |
Mel, I will take one set of Big Block and one set of two wheel drive small block. Sending PM. Thanks Tim
04-19-2018, 12:31 AM | #45 |
Hey Tim, here are the 2wd BBC/TH400 and the 2wd SBC/TH350-400 (w/o trans lever) auto linkage setups that are headed your way, the package went out USPS priority on Wed. 04/18 and the projected delivery date listed on the postal receipt is this Sat. 04/21. Thanks again and keep us in mind if we can help with anything else 67-72 related in the future, Mel
04-19-2018, 02:13 PM | #46 |
07-10-2018, 09:07 AM | #47 |
Is there another SBC/TH350 linkage package available? If so, I'd like to purchase one.
Thanks! |
07-10-2018, 10:10 PM | #48 |
Do you have any dual diaphragm brake booster complete bracket set up 71-72?
Thanks Mel |
07-12-2018, 10:09 PM | #49 | |
Also per your separate pm, I can check on availability of the requested shift lever in the morning. . |
07-13-2018, 08:04 AM | #50 |
If there is a 4wd set up available I'll take it
