11-06-2017, 08:20 PM | #26 |
Re: Guess that clip, clamp, retainer, etc.
A few steel retainers I missed.
Does anyone have a picture or source to the wire A/C wire & vacuum line retainers mounted on the bottom of the evaporator box? My notes say they're nylon, but I don't recall seeing etc. I added an image for the locations from the assm. manual. Also, (ha), I'm trying to confirm which head the temperature sender is supposed to go on, for a BBC. Pretty sure it's the LH head. Mine is on the right, which is probably on me from long ago. And, can anyone describe what retainers were used for the temperature wire, and perhaps a route description? I'm bet the house (gulp) one of those valve cover retainers in post 25 is used (4th row, 2nd & 3rd piece), but I'd like to know of any retainers used behind the head or at the F/W. Thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-06-2017 at 09:12 PM. |
11-07-2017, 12:48 AM | #27 |
Carpe manana
See first pic here for harness retainer on AC box: http://67-72chevytrucks.com/vboard/s...1&postcount=54
Not nylon. Retainer for temp send wire on a SBC uses a retainer woven into the harness that affixes at the lower LH stud of the water pump.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-07-2017, 12:59 AM | #28 |
Who Changed This?
My '70 402-equipped truck has the temp sender on the passenger's (right) side head, by the engine oil dip stick. It appears to be the factory routing. NB: the engine has been rebuilt, so it may be wrong, but that wire sits in the harness as looking proper.
11-07-2017, 01:59 AM | #29 | |
What the.....WATER PUMP? Hmmm, doesn't apply to BBC, the pump is out of the way.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-07-2017 at 02:20 AM. |
11-07-2017, 02:07 AM | #30 | |
Can you describe how the wire is routed and any retainers? On my truck, the wire came off the RH (truck side) portion of the firewall block. Pretty sure it routes through the firewall gutter, then?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-07-2017 at 02:27 AM. |
06-29-2018, 06:06 PM | #31 |
Link was lost, so here are the retainers
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-12-2019, 06:45 PM | #32 |
Been a while but does anybody know if these type of clips are reusable? I'm assuming yes, but I have yet to find an answer as to how...
These came off of my dads 1964 c10 LWB. I'm almost positive these have never been removed from the truck. EVER. #1 everything was covered with about 2" thick of neglect and road grime. #2 passengers side front drum brake spindle still has the factory stainless steel tag around the tie rod connection. If there are reusable how do I reset them without destroying them? Any and all help is much appreciated. Oh yeah, these are for the manual drum brake hard lines the run along the chassis
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
